Evo N200 - Installing Battery
Before you Begin
To prevent loss of information when removing a battery pack that is the only power source available to the system, initiate Hibernation or turn off the computer before removing the battery pack.
Before you Begin
  1. Close the display, then turn the computer bottom-side up.
  2. Remove the battery pack retaining screw.
Removing a Battery Pack
  1. Slide and hold the battery release latch toward the front of the computer.
  2. Tilt the battery pack out of the battery bay.
  3. Remove the battery pack.
Inserting a Battery Pack
Insert the battery pack into the battery bay at a 45 degree angle.
Tilt the battery pack downward into the battery bay until it is seated.
Replace the battery pack retaining screw.
To return to your work, open the display, then turn on the computer or restore it from Hibernation.  To restore the computer from Hibernation, slide the power switch.
