Evo Notebook N410C - Installing Communications
Overview
  1. Prepare the notebook for disassembly.
  2. Remove the palm rest.
  3. Disconnect the modem/NIC cable from the modem/NIC board (1).
  4. Pull away the retention clips on each side of the modem/NIC board (2). The modem/NIC board tilts upward.
  5. Lift the edge of the modem/NIC board and slide it out of the connector at a 45-degree angle (3).
  6. Reverse the above procedure to install the modem/NIC board.
Installing the Modem Cable
  1. Prepare the notebook for disassembly and, in the order below, remove the following components:
    • Palm rest
    • Keyboard
    • Switch cover
    • Display
  2. Position the notebook so the rear panel faces you.
  3. Remove the screw (1) that secures the right
  4. display support to the base enclosure.
  5. Remove the right display support (2).
  6. Position the notebook so the front faces you.
  7. Lift the RJ45/RJ11 connector module (1) out of the base enclosure.
  8. Disconnect the microphone cable (2) from the connector on the display lid switch board.
  9. Disconnect the microphone cable (3) from the system board.
  10. Remove the screw 4 that secures the display lid switch board to the base enclosure.
  11. Disconnect the network interface card (NIC) passthrough cable (1) and NIC/switch to system cable (2) from the system board.
  12. Remove the modem cable.
  13. Reverse this procedure to install a new cable.
Country: Flag Bulgaria
