    Fix Windows 10 Update Issues
HP Designjet 4000 Printer Series - HP Jetdirect Embedded Print Server
This printer contains an HP Jetdirect embedded print server that is integrated directly into the printer. Using this print server, you can connect the printer directly to a network and share it among multiple users or systems. Because the print server is built into the device, an input/output (I/O) slot or external port is not needed for network connectivity and may be used for other purposes.
Network Connection
Using the embedded print server and built-in RJ-45 connector, the printer can connect to an IEEE 802.3 10/100Base-TX (Ethernet/Fast Ethernet) network through unshielded twisted-pair network cables.
Autonegotiation (10/100Base-TX) is used to configure link operation automatically at 10 Mbps or 100 Mbps, and full- or half-duplex communication mode, as required by the network. However, link operation may be manually set using several configuration tools, such as the printer control panel (if supported), Telnet commands, a Web browser, and network management software. These tools are described later in this guide.
Unless otherwise specified, the term print server in this manual refers to an HP Jetdirect print server and not a separate computer running print server software.
Identification
Firmware Version
The print server can be upgraded with new firmware versions when released. New versions may provide enhanced features and capabilities. The HP Jetdirect embedded print server firmware is integrated with the HP Designjet 4000/4000ps printer firmware. The features and capabilities described in this guide support the following HP Designjet 4000/4000ps printer firmware version:
  • Firmware version: A.01.01
Supported Network Protocols
The supported network protocols, and popular network printing environments that use those protocols, are listed in the table below.
Network Printing Environments1
TCP/IP
Microsoft Windows 98/Me/NT4.0/2000/XP (32- and 64-bit)
Direct Mode printing
UNIX and Linux, including:
  • Hewlett-Packard HP-UX, Sun Microsystems Solaris (SPARCsystems only), IBM AIX2, HP MPE-iX2, RedHat Linux, SuSE Linux
LPR/LPD (Line Printer Daemon)2
FTP (File Transfer Protocol)
1 Refer to the current HP Jetdirect product data sheets for additional network systems and versions. For operation with other network environments, consult your system vendor or authorized HP dealer.
2 For these network systems, contact your network system vendor for software, documentation, and support.
