    Fix HP Printer issue on macOS
HP Compaq nx6115 and nx6125 Notebook PCs Product Specifications
Product description
The HP Compaq nx6115 and nx6125 Notebooks are a smart balance of mobility, affordability and long battery life for cost-conscious mobile professionals.
Product features
Feature
Processor
  • AMD Turion 64 Mobile Technology ML-40 (2.2-GHz, 1-MB L2 cache)
  • AMD Turion 64 Mobile Technology ML-37 (2.0-GHz, 1-MB L2 cache)
  • AMD Turion 64 Mobile Technology ML-34 (1.8-GHz, 1-MB L2 cache)
  • AMD Turion 64 Mobile Technology ML-32 (1.8-GHz, 512-KB L2 cache)
  • AMD Turion 64 Mobile Technology ML-30 (1.6-GHz, 1-MB L2 cache)
  • AMD Turion 64 Mobile Technology ML-28 (1.6-GHz, 512-KB L2 cache) Mobile
  • AMD Sempron processor 3100+ (1.8-GHz, 256-KB L2 cache) Mobile
  • AMD Sempron processor 3000+ (1.8-GHz, 128-KB L2 cache) Mobile
  • AMD Sempron processor 2800+ (1.6-GHz, 256-KB L2 cache)
Memory
  • Standard - 256-MB, 512-MB, or 1024-MB 333-MHz DDR SDRAM; two SODIMM slots
  • Maximum - Upgradeable to 2048-MB maximum (1024-MB SODIMM in slots 1 and 2)
ATI RADEON XPRESS 200M Chipset
Storage - Hard Drive(s)
  • 40-, 60-, or 80-GB 4200 rpm SMART
  • 40-, 60-, or 80-GB 5400 rpm SMART
Storage - Optical
Integrated (12.7-mm), one of the following:
  • CD-ROM
  • DVD-ROM
  • DVD/CD-RW Combo
  • DVD+/-RW
  • DVD+/-RW with Double Layer Technology
  • 15.0-inch TFT SXGA+ wide viewing angle (1400 x 1050 resolution and 16 M colors)
  • 15.0-inch TFT XGA (1024 x 768 resolution and 16 M colors)
Graphics
Integrated ATI MOBILITY RADEON X300 with up to 128-MB allocated system memory
Audio
  • Conexant AC '97 CODEC
  • Integrated 16-bit Sound Blaster Pro compatible audio
  • Integrated microphone
  • Integrated stereo speakers
  • Stereo headphone/line out
  • Stereo microphone in
  • External volume up, volume down, and mute buttons (nx6125 only)
Communications
  • NetXtreme Gigabit Ethernet Controller (10/100/1000 NIC)
  • 56K modem with digital line guard
Communications - Wireless (optional)
  • Broadcom 802.11b/g WLAN
  • Broadcom 802.11a/b/g WLAN
  • Integrated Bluetooth
Power
External 65-watt slim AC adapter, 6-foot (1.8-meter) power cord included. Total length including External AC adapter is 12 feet (3.66 meter).
