HP Compaq Business Desktop dc7600 Convertible Minitower Specifications
Product Description
The HP Compaq dc7600 Business PC is the follow-up to the HP Compaq dc7100 Business PC. HP Compaq Business PCs are designed to provide a consistent and stable platform for commercial customers.
Product Features
Feature
Pentium Processors
  • Intel P4 521 (2.8/800/1M) processor with EM64T
  • Intel P4 531 (3.0/800/1M) processor with EM64T
  • Intel P4 541 (3.2/800/1M) processor with EM64T
  • Intel P4 630 (3.0/800/2M) processor with HyperThreading
  • Intel P4 640 (3.2/800/2M) processor with HyperThreading
  • Intel P4 650 (3.4/800/2M) processor with HyperThreading
  • Intel PD 820 (2.8x2/800/2xMB L2 Cache) Dual Core Processor (not available on the USDT)
  • Intel PD 830 (3.0 Ghz clock speed, 800 MHz FSB, 2x1M L2 cache)
  • Intel PD 840 (3.2 Ghz clock speed, 800 MHz FSB, 2x1M L2 cache
  • Intel Pentium 4 660 (3.6/800/2M) processor with HyperThreading
  • Intel Pentium 4 670 (3.8/800/2M) processor with HyperThreading
Celeron Processors
  • Intel Celeron D Processor 331
  • Intel Celeron D Processor 336
CPU Bus Speed Supported
533 MHz, 800 MHz (Processors with a 1 GHz FSB are not currently offered on these models)
Standard L2 Cache
2 MB, 1 MB or 256K depending on processor
Intel 945G Express
Memory Expansion Slots
4 DIMMs
Memory Type Supported
Non-ECC DDR Synchronous Dram (ECC not supported by Chipset)
Memory Speed
  • DDR2 Synch DRAM PC2-4200 (533 MHz) non-ECC memory
  • DDR2 Synch DRAM PC2-5300 (667 MHz) non-ECC memory
Maximum Memory
4 GB
Network Controller
Integrated Broadcom NetXtreme Gigabit Ethernet for HP
Graphics
  • Integrated Intel Graphics Media Accelerator 900
  • NVIDIA Quadro NVS 285 128 MB TC PCIe
Audio
  • Integrated High Definition audio with Realtek 2 channel ALC260 codec
  • Microphone and headphone front ports
  • Aux input connection on system board
  • Line-out and line-in rear ports on SFF/USDT
  • Line-out, line-in and microphone rear ports on CMT
  • All ports are stereo
  • Internal speaker
Rear audio ports are re-assignable as line-in, line-out, or microphone-in, with an optional driver, which is available by download from the HP support website only.
PCI Slots
  • 2 full-height (4.2 inches), length (13.4 inches) standard
  • 2 additional slots available via optional extender card
PCI Express x16 slot
1 full-height (4.2 inches), length (10.5 inches)
PCI Express x1 slot
1 full-height (4.2 inches), length (13.4 inches)
AGP
none
External Bays
  • 4 bays (2 - 5.25 inch, length 8.189 inches)
  • 1 - 5.25 inch length (5.71 inches)
  • 1 - 3.5 inch
Internal Bays
2 - 3.5 inches hard drive bays
MultiBay
none
IDE
1 IDE connector for optical drives
Serial - ATA
4 serial ATA connectors for SATA hard drives
USB 2.0
8 (2 front, 6 rear)
Serial
1 standard with 2nd optional
Parallel
1 standard
PS/2
1 keyboard, 1 mouse
DVI output
Available via ADD2 card, PCI-E x16 card, and PCI card
Video
Analog for integrated graphics
Support for Multi-Monitor
Audio
  • Front - microphone and headphone
  • Rear - line in, line out, mic in
Power Supply
365W active PFC
Hard Drive Interfaces Supported
2 Serial ATA interfaces
Hard Drive Controller (PCI) Supported
Serial ATA
System Specifications
Specification
Chassis dimension - inches
17.65 inches x 6.6 inches x 17.8 inches
Chassis dimensions - centimeters
744.83 cm x 16.76 cm x 45.21
32.5 pounds
Volume
33.8 liters
Shipping weight
43 pounds
Power supply
365 watt custom power supply - Active PFC
Operating voltage range
90 - 264 VAC
Rated voltage range
100 - 240 VAC
Rated voltage range
50/60 Hz
Operating line frequency range
47 - 63 Hz
Rated input current
6A
Heat dissipation
Typical 375 btu/hr (95 kg-cal/hr)
Maximum 1916 btu/hr (483 kg-cal/hr)
Power supply fan
92mm variable speed
Energy Star Compliant
yes
Blue Angel Compliant (less than 5w in S5 - Power Off)
yes
Power consumption in ES Mode - Suspend to RAM (S3) (Instantly Available PC)
3 Watts
Front Components
  1. Optical drive
  2. Optical drive activity light
  3. Diskette drive (optional)
  4. Diskette drive activity light
  5. Hard drive activity light
  6. Optical drive eject button
  7. Diskette drive eject button
  8. Power button
  9. Power-on light
  10. USB ports
  11. Headphone connector
  12. Microphone connector
Rear Connectors
  1. Power cord connector
  2. PS/2 keyboard connector
  3. Monitor connector
  4. Serial connector
  5. USB port
  6. Microphone connector
  7. Headphone/Line-out
  8. PS/2 mouse connector
  9. Parallel connector
  10. Line-In audio connector
  11. RJ-45 network connector
Chipset Specifications
The HP Compaq dc7600 Business PC uses the Intel 945G Express chipset, which features:
  • An 800 MHz front side bus.
