Evo Notebook N410C - Optical Drives Tech Specs
Optical Drives Technical Specifications
8X DVD/CD-RW Combo Drive
Center hole diameter
0.59 in/1.5 cm
Disk Diameter
12 cm/8 cm
Disk Thickness
0.047 in/1.2 mm
Track pitch
0.74 um
Access Times (typical reads, including settling)
  • Random CD: <150ms
  • Full Stroke CD:  <225ms
Cache buffer
128 KB/s (minimum)
Data transfer rate (typical, including settling)
  • CD-R (8X) - 1200 KB/s (150 KB/s at 1X CD rate)
  • CD-RW (8X) - 1200 KB/s (150 KB/s at 1X CD rate)
  • CD-ROM (24X) - 3600 KB/s (150 KB/s at 1X CD rate)
  • DVD (8X) - 10,800 KB/s (1352 KB/s at 1X DVD rate)
  • Normal PIO Mode 4  (single burst) - 16.6 MB/s
Audio Output Level
Line-out - 0.7 Vrms
Cache Buffer
CD-R, CD-RW Write Speeds Sustained: 1200KB/s (8X CLV)
Startup time
< 15 seconds
Stop time
< 6 seconds
24X DVD/CD-RW Combo Drive
39 cm
Disk Diameter
12 cm, 8 cm
Disk Thickness
1.2 mm
Track pitch
0.74
Access time (typical reads, including settling)
  • Random CD: < 150ms
  • Full Stroke CD:  < 225ms
Cache buffer
128 KB/s (minimum)
  • CD-R (24X) - 3600 KB/s (150 KB/s at 1X CD rate)
  • CD-RW (10X) - 1500 KB/s (150 KB/s at 1X CD rate)
Audio Output Level
Line-out: 0.7 Vrms
Startup time
< 15 seconds
Stop time
< 6 seconds
16X CD-RW Drive
0.59 in/1.5 cm
Disk diameter
12 cm, 8 cm
Disk thickness
0.047 in/1.2 mm
Track pitch
0.74
  • Random (typical): < 150 ms
  • Full Stroke (typical):  < 225 ms
Audio Output Level
0.7
Cache buffer
128 KB/s (minimum)
  • CD-R (16X) - 2400 KB/s
Startup time
< 15 seconds
Stop time
< 6 seconds
8X DVD-ROM Drive
0.59 in/1.5 cm
Disk diameter
12 cm, 8 cm
Disk thickness
0.047 in/1.2 mm
Track pitch
0.74
  • Random (typical) < 150 ms DVD Media
  • Full-Stroke (typical) < 225 ms DVD Media
  • Random (typical) < 110 ms CD Media
  • Full-Stroke (typical) < 200 ms CD Media
Cache buffer
512 KB/s (minimum)
  • Max 24X CD 3600 KB/s (150 KB/s at 1X CD rate)
  • Max 8X DVD 10,800 KB/s (1352 KB/s at 1X DVD rate)
  • Normal PIO Mode 4 (single burst) 16.6 MB/s
Startup time
< 10 seconds Single Session CD-ROM
Stop time
< 3 seconds
24X CD-ROM Drive
Applicable Disk
CD-ROM (Mode 1, 2 and 3), CD-XA ready (Mode 2, Form 1 and 2), CD-I ready (Mode 2, Form 1 and 2), CD-R (read only), CD Plus, Photo CD (Single and Multi-session), CD-Extra, Video CD, CD-WO (fixed packets only), CD-Bridge
0.59 in/1.5 cm
Disk diameter
12 cm, 8 cm
Disk thickness
0.047 in/1.2 mm
Track pitch
1.6
  • Full-Stroke (typical) < 300 ms
Audio Output Level
0.7
Cache buffer
128 KB
  • Sustained (16X) 2400 KB/s
  • Variable 1500 to 3600 KB/s (10X to 24X)
  • Normal PIO Mode 4 (single burst) 16.66 MB/s
Startup time
< 8 seconds
Stop time
< 4 seconds
MultiBay Diskette Drive
Diskette Size
3.5in
Height
12.7mm
Bytes per Sector
512
Sectors per track
  • High density - 18 (1.44 MB)/15 (1.2 MB)
  • Low density - 9
Tracks per side
  • High density - 80 (1.44 MB)/80 (1.2 MB)
  • Low density - 80
Read/Write heads
2
Access Times
  • Track-to track (high/low) - 3 ms/6 ms
  • Average (high/low) - 94 ms/174 ms
  • Settling time  - 15 ms
  • Latency average - 100 ms
Country: Flag Bulgaria
