Evo Notebook N610C - Installing the Modem Cable
Overview
  1. Prepare the notebook for disassembly and remove the following components:
    • RTC battery
    • Keyboard
    • Memory expansion compartment cover
    • TouchPad
    • Switch cover
    • Display
    • Top cover
    • System board
  2. Position the base enclosure with the rear panel facing forward.
  3. Lift the modem connector out of the base enclosure (1) and disengage the modem cable (2) from the alignment clips and tabs in the base enclosure.
  4. Remove the modem cable.
  5. When installing the modem cable, route the cable along the path indicated above.
  6. To reinstall a cable, reserve this procedure.
