HP Compaq Business Notebook nx9100 - Display Panel Specifications
14.1-Inch Color TFT XGA Display
Feature
US
Metric
Dimensions (H x W)
11.22 x 8.46 in
28.5 x 21.5 cm
Diagonal Size
14.1 in
35.81 cm
Mounting
Internal Panel Supports, Side Mounted
Number of Colors
Up to 16.8M
Contrast Ratio
150:1
Brightness
120nt typ
Pixel Resolution
Pitch 0.264 x 0.264 mm
Format 1024 x 768
Configuration RGB stripe
Backlight
Edge Lit
Character Display
80 x 25
Total Power Consumption
4.2W
15-Inch Color TFT SXGA+ Display Wide-viewing Angle
Feature
US
Metric
Dimensions (H x W)
11.8 x 9 in
30.4 x 22.8 cm
Diagonal Size
15 in
38 cm
Mounting Internal Panel Supports
Side Mounted
Number of Colors
Up to 16.8M
Contrast Ratio
150:1
Brightness
130nt typ
Pixel Resolution Pitch
0.218 x 0.218 mm
Format
1400 x 1050
Configuration
RGB stripe
Backlight
Edge Lit
Character Display
80 x 25
5.75W
Viewing Angle (Typical)
Horizontal - +/65 Degrees
Vertical - +50/-50 Degrees
Feature
US
Metric
Display Dimensions (H x W)
11.8 x 9 in
30.4 x 22.8 cm
Diagonal Size
15 in
38 cm
Mounting
Number of Colors
Up to 16.8M
Contrast Ratio
150:1
Brightness
150nt typ
Pixel Resolution
Pitch 0.218264 x 0.218264 mm
Format 1400 x 1050
Backlight
Edge Lit
Character Display
80 x 25
5.75W
15-Inch Color TFT XGA Display
Feature
US
Metric
Dimensions (H x W)
11.8 x 9 in
30.4 x 22.8 cm
Diagonal Size
15 in
38 cm
Mounting
Number of Colors
Up to 16.8M
Contrast Ratio
150:1
Brightness
150nt typ
Pixel Resolution
Pitch 0.297 x 0.297 mm
Format 1024 x 768
Backlight
Edge Lit
Character Display
80 x 25
5.0W
15-Inch Color TFT UXGA Display with wide viewing angle
Feature
US
Metric
Dimensions (H x W)
11.8 x 9.0 in
30.4 x 22.8 cm
Diagonal Size
15.0 in
38.0 cm
Mounting
Number of Colors
Up to 16.8M
Contrast Ratio
250:1
Brightness
140nt typ
Pixel Resolution
Pitch 0.191 x 0.191 mm
Format 1600 x 1200
Backlight
Edge Lit
Character Display
80 x 25
6.5W
Viewing Angle
+/-85 degrees Horizontal, +15 /-35 Vertical (typical)
Country: Flag Bulgaria