  • Support for several classes of Intel processors:
    • Intel Pentium 4 650, 640, and 630 processors with Intel HyperThreading Technology
    • Intel Pentium 4 541, 531, and 521 processors with Intel Extended Memory 64 Technology (EM64T) for 64 bit addressability
    • Intel PD 820 dual core processor (not available on the USDT)
    • Intel Celeron D 331 and 336 processors
  • Graphics Media Accelerator 950 with support for dual video monitors.
  • Broadcom NetXtreme® BCM5752 Gigabit Ethernet controller.
  • Dual-channel DDR2 667 memory.
  • Support for up to four Serial ATA devices (depending on model).
  • Eight high-speed USB 2.0 ports.
  • An enhanced audio architecture featuring Intel High Definition Audio (Azalia).
Communication Specifications
Connector
RJ-45
Controller
Broadcom 5751 PCI Express LAN Controller
Memory
Integrated 96Kb frame buffer memory
Data rates supported
10/100/1000 Mbps
Compliance
IEEE 802.1P, 802.1 Q, 802.2, 802.3, 802.3AB and 802.3v compliant 802.3x flow control
Bus architecture
PCI-E
Data path width
Single channel, PCI-E
Data transfer mode
Bus master DMA
Hardware certifications
FC, B, CE, TUV - cTUVus Mark Canada and United States, TUV-GS Mark for European Union
Power requirement
3.1 watts at +3.3V AUX supply with 5V tolerance
Boot ROM support
Yes
Network transfer rate
  • 10BASE-T (half-duplex) 10 Mbps
  • 10BASE-T (full-duplex) 20 Mbps
  • 100BASE-TX (half-duplex) 100 Mbps
  • 100BASE-TX (full-duplex) 200 Mbps
  • 1000BASE-T (full-duplex) 2000 Mbps
Environmental
Operating temperature: 0 degree to 55 degree C (32 degree to 131 degree F)
Operating humidity: 55 degree C (85 percent at 131 degrees F)
Operating system driver support
MS Windows NT 4.0
MS Windows 98
MS Windows 2000
MS Windows XP
Management capabilities
ACPI, WOL and DMI 2.0, PXE 2.0, WfM 2.0, Broadcom mgmt utility
Alerting
N/A
Intel Pro 1000 MT Gigabit NIC
Connector
RJ-45
Controller
Intel 82540EM Gigabit Controller
Memory
10/100/1000 Mbps
Compliance
Bus architecture
PCI 2.2
Data path width
32-bit, 33/66 MHz bus interface
Data transfer mode
Bus master DMA
FCC, B, CE, TUV - cTUVus Mark Canada and United States, TUV-GS Mark for European Union
Power requirement
1.48 watts at +3.3V AUX supply with 5V tolerance
Boot ROM support
Yes
Environmental
MS Windows NT 4.0
MS Windows 98
MS Windows 2000
MS Windows XP
ACPI, WOL and DMI 2.0, PXE 2.0, WfM 2.0, Intel PROset II utility
Agere 56K PCI SoftModem
Data Transmission
Technology speeds: 56,000 Kbps maximum downstream data, controllerless
56 Kbps technology refers to download speeds only and requires compatible modems at server sites. Other conditions may limit modem speed. FCC limitations allow a maximum of 53 Kbps during download transmissions
Data speeds
(Upload only) 33,600/31,200/28,800/26,400/21,600/19,200/16,800/14,400/12,000/ 9,600/7,200/4,800/2,400/1,200/300
Data standards
ITU-T V.90, ITU-T, ITU-T V.34, V.44, V.42, V.42bis21, V.32bis, Bell 212A, and Bell 103
Fax Speeds
14,400/12,000/9,600/7,200/4,800/2,400/1,200/300 b/s
Fax Mode Capabilities
ITU-T T.31 class 1 FAX, V. 17, V.29, V.27ter, and V.21 Channel 2
Error Correction and Data Compression
V.44, 42bis, V.42 and MNP2-5
Power Management
ACPI; PPMI 1.1 and wake support with PME and Vaux; meets PCI 2.3 requirements and PC 2001 requirements
Upgradeability
Driver upgradeable for future enhancements
Video
ITU-T V.80 video ready interface
Other
TIA/EIA 602 standard AT command set
Integrated DTE interface with speeds of up to 115.2 Kbps, parallel 16550a UART-compatible interface
Optional ring wakeup signal
Operating Temperature
0 degree to 70 degrees C (32 degrees to 158 degrees F)
Operating Humidity
20 percent to 90 percent, non-condensing
Operating Systems Support
Microsoft® Windows® 2000 and Microsoft Windows XP
OS Driver Support
Microsoft Windows 2000 and Microsoft Windows XP
Power
Requires a 3.3-V auxiliary power rail on PCI bus
Uses only one PCI load (i.e., one grant/request pair), one shared IRQ, one electrical load
Graphics Specifications
Integrated Graphics Media Accelerator 950
3D/2D Controller
Microsoft® DirectX® 9 based with support for Pixel Shader 2.0, 4:1 anisotropic filtering, Gaussian texture filtering, shadow maps, volumetric textures, double-sided stencil buffers, and 4 pixel pipes.
