Compaq QVision 210 Color Monitor - Overview
Product Description
Compaq QVision 210 20" Monitor
Product Features
Feature
Monitor Type
Color Multiple Scan
Picture Tube (diagonal)
21 inch Full square
Viewable Image Area (diagonal)
49.6 cm (19.5 inches)
Dimensions, WxHxD
50.7 x 50.2 x 55.9 cm (20 x 19.8 x 22 inches)
Weight (unpacked)
35kg (77lb)
Dot Pitch
0.26 mm
Energy Star Compliant
Yes
Display Resolutions / Refresh Rates (Noninterlaced)
    1600 x 1200
60, 70, and 75 Hz
    1280 x 1024
60, 75 and 85 Hz
    1024 x 768
60, 70, 72 and 75 Hz
    800 x 600
72 and 75 Hz
    720 x 400 (Text mode)
70Hz
    640 x 480
60, and 75 Hz
    640 x 350
70 Hz
Preset Display modes
Yes
User Programmable Graphic Modes
Twelve
Bandwidth
100 MHz
Input Impedance
75 ohms
Horizontal Frequency
(Banded/Continuous)
31 to 94 kHz
Continuous
Vertical Frequency
48 to 160 Hz
Power Supply(ALS)
90-127 / 195-265 VAC 47-63 Hz
Inrush Current
30 Amps at 120 VAC; 50 Amps at 220 VAC
Maximum Power Rating
175 Watts
Sync Input
TTL separate synch
Signal Cable Connectors
Detachable 15 pin miniature D-sub to 5 BNC
Anti-glare
Yes, with Anti-Static
Asset Management
Yes
ISO9241-3 VDT (workplace)
Yes
MPR II (Low Emissions)
Yes (Model 482T MPR II & TCO )
Plug and Play
Yes
Power Management
Yes
Standard Controls
Contrast, Brightness, Sizing, & Positioning
Advanced Controls:
Pincushion (barrel),
Trapezoid,
Tilt (rotation)
Color temperature
Degauss
Parallelogram
Unbalanced pin
On Screen Display
Yes
