Compaq Evo D510 Ultra-slim Desktop PC Product Specifications
Product description
The Evo D510 Ultra-Slim Desktop is available in GCD and CKK only.
Product features
Feature
Intel 845G
Processor
Intel Pentium 4 Processors with 400 MHz Front Side Bus
  • 1.7 GHz with 400 MHz FSB, Standard L2 Cache 128 KB Integrated ECC
  • 1.9 GHz with 400 MHz Front Side Bus, 512 KB L2 cache
  • 2.0 GHz with 400 MHz Front Side Bus, 512 KB L2 cache
Memory
  • 128 MB DDR Synch Dram PC2100 (266 MHz) Non ECC (1 x 128)
  • 256 MB DDR Synch Dram PC2100 (266 MHz) Non ECC (1 x 256)
  • 384 MB DDR Synch Dram PC2100 (266 MHz) Non ECC (1 x 128 + 1 x 256)
  • 512 MB DDR Synch Dram PC2100 (266 MHz) Non ECC (1 x 512)
  • 512 MB DDR Synch Dram PC2100 (266 MHz) Non ECC (2 x 256)
  • 1 GB DDR Synch Dram PC2100 (266 MHz) Non ECC (1 x 1024)
  • 1 GB DDR Synch Dram PC2100 (266 MHz) Non ECC (2 x 512)
  • 2 GB DDR Synch Dram PC2100 (266 MHz) Non ECC (2 x 1024)
Maximum Memory
2 GB DDR-Synch DRAM PC2100(266 MHz)
Hard Drive
  • 20 GB 5400 rpm SMART III Ultra ATA/100
  • 20 GB 7200 rpm SMART III Ultra ATA/100
  • 40 GB 5400 rpm SMART III Ultra ATA/100
  • 40 GB 7200 rpm SMART III Ultra ATA/100
  • 80 GB 5400 rpm SMART III Ultra ATA/100
  • 80 GB 7200 rpm SMART III Ultra ATA/100
Keyboard
  • PS/2 Easy Access Keyboard
  • USB Easy Access Keyboard
  • USB Smart Card Keyboard
Mouse (One of the following)
  • PS/2 2-Button Scroll Mouse
  • USB 2-Button Scroll Mouse
NIC
Integrated Intel PRO/100 VM Network Connection
Removable Storage
  • 1.44 MB Diskette Drive
  • MultiBay Drives  (Requires Multibay Drive Adaptor to use)
  • USB Disk-on-Key
MultiBay Drive
  • MultiBay 24X CD-ROM Drive
  • MultiBay 8X DVD-ROM Drive with RAM Read
  • MultiBay 24X CD-RW Drive
  • MultiBay 24X Combo DVD-ROM and CD-RW Drive
  • MultiBay 20-GB Hard Drive
Graphics
Intel Extreme Graphics (integrated with Intel 845G chipset)
Optical Storage
Standard MultiBay drive
Audio
Integrated Intel audio with Premium internal speaker
Slots
None
Bays
Two
Internal Drive
One 3.5 inches ATA hard drive
External Drives
  • MultiBay drive
  • MultiPort (wireless network port uses USB bus)
Wireless Support
  • MultiPort slot supports optional 802.11b and Bluetooth MultiPort modules
  • Bluetooth MultiPort Module
  • 802.11b MultiPort Module
USB Support
  • 1 Front USB 2.0 Ports
  • 4 Rear USB 2.0 Ports
Power Supply
Custom Power Supply-Non-PFC full ranging (no line select)
Dimensions (H x W x D)
7 x 32 x 33 cm / 2.72 x 12.4 x 12.83 inches
5.04 kilograms / 11.2 lbs.