VGA Controller
Integrated
Bus Type
PCI Express™ x16 (Internal graphics is automatically disabled if an external PCIE or PCI graphics card is installed. If the external graphics card is installed in a PCI slot, the internal graphics can be re-enabled using the system's BIOS setup utility. If the external graphics card is installed in the PCI Express™ slot, the internal graphics cannot be enabled).
RAMDAC
Integrated, 400 MHz
Memory
Graphics memory is shared with system memory. Graphics memory usage can vary from 8-128 MB depending on the amount of system memory installed and system load. 8 MB is pre-allocated for graphics use at system boot time. Additional memory is allocated for graphics using Intel's Dynamic Video Memory Technology (DVMT) to balance the optimum amount of memory between graphics and other system use Memory less than 256 MB: 8 MB pre-allocated (for DOS) + 24 MB DVMT: max frame buffer of 32 MB
256 MB less than or equal to Memory: 8 MB pre-allocated + 120 MB DVMT: Max frame buffer of 128 MB
Controller Clock Speed
400 MHz
Overlay Planes
Single overlay support with 5x3 filtering
Maximum Color Depth
32 bits/pixel
Maximum Vertical Refresh Rate
85 Hz at up to 1920x1440, 85Hz at 2048x1536. Varies with mode and configuration. See table below
Multi-display Support
Support for one CRT via the motherboard's VGA connector. Support for an additional DVI-D display via the optional DVI ADD2 card. Dual independent displays and dual synchronous (Twin or Clone mode) displays are supported.
Operating Systems
MS Windows XP and Windows 2000
Graphics/Video API Support
Microsoft DirectX®9, DirectXVA®, VMR9, GDI/GDI+; OpenGL® 1.4.
Resolution
Maximum Refresh Rate (Hz)
Analog Monitor
Digital Monitor
640 x 480
85
60
800 x 600
85
60
1024 x 768
85
60
1280 x 1024
85
60
1600 x 1200
85
60
1920 x 1080
85
60
1920 x 1200
85
60
1920 x 1440
85
60
2048 x 1536
85
60
1 Modes listed are supported with a single active display. The supported mode list for multiple active displays a subset of this list. Not all modes will support video playback and some supported modes may use software MC (motion compensation) rather than hardware MC. Not all modes will support 3D acceleration depending on the system configuration (e.g., resolution selected, size of frame buffer, number of installed memory modules, etc.).
Other resolutions and refresh rates may be selectable but are not recommended.
DVI ADD2 Graphics
Models
DY674A Intel DVI ADD2 adapter for Convertible Minitower and Small Form Factor
Form factor
Low-profile card (normal layout for Convertible Minitower; reverse layout for Small Form Factor)
DVI-D Connector
Compliant with DDWG (Digital Display Working Group) and VESA specifications for a single-link digital DVI (DVI-D) connector.
