    Fix Windows 10 Update Issues
    Are you working from home?
HP Single-Function and Multi-Function Printers - Fatal Error 'Error 1935. Fatal error during installation.' (MSI Error 1935) Displays During HP Software Installation
Issue
While you install the HP software, the following fatal error message displays on the computer: 'Fatal error during installation. Error 1935'. The rest of the text in the error message might vary.
Some of the following solutions require you to restart the computer. Consider bookmarking this page on your Web browser, so that you can reference it after restarting the computer.