Battery
  • 6-cell high capacity Lithium-Ion (52Wh)
  • 6-cell high capacity Lithium-Ion (42Wh) (on some nx6115 variants)
  • 8-cell high capacity Lithium-Ion (52Wh) (optional travel battery)
Battery Life
  • Primary Battery - Up to 3 hours 45 minutes
  • Primary Battery & optional HP Travel Battery - Up to 7 hours 30 minutes
Pointing Devices
Touchpad with scroll zone
Ports, Connectors & Slots
  • HP Compaq nx6115 Notebook PC
    • One Type I/II PC Card Slot (Supports 32-bit CardBus and 16-bit PC Cards)
    • One VGA External Monitor Connector
    • One IEEE 1394 Port
    • One External Microphone Port
    • One Headphone/Line out port
    • One Power Connector
    • One RJ-11 (Modem)
    • One RJ-45 (NIC)
    • Three USB 2.0 ports
    • One Travel Battery Connector
    • Ten LED Status Indicators
  • HP Compaq nx6125 Notebook PC
    • One Type I/II PC Card Slot (Supports 32-bit CardBus and 16-bit PC Cards) or Optional Integrated Smart Card Reader (Compatible with ISO 7816 compliant Smart Cards PC/SC interface support)
    • One ExpressCard/54 slot (Supports 34mm and 54mm ExpressCards)
    • One 6-in-1 Media Reader (Supports SD (Secure Digital), MMC (MultiMediaCard), Memory Stick, Memory Stick Pro, Smart Media, xD-Picture cards)
    • Biometric Fingerprint Reader
    • One RJ-11 (Modem)
    • One RJ-45 (NIC)
    • One S-Video TV Out port
    • Twleve LED Status Indicators
Dimensions
1.22 (at front) x 12.9 x 10.5 in (31 (at front) x 328 x 267 mm) (both units)
5.99 lb (2.72 kg) (both units)
Unit has a base warranty of 1 year pick-up/ carry-in labor and 1 year parts with no (0) onsite repair.
Physical specifications
This document provides physical and performance specifications.
Metric
U.S.
Dimensions
Height (front to back)
Width
Depth
N/A
1.3 to 1.5 in
13.0 in
10.75 in
HP Compaq nx6125 model with 15.0-inch display, optical drive, and 6-cell battery pack
HP Compaq nx6115 model with 15.0-inch display, optical drive, and 6-cell battery pack
N/A
6.3 lbs
6.0 lbs
Input Power
Operating voltage
Operating current
18.5 V dc @ 3.5 A - 65 W
3.5 A
N/A
Temperature
Operating (not writing to optical disc)
Operating (writing to optical disc)
Nonoperating
0°C to 35°C
5°C to 35°C
-20°C to 60°C
32°F to 95°F
41°F to 95°F
-4°F to 140°F
Relative humidity (noncondensing)
Operating
Nonoperating
10% to 90%
5% to 95%
10% to 90%
5% to 95%
Maximum altitude (unpressurized)
Operating (14.7 to 10.1 psia)
Nonoperating (14.7 to 4.4 psia)
-15 m to 3,048 m
-15 m to 12,192 m
-50 ft to 10,000 ft
-50 ft to 40,000 ft
Shock
Operating
Nonoperating
125 g, 2 ms, half-sine
200 g, 2 ms, half-sine
N/A
Random Vibration
Operating
Nonoperating
0.75 g zero-to-peak, 10 Hz to 500 Hz, 0.25 oct/min sweep rate
1.50 g zero-to-peak, 10 Hz to 500 Hz, 0.5 oct/min sweep rate
N/A
Applicable product safety standards specify thermal limits for plastic surfaces. The notebook operates well within this range of temperatures.
Software/OS
Feature
Operating System
  • Microsoft Windows XP Professional SP2
  • Microsoft Windows XP Home Edition SP2 (select countries only)
  • FreeDOS
Preloaded Software
  • Adobe Acrobat Reader
  • HP Local Recovery provided by Altiris
  • HP One-Touch Button Software
  • HP Mobile Print Driver
  • Synaptics Touchpad Driver
  • HP Help and Support
  • HP ProtectTools Security Manager:
    • BIOS Configuration for HP ProtectTools
    • Credential Manager for HP ProtectTools
  • HP Wireless Assistant
  • Sonic RecordNow! (for optional DVD+/-RW and DVD/CDRW drives)
  • Symantec Norton Antivirus with complimentary 60-day live update
  • Intervideo WinDVD - DVD Player (for optional DVD+/-RW, DVD/CDRW and DVD drives)
Software Included on CD
Intervideo WinDVD Creator – DVD Authoring (for optional DVD+/-RW drives)
Additional Software available on the Web
  • Smart Card Security for HP ProtectTools
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