Dual Head Support
Yes, when used with the integrated VGA connector
Display Devices Supported
HP L1530
HP L1740
HP L1755
HP L1940
HP L1955
HP L2035
HP L2335
The DVI ADD2 card offers optimal performance with any display that meets applicable VESA standards
Color Depth
All modes support 8-bpp, 16-bpp, and 24-bpp color depths (up to 16.7 million colors
Host Interface Connector
Mechanically compliant with PCI-E standard Complies with the Intel ADD2 and Intel Serial Digital Video Output (SDVO) specifications
Dot Clock
165 MHz maximum
Display Modes
Supports display modes that require up to 165 MHz bandwidth on the link, as shown in the following table:
Resolution
60 Hz LCD
60 Hz
75 Hz
85 Hz
Blanking
5 percent reduced
GTF
GTF
GTF
640 x 480 VGA
Yes
Yes
Yes
Yes
800 x 600 SVGA
Yes
Yes
Yes
Yes
1024 x 768 XGA
Yes
Yes
Yes
Yes
1280 x 1024 SXGA
Yes
Yes
No
No
1600 x 1200 UXGA
Yes
Yes
No
No
ATI RADEON X300 SE PCI Express Graphics
Models
ATI RADEON X300 SE PCI Express 128-MB DDR single head DVI with TV out
Bus Type
PCI Express (x16 lanes)
85 Hz
Display Support
Integrated 400 MHz RAMDAC
Display Max Resolution
2048 x 1536
Board Display Options
128 MB Card Display Option
DVI-I + TV
DVI-I supports analog CRT or flat panel or digital flat panel (using DVI-A, DVI-D or DVI-I connector)
DVI-I supports analog CRT or flat panel (with VGA connector and DVI-I to VGA dongle)
TV Connector is a 7-pin mini-DIN (also allowing 4-pin S-Video without adapter)
Board Configuration - 128 MB Frame Buffer
Specification
Graphics Chips
Core clock
Memory clock
Frame buffer
Memory I/O
Memory Configuration
200 MHz
200 MHz
128 MB DDR
64 bit
4 pcs 16M x 16 DDR
Memory type
DDR1
Maximum memory
128MB
Operating systems support
Windows 2000, Windows XP
Core Power
10 W (Max ASIC power)
18 W (Max Board power)
Option Kit Contents
ATI RADEON X300 SE PCI Express graphics card with full height bracket attached
Low profile bracket
Software CD with graphics drivers
Warranty documentation
NVIDIA Quadro NVS 280 64MB PCI Dual Head
Form Factor
Low profile (both ATX and low profile brackets included)
Graphic Controller
Integrated Quadro 280 2-D graphics processor unit (GPU)
Bus type
PCI
RAMDAC
Dual 350 MHz integrated
Memory
64 MB DDR with frame buffer and Texture storage
Connector
Single High-density DMS 59 Connector
Dimensions
Low-profile, 6.57 x 16.76 cm (2.586 x 6.6 inches) (
Controller clock speed
250 MHz
Color depth
32-bits/pixel max
Overlay planes
1 16-bit Video overlay plane
Maximum vertical refresh rate
85 Hz
Multi-monitor support
Dual analog or digital monitors
Dual DVI Support
Yes (with kit DL139A)
High-definition Video Processor (HDVP)
Full-screen, full-frame video playback of HDTV and DVD content DVD-ready motion compensation for MPEG-2
Independent hardware color controls for video overlay
Hardware color-space conversion (YUV 4:2:2 and 4:2:0)
IDCT motion compensation
5-tap horizontal by 3-tap vertical filtering
8:1 up/down scaling
Available graphics drivers
Microsoft Windows 2000 and Microsoft Windows XP (Provides full native Dual View mode, Span or Big Desktop mode, and Clone mode)
HP qualified drivers may be preloaded or available from the HP support Web site: http://welcome.hp.com/country/us/eng/software_drivers.html
Analog Resolution
Maximum Colors Supported
640 x 480
16.7 M
240 Hz
800 x 600
16.7 M
240 Hz
1024 x 768
16.7 M
200 Hz
1600 x 1200
16.7 M
170 Hz
1600 x 1200
16.7 M
150 Hz
1600 x 1200
16.7 M
100 Hz
1600 x 1200
16.7 M
85 Hz
1600 x 1200
16.7 M
85 Hz
1920 x 1440
16.7 M
75 Hz
2048 x 1536
16.7 M
60 Hz
640 x 480
16.7 M
75 Hz
800 x 600
16.7 M
75 Hz
1024 x 768
16.7 M
75 Hz
1152 x 864
16.7 M
60 Hz
1280 x 1024
16.7 M
60 Hz
1600 x 1200
16.7 M
60 Hz (primary only)
NVIDIA Quadro NVS 50 64 MB PCI DVI with TV Out
Form factor
