    Fix HP Printer issue on macOS
HP Compaq nc8000 Notebook PC and HP Compaq nw8000 Mobile Workstation - Specifications
System Specifications
Feature
Specification
Dimensions (HxWxD)
15-inch TFT panel display
4.1 x 32.6 x 27.5 cm (1.6 x 12.8 x 10.8 in )
System with main battery and MultiBay weight saver
2.96 kg (6.5 lbs)
Stand-Alone Power Requirements
Nominal Operating Voltage (Li-Ion)
14.4 VDC
Max Operating Power
60W
Peak Operating Power
65W
Temperature
Operating
10° to 35° C (50° to 95° F)
Non-operating
–20° to 60° C (-4° to 140° F)
Relative Humidity
Operating
10% to 90% relative humidity, non-condensing
Non-operating
5% to 90% relative humidity, 38.7° C (101.6° F) Maximum wetbulb temperature
Shock
Operating
40 G, 2 ms, half-sine
Non-operating
240 G, 2 ms, half-sine
Vibration
Operating
0.5 G, 10 to 500 Hz, 0.5 Oct/Min sweep rate
Non-operating
1.0 G, 10 to 500 Hz, 0.5 Oct/Min sweep rate
Maximum Altitude (unpressurized)
Operating
3,048 m (0 to 10,000 ft) (14.7 to 10.1 psia)
Non-operating
9,144 m (0 to 30,000 ft) (14.7 to 4.4 psia)
Industry Standard Certifications
Blue Angel
No
UL
Yes
Canadian Safety
Yes
TUV GS
Yes
Nordic Safety
Yes
Mexican Safety
Yes
Poland Compliance
Yes
Australia / NZ Compliance
Yes
CCC
Yes
Japan Compliance
Yes
MIC
Yes
BSMI
Yes
CE Marking Compliance
Yes
KONCAR
Yes
GOST
Yes
SASO
Yes
SABS
Yes
UKRSERTCOMPUTER
Yes
AC Adapter
Feature
Specification
AC adapter
0.29 kg (0.65 lb)
Power cord
0.13 kg (0.29 lb)
Power Supply (Input)
Operating Voltage
90 to 264 VAC RMS
Operating Current
1.6 A RMS
Operating Frequency Range
47 to 63 Hz AC
Maximum Transient
4/50 kV
Maximum Operating Power
65 Watts
Audio
Feature
Specification
Implementation
AC97 CODEC
Audio Signal Link to CPU
Audio CODEC (AC) link
Full Duplex
Yes
Stereo Inputs
Line In - 20K Impedance (with Port Replicator only)
Mono Inputs
Microphone - 20K Impedance
Stereo Outputs
Headphone jack, S/PDIF from Port Replicator only
Frequency Response
20 Hz - 20 kHz
Signal to Noise Ratio
>94dB
Total Harmonic Distortion
0.01%
Noise Floor
-120dB
Play/Record Sampling Rate(s)
7 kHz - 48 kHz
AD/DA Resolution
16 bit
Mono Speaker Amplifier Power
2-Watts RMS
Mono Speaker Speaker Impedance
4-Ohms
Battery
Feature
Specification
Dimensions (H x W x L)
1.9 x 7.6 x 14.7 cm (0.75 x 3.0 x 5.8 in)
0.42 kg (0.92 lb)
Cells/Type
8-cell Lithium-Ion
Energy
Voltage
14.4 V
Amp-hour capacity
4.4 Ah
Watt-hour capacity
63Wh
Temperature
Operating
5° to 45° C (41° to 113° F)
Non-operating
20° to 60° C (32° to 140° F)
Battery Re-Charge Time
System in OFF mode or Standby
3 hours
System ON (depending on system power consumption)
3-5 hours
Bluetooth
Feature
Specification
Form Factor
Integrated USB module
Bluetooth
1.1 Compliant
Dimensions
26 x 14 x 5.7 mm (1.02 x 0.55 x 0.22 in)
Temperature
Operating
–20° to 70° C (-4° to 158° F)
Non-operating
–40° to 80° C (-40° to 176° F)
Humidity
10% to 90% operating
5% to 95% non operating
Altitude
Operating
4,572 m (15,000 ft)
Non-operating
12,192 m (40,000 ft)
Plug and Play
USB 1.1 compliant
Microsoft Windows Plug and Play compliant
Frequency Band
2402 to 2480 MHz
Number of Available Channels
79 (1 MHz) available channels
Data Rates and throughput
  • 1 Mbps
  • Synchronous Connection Oriented links up to 3, 64 kbps, voice channels
  • Asynchronous Connection Less links 723.2 kbps/57.6 kbps asymmetric or 433.9 kbps symmetric
Antenna type
Internally integrated within module
Range
33 ft (10 m)
OS Support
  • Microsoft Windows XP Professional and Home
  • Microsoft Windows 2000
Software Stack Supported
User may choose:
