    We are upgrading our website
Evo Notebook N610C - Installing the Mini PCI Board
Overview
  1. Prepare the notebook for disassembly.
  2. Turn the notebook bottom side up with the front facing forward.
  3. Remove the two screws (1) that secure the mini PCI compartment cover to the base enclosure.
  4. Lift the left edge of the cover and swing it up and to the right (2) .
  5. Remove the cover.
  6. Disconnect the modem cable from the mini PCI communications board (1).
  7. Spread the retaining tabs (2) to release the mini PCI communications board. The board tilts up at a 45-degree angle.
  8. Remove the board by pulling it away from the connector at a 45-degree angle (3).
  9. Reverse the preceding procedure to install the mini PCI communications board and mini PCI compartment cover.