Low profile, both ATX and low profile brackets included
Graphic Controller
Integrated Quadro 50 Graphics Processor Unit (GPU)
Bus type
PCI 2.1, 32-bit, 5V
Memory
64 MB DDR
Connectors
Single DVI-I connector
Single S-Video connector
Dimensions
Low profile, 6.57 x 16.76 cm (2.586 x 6.6 inches)
250 MHz
Memory speed
200 MHz
Color depth
32 bits/pixel max
Overlay planes
One 16 bit video overlay plane
85 Hz
Maximum pixel clock
Analog output: 350 MHz
Digital output: 162 MHz
Single DVI Support
Yes
TV out support
Yes (S-Video 4 pin mini-DIN)
High definition Video Processor
Full screen, full frame video playback of HDTV and DVD content
Hardware colorspace conversion (YUV 4:2:2 and 4:2:0)
Up to 5-tap horizontal by 3-tap vertical filtering
Digital Resolution
Analog Resolution
640 x 480
32 M
85 Hz
800 x 600
32 M
85 Hz
1024 x 768
32 M
85 Hz
1280 x 1024
32 M
85 Hz
1600 x 1024
32 M
85 Hz
1600 x 1200
32 M
85 Hz
1920 x 1080
32 M
85 Hz
1920 x 1200
32 M
85 Hz
1920 x 1440
32 M
75 Hz
2048 x 1536
16.7 M
75 Hz
Digital Resolution
640 x 480
32 M
60 Hz
800 x 600
32 M
60 Hz
1024 x 768
32 M
60 Hz
1280 x 1024
32 M
60 Hz
1600 x 1200
32 M
60 Hz
TV Output Resolution
640 x 480
32 M
60 Hz
800 x 600
32 M
60 Hz
1024 x 768
32 M
60 Hz
Hard Drives Specifications
7200 rpm Serial ATA Hard Drives
160 GB
Capacity
163,928,604,672 bytes
Height
2.54 cm (1 inch)
Width
Media diameter: 8.89 cm (3.5 inches)
Physical size: 10.2 cm (4 inches)
Interface
Serial ATA (3.0 Gb/S)
Synchronous Transfer Rate (maximum)
Up to 3 Gb/s
Buffer
8 MB
Seek Time (typical reads, includes controller overhead, including settling)
Single Track - 0.9 ms
Average - 9.3 ms
Full-Stroke - 21 ms
Rotational Speed
7,200 rpm
Logical Blocks
320,173,056
5 degrees to 55 degrees C (41 degrees to 131 degrees F)
80 GB
Capacity
80,026,361,856 bytes
Height
2.54 cm (1 inch)
Width
Interface
Up to 3 GB/s
Buffer
8 MB
Seek Time
Single Track - 2.0 ms
Average - 9.3 ms
Full-Stroke - 18 ms
Rotational Speed
7,200 rpm
Logical Blocks
156,301,488
0 degrees to 60 degrees C (32 degrees to 140 degrees F)
40 GB
Capacity
40,020,000,000 bytes
Height
2.54 cm (1 inch)
Width
Interface
Serial ATA
Synchronous Transfer Rate (Maximum)
1.5 Gb/s
Buffer
2 MB
Seek Time (typical reads, includes controller overhead including settling)
Single Track - 1.0 ms
Average - 8.5 ms
Full-Stroke - 18.0 ms
Rotational Speed
7,200 rpm
Logical Blocks
78,165,360
0° to 60° C (32 degrees to 140 degrees F)
Optical Storage Specifications
16X DVD+/ RW LightScribe Drive (Double Layer Dual Format)
Height
5.25 inch, half-height, tray-load
Orientation
Either horizontal or vertical
Interface type
ATAPI/EIDE
Disc recording capacity
8.5 GB DL or 4.7 GB standard
Dimensions (W x H x D)
15.0 x 4.4 x 20.3 cm (5.9 x 1.7 x 8.0 inches)
Weight (maximum)
1.2 kg (2.6 pounds)
Write speed
  • DVD+R - up to 16X
  • DVD+RW - Up to 4X
  • DVD+R DL - up to 2.4X
  • DVD-R - up to 8X
  • DVD-RW - up to 4X
  • CD-R - up to 40X
  • CD-RW - up to 24X
Read speed
DVD+R/-R/+RW/-RW/+R DL - up to 6X
DVD-ROM - up to 16X
CD-ROM, CD-R - up to 40X
CD-RW - up to 32X
Access time (typical reads, including settling)
Random
DVD: less than 130 ms (typical), CD: less than 120 ms (typical)
Full Stroke
DVD: less than 240 ms (seek), CD: less than 200 ms (seek)
Startup Time
Single-session: less than 15 seconds (typical), Multi-session: less than 30 seconds (typical)
Stop Time
less than 4 seconds
Cache Buffer
2 MB (minimum)
Data Transfer Modes
ATA PIO mode 4 (16.7 MB/s); ATA Multi-word DMA mode 2 (16.7 MB/s); ATA UltraDMA Mode 3 (44.4 MB/s -default
Power
Source
Four-pin, DC power receptacle
DC Power Requirements
5 VDC plus or minu 5 percent-100 mV ripple p-p
12 VDC plus or minus 5 percent -200 mV ripple p-p
DC Current
5 VDC (less than 1000 mA typical, 1600 mA maximum)