  • Microsoft User Interface (Profiles supported: HID, DUN, HCRP)
  • Widcomm User Interface (see profile support below)
Profile Support
  • General Access Profile
  • Service Discovery Application Profile
  • Serial Port Profile
  • Generic Object Exchange Profile
  • File Transfer Profile
  • Synchronization Profile
  • Dial-Up Networking Profile
  • LAN Access Profile
  • Object Push Profile
  • Hard Copy Cable Replacement Profile
  • Personal Area Networking Profile
  • Human Interface Device Profile
Usage Models
Service Discovery (determine what Bluetooth devices are within range and support authorization)
  • Synchronization
  • PDAs to PCs
  • Portable to Desktop
  • File Transfer
  • File and directory browsing and navigation on another Bluetooth device
  • File copying
  • Object manipulation – including add, delete, create new folders etc
  • Wireless link to Corporate LAN using several Bluetooth devices sharing the same
  • Access Point
  • Corporate email, network neighborhood, access to LAN applications, file transfer, ftp, Internet browsing, etc., using TCP/IP
  • Wireless link to WAN thru cell phone
  • Agnostic to WAN technology
  • Send/receive SMS messages
  • Wireless link to Printer
  • Adhoc peer to peer networking (two computers) or Personal Area Networking (PAN) using NDIS (<7 computers)
  • Adhoc Bluetooth Pico-networking (point to multi-point)
  • Object Push – Business card or appointment exchange
  • Human Interface Devices
  • Wirelessly interface to notebook with mouse, keyboard, etc
  • Printing
  • Wirelessly print to Bluetooth enabled printers
Transmit Power
-6dBm to 4 dBm (Bluetooth Class II)
Receive Sensitivity
Better than –80 dBM at 0.1 % raw bit error rate
Link Topology
Point to Point, Multipoint Pico Nets up to 7 slaves
Security
Full support of Bluetooth Security Provisions
Network Architecture Models
  • Ad-hoc (Peer to Peer)
  • Infrastructure (Access Points Required)
Power Requirement
Peak
<270 mW
Power Management
  • Microsoft Windows ACPI, and USB Bus Support
  • Wireless EAB On/Off
  • Software On/Off control
  • Self configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniff
Protocols Supported
  • TCP/IP
  • IPX/SPX
  • UDP
LED Activity
  • Solid Blue LED – On
  • LED Off – Power Off
Certifications
All necessary regulatory approvals for countries we support including
  • CC (47 CFR) Part 15C, Section 15.247 & 15.249
  • FCC (47 CFR) Part 15C, Section 15.247 & 15.249
  • ETS 300 328, ETS 300 826
  • Low Voltage Directive IEC950
  • UL, CSA, and CE Mark
Diskette Drives
Feature
Specification
MultiBay Diskette Drive
Dimensions (H x W x D)
1.35 x 13.28 x 13.88 cm (0.5 x 5.22 x 5.46 in)
230 g (0.51lb)
Diskette Size
3.5 in
Height
12.7 mm
Bytes per Sector
512
Sectors per track
High density
18 (1.44 MB)/15 (1.2 MB)
Low density
9
Tracks per side
High density
80 (1.44 MB)/80 (1.2 MB)
Low density
80
Read/Write heads
2
Access Times
Track-to track (high/low)
3 ms/6 ms
Average (high/low)
94 ms/174 ms
Settling time
15 ms
Latency average
100 ms
Feature
Specification
15.0-Inch Color TFT XGA Display
30.4 x 22.8 cm (12.0 x 9.0 in)
Diagonal Size
15.0 in (38.0 cm)
Mounting
Internal
Number of Colors
16 M
Contrast Ratio
250:1 typical
Refresh Rate
60 Hz
Brightness
180 nit typical
Pixel Resolution
Pitch
0.297 x 0.297 mm
Format
1024 x 768
Configuration
RGB Stripe
Backlight
CCFT
Character Display
80 x 25
Total Power Consumption
4 W
Viewing Angle
+/-45° Horizontal, +15° /-35° Vertical (typical)
15.0-Inch Color TFT SXGA+ Display
Diagonal Size
15.0 in (38.0 cm)
Mounting
Internal
