HP Designjet 4000 Printer Series - Out of Memory Error
Issue:
During a print, the front panel is displaying an Out of Memory error message, and the printer does not finish the print. This occurs when using the Windows HP-GL/2 driver (office driver).
Solution
  1. Access the printers properties (printing preferences on some systems).
  2. Select the Services tab.
  3. Click on Troubleshoot software problems.
  4. Choose Print job as bitmap (process in computer).
    Print job will now be processed in computer before being sent to the printer.
    The time needed to process the job in the computer may be considerably longer.
Summary
There is no direct relationship between the size of a file in your computer and the amount of memory needed in the printer to print the file. In fact, because of file compression and other complicating factors it is often impossible to estimate how much memory will be needed. So it is possible that a print will fail for lack of memory even though you may have successfully printed larger files in the past.