12 VDC (less than 600 mA typical, 1400 mA maximum)
Total Drive Power
less than 2.5 Watts
Audio output
Line-Out
0.7 VRMS
Signal-to-Noise Ration
74 dB
Channel Separation
65 dB
Environmental Conditions (operating - non-condensing)
Temperature
5 degrees to 50 degrees C (41 degrees to 122 degrees F)
Relative humidity
10 percent to 90 percent
Maximum wet bulb temperature
30 degrees C (86 degrees F)
System Configuration
Intel Pentium III Processor or later with 128 MB of memory (required); 256 MB recommended 2-D or 3-D graphics cards on primary disk drive for operating system and application software; second disk drive for audio and video data
Operating System support
Microsoft Windows 2000, Windows XP Professional, Windows XP Home
Regulatory approvals
MPC-3 compliant, multi-read requirements, ATA Spec X3T9.2, ATAPI Spec T13.1153D, ANSI C63.4-1992, UL 1950, ACA AS/NZS 3548, CB Bulletin No. 96A, CSA C22.2 No. 950-1995, CFR 47 C.I.S.P.R. Pub 22 Class B, DHHS/FDA, EMKO-TSE 07/94, TUV EN60950, EN60825-1, MIC, BSMI-CNS 13438, CE, Microsoft PC2001 certification, Microsoft Logo for Windows XP and 2000
Option kit contents
16X DVD+/-RW LightScribe drive, LightScribe software, InterVideo WinDVD, InterVideo WinDVD Creator, Roxio Easy Media Creator 7, Dantz Retrospect Express Backup Software, installation guide, and DVD+R media
16X/48X DVD-ROM Drive
Height
Interface Type
ATAPI
Dimensions - External, excluding Bezel
149.5 x 43.5 mm (5.88 x 1.71 inches)
Disc Diameter
12 cm, 6 cm
Disc Thickness
1.2 mm
Track Pitch
1.6 µm (CD), 0.74 µm (DVD
Disc Center Hole Diameter
15 mm
Disc formats
DVD-ROM (single and dual layer); DVD-video; DVD-R version 1.0 and 2.0; DVD-RW version 1.0 and 1.1; DVD-R multi-border; DVD+RW; DVD+R, DVD+R DL ; CD-ROM Mode 1 and 2; CD-DA; CD-ROM XA Mode 2, Form 1 and 2; CD-extra; CD-text; CD-I Mode 2, Form 1 and 2; CD-I ready; video CD, CD-bridge; PhotoCD (single and multi-session); CD-R; CD-RW
Disc Capacity
DVD-ROM: 4.7 GB (DVD-5), 8.54 GB (DVD-9), 9.4 GB (DVD-10), 3.95 GB (DVD-R version 1.0), 4.7 GB (DVD-R version 2.0), 4.7 GB (DVD-RW version 1.0 and 1.1), 4.7 GB (DVD+RW), 4.7G (DVD+R), 8.5 GB (DVD+R DL)
CD-ROM: 540 MB (Mode 1, 12 cm), 640 MB (Mode 2, 12 cm), 700 MB (80 minimum CD-R and CD-RW), 180 MB (8 cm
Block Size (bytes)
DVD-ROM - 2048; CD-ROM Mode 0 - 2352; CD-ROM Mode 1 - 2352, 2340, 2336, 2048; CD-ROM Mode 2 - 2352, 2340, 2336, 2048
Access Times (typical reads, including settling)
DVD-ROM Single Layer: 120 ms (typically)
CD-ROM Mode 1: 90 ms (typically)
Full Stroke DVD: 240 ms (seek) (typically)
Full Stroke CD: 160 ms (seek) (typically)
Maximum Data
CD-ROM Read: 7200 KB/s (up to 48X)
DVD-ROM Read: 21,600 KB/s (16X) Max
Data Transfer Modes
PIO Mode 4 (16.6 MB/s); Multi-word DMA mode 2 (16.6 MB/s); UltraDMA Mode 3 (44.4 MB/s)
Power
Source: Four-pin, DC power receptacle
DC Power Requirements:
  • 5 VDC plus or minus 5 percent - 100 mV ripple p-p
  • 12 VDC plus or minus 5 percent - 200 mV ripple p-p
DC Current
5 VDC - less than 800 mA typical, less than 1000 mA maximum
12 VDC - less than 870 mA typical
Audio Output Level
0.7 Vrms (typical)
Configuration Jumper Block
Master, slave, and cable select modes
Data Interface Connector
40-pin, shrouded and keyed, flat ribbon
Environmental (all conditions non-condensing)
Temperature (operating): 5 degrees to 50 degrees C (41 degrees to 122 degrees F)
Relative Humidity (operating): 10 percent to 65 percent
Maximum Wet Bulb Temperature (operating): 30 degrees C (86 degrees F)
Certifications, Approvals
MMC II support, multi-read certification, Microsoft WHQL certification, ACA AS/NZS 3548 class B, CNS 13438, C.I.S.P.R. Pub 22, TUV or VDE EN60950, EN 55022, EN55024, SEMKO, NEMKO, DEMKO, FIMKO, EN 60825-1, UL 60950, and CSA C22.2 60950-2000.