Number of Colors
16 M
Contrast Ratio
300:1 typical
Refresh Rate
60 Hz
Brightness
180 nit typical
Pixel Resolution
Pitch
0.217 x 0.217 mm
Format
1400 x 1050
Configuration
RGB Stripe
Backlight
CCFT
Character Display
80 x 25
4 W
Viewing Angle
+/-60° Horizontal, +40° /-45° Vertical (typical)
15.0-Inch Color TFT UXGA Display
Diagonal Size
15.0 in (38.0 cm)
Mounting
Internal
Number of Colors
16 M
Contrast Ratio
300:1 typical
Refresh Rate
60 Hz
Brightness
180 nit typical
Pixel Resolution
Pitch
0.190 x 0.190 mm
Format
1600 x 1200
Configuration
RGB Stripe
Backlight
CCFT
Character Display
80 x 25
4 W
Viewing Angle
Hard Drives
Feature
Specification
60-GB 7200 rpm
MultiBay Drive Adapter
1.27 x 13.25 x 12.61 cm (0.5 x 5.21 x 4.97 in)
70 g (0.15 lb)
Drive Weight
115 g (0.25 lb)
Capacity
60 GB
Height
9.5 mm (0.74 in)
Width
70 mm (2.75 in)
Interface
ATA-6
Transfer Rate
Synchronous (maximum)
100 MB/s (Drive Capability)
Security
ATA Security
Seek Time (typical reads, including settling)
Single Track
3 ms
Average
10 ms
Maximum
22 ms
Rotational Speed
7200 rpm
Logical Blocks
117,210,240
Operating Temperature
5° to 55° C (41° to 131° F)
Features
Security
ATA Security
60-GB 5400 rpm
70 g (0.15 lb)
Drive Weight
0.22 lb (102 g)
Capacity
60 GB
Height
9.5 mm (0.74 in)
Width
70 mm (2.75 in)
Interface
ATA-5
Transfer Rate
Security
ATA Security
Single Track
3 ms
Average
13 ms
Maximum
24 ms
Rotational Speed
5400 rpm
Logical Blocks
117,210,240
Features
Security
ATA Security
40-GB 5400 rpm
70 g (0.15 lb)
Drive Weight
102 g (0.22 lb)
Capacity
40 GB
Height
9.5 mm (0.74 in)
Width
70 mm (2.75 in)
Interface
ATA-5
Transfer Rate
Security
ATA Security
Single Track
3 ms
Average
13 ms
Maximum
24 ms
Rotational Speed
5400 rpm
Logical Blocks
78,140,160
Features
Security
ATA Security
Integrated NIC
Feature
Specification
Integrated 10/100/1000 NIC
Ethernet Features
  • 10 Mbit/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 Mbit/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
  • 1000 Mbit/s operation (1000BASE-T; IEEE 802.3z and 802.3ab; IEEE 802.3 clauses 34-42)
  • Auto-Negotiation (Automatic Speed Selection)
  • Full Duplex Operation at all Speeds, Half Duplex operation at 10 and 100 Mbit/s
  • IEEE 802.1p QoS (Quality of Service) Support
  • IEEE 802.3x Flow Control (IEEE 802.3 clauses 31-32; configurable)
Power Management
  • ACPI 1.1a compliant -- multiple power modes
  • Situation-sensitive features reduce power consumption
  • NIC Battery Saving Mode (enabled by default)
Performance Features
  • TCP/IP/UDP Checksum Offload (configurable)
  • Microsoft Large Send Offload (configurable)
  • TCP Segmentation Offload
  • CPU Task Offload
  • Adaptive Interrupts
Manageability
  • Wake-on-LAN from all Power-Managed States (configurable; Magic Packet and Microsoft Wake-Up Frame)
  • PXE 2.0 Remote Boot
  • Statistics Gathering (SNMP MIB II, Ethernet-like MIB, Ethernet MIB (802.3x, clause 30))
  • Comprehensive diagnostic and configuration software suite
  • Cable Analyzer
NIC Device Driver Name
Broadcom NetXtreme Gigabit Ethernet
Drivers Available
  • Windows XP
  • Windows 2000
  • Linux kernel versions 2.2 and 2.4
Modem
Feature
Specification
Agere Systems AC'97 Modem
Form Factor
MDC Daughtercard
Power Management Support
APM Revision 1.2, ACPI
Approvals/ Certifications
UL, CSA, NEMKO, CCIB, Industry Canada, FCC Part 68, CTR21, FCC Part 15 Class B, Canadian ICES-003 Class B, C.I.S.P.R.22, Australian ACA, CE Mark, Other Countries
Modem Device Driver Name
Data Mode Capabilities
V.92
V.90 (a-law, mu-law)
V.8bis
V.80
