Evo Notebook N800c - Installing Multibay Devices
Installing and Removing Multibay Devices
NOTE: Modular Bay devices used in Compaq Armada, Compaq Evo or Presario FutureBay devices
cannot be used in the N800 / Presario 2800 MultiBay. Likewise, MultiBay devices cannot be used in other Compaq notebooks using a Modular Bay.
The MultiBay supports the following devices:
  • DVD/CD-RW drive
  • CD-ROM drive
  • DVD-ROM drive
  • CD-RW
  • Floppy diskette drive
  • Battery
  • Weight saver
IMPORTANT: Static electricity can damage electronic components.
Before beginning these procedures, make sure you are grounded (discharged of static electricity) by briefly touching a grounded, unpainted metal object or surface.
Installing the Multibay Device
  1. Turn the computer bottom side up with the front facing you.
  2. Insert the device in the MultiBay and gently push the device until it is seated.
Removing the Multibay Device
Before you begin, close the computer display, turn the notebook bottom side up with the front facing forward to remove a MultiBay device.
To remove a MultiBay device in Windows XP:
  1. Slide the release bezel out to release the MultiBay device.
  2. Pull out the MultiBay device and remove.
To remove a MultiBay device in Windows 2000:
  1. Double click the Add/Remove hardware icon in the system tray.
  2. Select the device from the list and click the Stop button.
  3. Remove the device following the appropriate steps.