Operating Systems supported
48X/32X Combo CD-RW/DVD-ROM Drive
Orientation
Interface Type
ATAPI IDE
14.66 x 4.34 x 18.69 cm (5.77 x 1.71 x 7.36 inches) external, excluding bezel
Disc Loading Mechanism
Half-height, tray load
Disc Diameter
12 cm, 8 cm
Disc Thickness
1.2 mm (0.05 inch)
Track Pitch
15 mm (0.6 inch)
Reference Scanning Velocity
1.2 m/s (CD); 3.49 m/s (DVD SL); 3.84 m/s (DVD DL)
Read Only Disc formats
CD-ROM-Mode 1; CD-ROM XA-Mode 2; CD-Bridge; CD digital audio; CD Extra; Photo CD (single and multi-session); video CD; DVD (single- and double-layer); DVD-R; DVD-RW; DVD-RW Multi-Border; DVD+R; DVD+R Multi-Session , and DVD+RW
Disc Capacity
8 cm (180 MB) ; 12 cm (540 MB); 12 cm (650 MB); 12 cm (700 MB); 4.7 GB (DVD-5); 8.54 GB (DVD-9); 9.4 GB (DVD-10)
Block Size (bytes)
Mode 1-2,048 and 2,352 bytes; mode 2, form 1-2,048; 2,328; 2,336; 2,340 and 2,352 bytes; mode 2, form 2-2,328; 2,336; 2,340 and 2,352 bytes; CD-DA-2,352 bytes; DVD-2,048 bytes
Writable Disc Parameters
Disc Type
CD-R and CD-RW
Write Methods
Disc at Once, Track at Once, Session at Once, Variable Packet, Fixed Packet
Format and Modes Supported
CD-ROM; CD-ROM XA; CD digital audio, video CD; CD-Bridge
Capacity
8 cm (180 MB) ; 12 cm (540 MB) ; 12 cm (650 MB); 12 cm (700 MB)
Block Size
CD-DA-2,352 bytes; mode 0- 2,336 and 2,352 bytes; mode 1-2,048 and 2,352 bytes; mode 2-2,336 and 2,352; mode 2, form 1-2,048 and 2,352 bytes; mode 2, form 2-2,324 and 2,352 bytes
Access Times (typical)
Random DVD: less than 140 ms (typically)
Random CD: less than 125 ms (typically)
Full Stroke DVD: 250 ms (seek)
Full Stroke CD: less than 210 ms (seek)
Data Transfer Rates
CD-R write: 7200 KB/s (48X) Max
CD-RW write: 4800 KB/s (32X) Max
CD-ROM, CD-R, CD-RW read: 7200 KB/s (32X) Max
DVD ROM read: 21,632 KB/s (16X) Max
Data Transfer Modes
ATA PIO mode 4); ATA Multi-word DMA mode 2; ATA UltraDMA mode 0; ATA UltraDMA mode 1, mode 2; ATA UltraDMA Mode 3 (default)
Power
Cache Buffer
2 MB (minimum)
Start-up Time (single)
less than 7 seconds typical
Start-up Time (multi-session)
less than 30 seconds typical
Stop Time
less than 4 seconds
Power DC Current
5 VDC - less than 1A typical, less than 1600 mA maximum
12 VDC - less than 600 mA typical, less than 1.4A maximum
Total Drive Power (Standby mode) - less than 2.5 watt
Power Source
Audio Output Level
0.7 Vrms (typical)
Master, slave, and cable select (default) modes
Relative Humidity (operating): 10 percent to 90 percent
MPC-3 compliant, multi-read requirements, ACA AS/NZS 3548, ANSI C63.4-1992, ATAPI Spec SFF-8020, ATA Spec X3T9.2, CB Bulletin No. 92A, CSA C22.2 No. 950-1995, C.I.S.P.R. Pub 22, EMKO-TSE 207/94, TUV or VDE EN60 950, EN60825-1, Microsoft ®PC2001 certification, Microsoft Logo for Windows® XP, 2000
48X/32X/48X CD-RW Drive
Orientation
Interface Type
ATAPI IDE
203 x 149.5 x 43.5 mm (7.99 x 5.88 x 1.71 inches) external, excluding bezel
1.2 kg (2.6 pounds)
Disc Diameter
12 cm, 8 cm
Disc Thickness
1.2 mm (0.05 inch)
Track Pitch
15 mm (0.6 inch)
1.2 m/s
Recording/Playing Time
80 minutes with CD-R media
CD-ROM-Mode 1; CD-ROMCD-ROM-Mode 1; CD-ROM XA-Mode 2 (forms 1 and 2); CD digital audio; CD Extra; CD-I-Mode 2 (forms 1 and 2) and CD-I-Ready; Photo CD (single and multi-session); video CD
Disc Capacity
185 MB (Mode 2, 8cm); 540 MB (Mode 1, 12 cm); 650 MB (Mode 2, 12 cm); 700 MB (Mode 2, 12 cm
Block Size (bytes)
Mode 1-2,048 and 2,352 bytes; mode 2, form 1-2,048; 2,328; 2,336; 2,340 and 2,352 bytes; mode 2, form 2-2,328; 2,336; 2,340 and 2,352 bytes; CD-DA-2,352 and 2,368 bytes
Disc Type
CD-R and CD-RW
Write Methods
CD-ROM (mode 1); CD-ROM XA (mode 2, forms 1 and 2); CD digital audio, CD-I (mode 2, forms 1 and 2); video CD
Capacity
185 MB (Mode 2, 8cm); 540 MB (Mode 1, 12 cm); 650 MB (Mode 2, 12 cm); 700 MB (Mode 2, 12 cm)
Block Size
Mode 1 - 2,048 bytes; mode 2, form 1 - 2,048 and 2,352 bytes; mode 2, form 2 - 2,352 bytes; CD-DA - 2,352 bytes
Random: less than 120 ms
Full Stroke: 200 ms
Maximum Data Transfer Rates
CD-ROM, CD-R read: 7200 KB/s (48X) Max
Data Transfer Modes
ATA PIO mode 4 (16.7MB/s); ATA multi-word DMA mode 2 (16.7 MB/s); ATA UltraDMA mode 0 (16.7 MB/s) ;ATA UltraDMA mode 1 (24 MB/s) ; ATA UltraDMA mode 2 (33 MB/s) - default.