V44, V.42bis, MNP5 (Compression)
V.42 (LAPM, MNP2-4) (Error Correction)
V.34 (file date: 10/96)
Optional symbol rates:
  • 2800, 3429
  • Asymmetric Symbol rates
ronous primary channel data signaling rates:
  • 3600, 31200
  • Automatic rate re-negotiation
  • V.32bis
  • V.32
  • V.23
  • V.22bis
  • V.22
  • V.21
  • Bell 212A
  • Bell 103J
Fax Mode Capabilities
  • TIA/EIA-578-B (Class 1)
  • T.30, T.4 (Group 3)
  • V.17
  • V.29
  • V.27ter
  • V.21 Channel 2
Command Set
  • V.250 (Partial)
  • TIA-602
  • Identification: +GMI, +GMM, +GMR
  • Port control: +IPR, +ICF, +IFC, +ILRR
  • Modulation: +MS, +MR, +MA
  • Error control: +ES, +ER, +EB, +ESR, +ETBM
  • Data compression: +DS, +DR
  • V.251
MultiBay Battery Pack
Feature
Specification
1.3 x 13.2 x 13.9 cm (0.5 x 5.2 x 5.45 in)
Weight (includes caddy)
0.39 kg (86 lb)
Cells/Type
8-cell Lithium-Ion
Energy
Voltage
14.8 V
Amp-hour capacity
3.6 Ah
Watt-hour capacity
53Wh
Temperature
Operating
Non-operating
–20° to 60° C (32° to 140° F)
2-3 hours
3-5 hours
Optical Drives
Feature
Specification
CD-ROM Drive
Dimensions
225 g (0.496 lb)
Access Times
Random
<110 ms CD
Full Stroke
<220 ms CD
Max data transfer rate
24X CD-ROM
3,600 KB/s
Transfer Mode
Multiword DMA Mode 2
Interface
EIDE
Supported Media (read)
CD-DA, CD+(E)G, CD-MIDI, CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW
Supported Media (write)
None
Media Capacity
650MB
Transport
Tray Loading
DVD-ROM Drive
Dimensions
235 g (0.518 lb)
Access Times
Random
  • <110 ms CD
  • <125 ms DVD
Full Stroke
  • <175 ms CD
  • <225 ms DVD
24X CD-ROM
3,600 KB/s
8X DVD
10,800 KB/s
Transfer Mode
Interface
EIDE
CD-DA, CD+(E)G, CD-MIDI, CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM
None
Media Capacity
4.7 GB
Transport
Tray Loading
DVD/CD-RW Drive
Dimensions
250 g (0.551 lb)
Access Times
Random
  • <110 ms CD
  • <130 ms DVD
Full Stroke
  • <210 ms CD
  • <225 ms DVD
24X CD-ROM
3,600 KB/s
8X DVD
10,800 KB/s
24X CD-R
3,600 KB/s
10X CD-RW
1,500 KB/s
Transfer Mode
Interface
EIDE
CD-R, CD-RW
Media Capacity
4.7 GB
Transport
Tray Loading
DVD+RW Drive
Dimensions
250 g (0.551 lb)
Access Times
Random
  • <175 ms CD
  • <230 ms DVD
Full Stroke
  • <285 ms CD
  • <335 ms DVD
24X CD-ROM
3,600 KB/s
8X DVD
10,800 KB/s
16X CD-R
2,400 KB/s
8X CD-RW
1,200 KB/s
2X DVD+R
2,700 KB/s
2X DVD+RW
2,700 KB/s
Transfer Mode
Interface
EIDE
CD-R, CD-RW,DVD+R,DVD+RW
Media Capacity
4.7 GB
Transport
Tray Loading
CD/RW Drive
Dimensions
235 g (0.518 lb)
Access Times
Random
<130 ms CD
Full Stroke
<200ms CD
24X CD-ROM
3,600 KB/s
24X CD-R
3,600 KB/s
10X CD-RW
1,500 KB/s
Transfer Mode
Interface
EIDE
Media Capacity
4.7 GB
Transport
Tray Loading
Wireless LAN
Feature
Specification
HP W400 802.11b/g WLAN
Wireless LAN Standards
  • IEEE 802. Part 11b (802.11b)
  • IEEE 802. Part 11g (802.11g)
Interoperability
Wi-Fi certified
Frequency Band
2.4 GHz
Data Rates
  • 802.11b: 1, 2, 5.5, 11 Mbps
  • 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
Modulation
  • Direct Sequence Spread Spectrum
  • DBPSK, DQPSK, CCK, OFDM
Security
  • 64- and 128-bit WEP encryption
  • Support for WiFi Protected Access (WPA) including TKIP, MIC
  • Hardware-accelerated support for the Advanced Encryption Standard (AES; 256-bit encryption)
  • Support for 802.1x authentication types: EAP-TLS, LEAP (Cisco), PEAP (Microsoft implementation)
  • Support for Cisco Security Features (proven compatibility with Cisco Aironet infrastructure products through the Cisco Compatible Extensions Program)
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations.
