Evo Notebook N410C - Installing a Battery
Inserting the Battery Pack
Before beginning, turn the computer bottom-side up.
  1. Slide the left slide switch forward.
  2. Slide and hold the right slide switch forward.
  3. Insert the battery into the battery compartment.
  4. Rotate the battery forward and snap the battery into place.
  5. Slide the right slide switch back.
Removing the Battery Pack
  3. Lift the battery up towards the back of the computer.
  4. Remove the battery.