Power
Cache Buffer
2 MB (minimum)
Stop Time
less than 4 seconds
Power DC Current
Power Source
Audio Output Level
0.7 Vrms (typical)
50-pin, IDE interface
Maximum Wet Bulb Temperature (operating): 29 degrees C (84 degrees F)
ACA AS/NZS 3548, ANSI C63.4-1992, CB Test Certificate for IEC 950, CE Mark, CFR 47 part 15, CNS 13438, CSA C22.2 No. 60950, DHHS/FDA - 1040, EN60825, EN55022:1998, EN55024, EN60 950:2000, ICES-003 class B, IEC 61000 4-2 - 4-11, Nordic EN60 950, TUV or VDE EN60 950, UL 60950, C.I.S.P.R. Publication 22 Class B, BSMI, Microsoft® P2001, Microsoft Logo for Windows® 98, 2000 and XP
48X Max CD-ROM Drive
Interface Type
ATAPI
Dimensions - (H x W x D maximum)
4.3 x 15.0 x 20.3 cm (1.7 x 5.9 x 6.0 inches)
1200 g (2.6 pounds)
Disc Diameter
12 cm, 8 cm
Disc Thickness
1.2 mm (0.05 inch)
Track Pitch
1.6 µm
CD-ROM Mode 1, CD-ROM XA (Mode 2, Form 1 and 2), CD Digital Audio, CD-EXTRA, CD-I (Mode 2, Form 1 and 2) and CD-I Ready, CD-Text, CD-Bridge, Photo CD (Single and Multi Session), Video CD, CD-R and CD-RW Multi-Session
Disc Formats Written
None
Disc Capacity
180 MB (8 cm); 540 MB (12 cm); 650 MB (12 cm); 700 MB (12 cm)
Block Size (bytes)
Mode 1 - 2,048, 2,352 bytes
Mode 2 - 1, 2,048, 2,328, 2,336, 2,340, 2,353 bytes
Mode 2 - 2, 2,328, 2,336, 2,340, 2,352 bytes
CD-DA - 2,352, 2,368 bytes
Random: less than 125 ms
Full Stroke seek: less than 210
Data Transfer Rates
Variable (Audio CD) - 1,800 to 3,600 KB/s (24X) Max Variable (CD-ROM, CD-R) - 2,400 to 7,200 KB/s (48X) Max
Data Buffer
2 MB
less than 7 seconds typical, less than 30 seconds with multi-session
Audio Output Level
Line-out-0.7 V at 47 Kohm
Kit Contents
CD-ROM drive, installation guide, warranty card
Power Specifications
Specification
Power supply
90 - 264 VAC
Rated voltage range
100 - 240 VAC
Rated voltage range
50/60 Hz
47 - 63 Hz
Rated input current
6A
Heat dissipation
Power supply fan
92mm variable speed
yes
yes
3 Watts
Physical Specifications
Specification
32.5 pounds
Volume
33.8 liters
Shipping weight
43 pounds
Software/OS
Feature
Pre-installed Operating System
  • Microsoft Windows XP Professional with Service Pack 2 (SP2)
  • Microsoft Windows XP Home with Service Pack 2 (SP2)
  • FreeDOS
    FreeDOS is a free operating system that is wholly compatible with MS-DOS.
    Microsoft Windows NT 4.0 and Microsoft Windows 2000 are not available on these systems.
Certified Operating Systems
  • SuSE Linux
  • Red Flag Linux
  • Microsoft WHQL
  • Netware Client
Certified means that the PC model has passed compatibility testing with the operating system. Compatibility testing is not a test of all possible configurations and some components may need support from drivers not included in the operating system.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