Media Access Protocol
CSMA/CA (Collision Avoidance) with ACK
  • Infrastructure (Access Point Required)
Roaming
IEEE 802.11 compliant roaming between 802.11b/g access points
Output Power
  • 802.11b: 17 dBM (typical)
  • 802.11g: 15 dBM (typical)
Power Consumption
Transmit
2.0 W (max)
Receive
1.5 W (max)
Sleep mode
20 mW (max)
Power Management
  • ACPI compliant power management
  • 802.11 Compliant Power Saving Mode
  • Power Saving Mode selectable through the configuration utility
Receiver Sensitivity
54 Mbps: -70 dBm to 1 Mbps: -90 dbm
Antenna type
High efficiency dual band antenna with polarization diversity, mounted in the display enclosure
Range
802.11 b - Typical
  • 1200 feet - Outdoor Open Area
  • 300 feet - Indoor, Office environment
802.11 g - Typical
  • 1000 feet - Outdoor Open Area
  • 200 feet - Indoor, Office environment
Form Factor
Form Factor
16 g (0.035 lb)
Dimensions
4.8 x 50.95 x 59.75 mm (0.19 x 2.00 x 2.35 in)
Operating Voltage
3.3v
Temperature
Operating
0° to 50° C (32° to 122° F)
Non-operating
-10° to 70° C (-14° to 158° F)
Humidity
Operating
10% to 90%
Non-operating
5% to 95%
Altitude
Operating
4,572 m (0 to 15,000 ft)
Non-operating
12,192 m (0 to 40,000 ft)
Configuration
  • Atheros Client Utility for Microsoft Windows 2000 or XP (required for Cisco Compatible Extensions support)
  • oft Windows XP Wireless Zero Configuration Utility
LED Activity
LED Off - Radio OFF; Solid LED - Radio ON
HP W500 802.11a/b/g WLAN
  • IEEE 802 Part 11a (802.11a)
Interoperability
Wi-Fi certified
Frequency Band
2.4 and 5 GHz
Data Rates
  • 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
Modulation
Security
  • Support for Cisco Security Features (proven compatibility with Cisco Aironet infrastructure products through the Cisco Compatible Extensions Program).
Sub-channels
Roaming
IEEE 802.11 compliant roaming between 802.11a and 802.11b/g access points
Output Power
Power Consumption
Transmit
2.0 W (max)
Receive
1.5 W (max)
Sleep mode
20 mW (max)
Power Management
Antenna type
Range
802.11a - Typical
  • 500 feet - Outdoors Open Area
  • 150 feet - Indoor, Office-environment
802.11 b - Typical
802.11 g - Typical
Form Factor
MiniPCI Type IIIA
16.5 g (0.036 lb)
Dimensions
Operating Voltage
3.3v
Temperature
Operating
0° to 70° C (32° to 158° F)
Non-operating
-40° to 80° C (-40° to 176° F)
Humidity
Operating
10% to 90%
Non-operating
5% to 95%
Altitude
Operating
0 to 10,000 ft (3,048 m)
Non-operating
0 to 50,000 ft (15,240 m)
  • Intel ProSet for Microsoft Windows 2000 or XP (required for Cisco Compatible Extensions support)
  • Microsoft Windows XP Wireless Zero Configuration Utility
LED Activity
