Evo N200 - I/O Technical Specifications
The system uses the National Semiconductor 97338 Super I/O controller to support the serial port, Infrared port, and parallel port.  The serial and parallel ports are available on the MEU only.
Rear View
   1. External battery pack connectors (2)
   2. RJ-45 jack
   3. RJ-11 jack
   4. VGA connector
   5. MEU connector
   6. USB connectors (2)
The Mobile Expansion Unit (MEU) is an optional proprietary docking connection that allows you to access other types of devices from the system, without making those devices a permanent part of the configuration.
Serial and Infrared Ports
The system has one external Fast Infrared communication port on the system, and an RS-232 serial port on the MEU. Both ports are implemented with a 16550A compatible serial controller.
The Infrared controller supports a data rate of up to 4Mb/s, in addition to 115Kb/s and other popular slower speeds.  ***Infrared version TBS***
The serial port uses an industry standard 9-pin "D" type connector.
Parallel Port
The MEU has one IEEE-1284 industry standard parallel port that uses a standard 25 pin "D" type connector.  The port can be programmed to operate in Compatibility Mode, Enhanced Modes, Bi-Directional mode, and Extended Capability Port Mode. The default is Bi-Directional mode.
USB Port Support
The system has a two-channel USB hub controller that provides two USB Rev 1.1 ports to the system, and two USB Rev 1.1 ports to the MEU. All ports support 500ma.
The system uses a special 5-pin USB connector, which provides support for four USB ports as well as the Selective Suspend (C3) power management state under Windows 2000.  The fifth pin is used as a sense line to sense the physical connection to the USB hub. The hub has a q-switch that connects and disconnects devices to the 440MX root controller.  ****To be verified****
This configuration results in a Generic USB Hub to be displayed in the Device Manager when a USB device is connected to the system.  This is normal for this system.
Country: Flag Bulgaria