Security
  • Optional cable lock (Kensington lock)
  • MultiBay security screw prevents ejection of MultiBay devices
  • Smart cover hood lock is not supported
Serviceability
  • Tool-less drive and hood removal
  • Easy access to system board
Electrical specifications
Feature
Power supply
Custom Power Supply, Non-PFC Full Ranging (No line select)
Operating voltage range
90 to 264 V ac (full ranging)
Rated voltage range
100 to 127 V ac (or 200 to 240 V ac)
Rated line frequency
50-60 Hz
Operating line frequency range
47-66 Hz
Rated input current
1.7A @ 100 V ac (or 0.85 A @ 200 V ac)
Maximum rated power
50 W
System specifications
Feature
System board architecture
P4/Legacy Free/AGP 4X (Integrated Only)
Intel 845G Chipset
I/O controller
Super I/O 3
System board form factor
Custom USDT
Processor
Intel Pentium 4 Processors with 400 MHz Front Side Bus, 512KB L2 cache
Any one of the following:
  • 1.7 GHz
  • 1.9 GHz
  • 2.0 GHz
Memory
  • 128MB DDR Synch Dram PC2100 (266 MHz) Non ECC (1 x 128)
  • 256MB DDR Synch Dram PC2100 (266 MHz) Non ECC (1 x 256)
  • 384MB DDR Synch Dram PC2100 (266 MHz) Non ECC (1 x 128 + 1 x 256)
  • 512MB DDR Synch Dram PC2100 (266 MHz) Non ECC (1 x 512)
  • 512MB DDR Synch Dram PC2100 (266 MHz) Non ECC (2 x 256)
  • 1GB DDR Synch Dram PC2100 (266 MHz) Non ECC (1 x 1024)
  • 1GB DDR Synch Dram PC2100 (266 MHz) Non ECC (2 x 512)
  • 2GB DDR Synch Dram PC2100 (266 MHz) Non ECC (2 x 1024)
  • 20GB 7200 RPM SMART III Ultra ATA/100
  • 40GB 5400 RPM SMART III Ultra ATA/100
  • 40GB 7200 RPM SMART III Ultra ATA/100
  • 80GB 5400 RPM SMART III Ultra ATA/100
  • 80GB 7200 RPM SMART III Ultra ATA/100
MultiBay drive
  • MultiBay 20GB Hard Drive
Removable storage
  • 1.44MB Diskette Drive
  • MultiBay Drives
  • USB Disk-on-Key
Graphics
Audio
Integrated ADI 1981A Audio
  • AC ‘97 Stereo Codec
  • OPL3 FM Synthesis Support
  • Sound Blaster Compatibility
  • Sampling: 7 KHz to 48 KHz
  • Compression: ADPCM, ESPCM
  • Wavetable Syntheses (software)
  • Internal Audio Speaker Power Rating: 3 W
Network interface card
Wireless communications
Modem
Lucent V.90 56K Win Modem
Keyboard
Mouse
Miscellaneous
Legacy Module - supports parallel, serial, PS/2 keyboard and PS/2 mouse ports
Interfaces
  • Serial Port: 1 with optional Legacy Module
  • Parallel Port: 1 with optional Legacy Module
  • PS/2: 2 with optional Legacy Module (1 Keyboard and 1 Mouse)
  • USB 2.0: 5 ports (4 rear, 1 front)
  • RJ-45 Network Port: 1
  • Video (VGA): 1
  • Multibay: 1
  • Multiport: 1
  • Mic-In: 1 (20 kohm input impedance)
  • Line-In: 1 (12 kohm input impedance)
  • Headphone-Out: 1 (2.5 ohm output impedance, expects at least a 32 ohm load)
Security
  • Mechanical Hood Security Provision
  • Kensington Lock Support
  • Cable Lock Provision
Software specifications
Feature
  • Microsoft Windows 2000 SP2
  • Microsoft Windows XP Professional SP1
  • Microsoft Windows XP Home SP1
  • Mandrake Linux 8.2 (only available on limited configurations)
Applications
  • Norton Internet Security/Norton AntiVirus 2002
  • Microsoft Office XP Small Business Edition/Professional Edition/Personal Edition
  • Roxio CD Creator
  • Intervideo DVD Player
BIOS features
Feature
Instantly available PC (Suspend to RAM - S3)
Allows for very low power consumption with quick resume time.
ROM based F10 setup
Allows for reviewing and customizing BIOS settings.
Remote system installation via F12 (PXE)
Allows a new or existing system to boot over the network and download software, including the operating system, that is stored on a management server.
Emergency ROM flash recovery with video
Allows for recovery of corrupted system BIOS.
CMOS archive and CMOS restore
Saves and restores BIOS settings to diskette in human-readable file.
Auto setup when new hardware installed
System automatically detects addition of new hardware (e.g. memory, floppy, etc.)
Serial, parallel, USB enable/disable port control
Allows the user to enable or disable serial, parallel or USB ports.
Removable media write/boot control
Prevents the computer from being booted from removable media (and can disable writes to media).
Remote boot from server
Network server mode
Allows for keyboard-less operation.
Power-On password
Prevents an unauthorized person from booting up the computer.
Setup password
Prevents an unauthorized person from changing the system configuration.
Memory change alert (requires Insight Management Agent)
Alerts management console if memory is removed or changed.
Thermal alert (requires Insight Management Agent)
  • Monitors the temperature within the chassis.
  • There are three operational states that a computer can experience:
    • NORMAL - operating under under normal temperature ranges.
    • ALERTED - operation when excessive temperatures are detected. Will raise a flag so that appropriate action can be taken to avoid shutdown or provide for a smoother system shutdown.
    • SHUTDOWN - when excessive temperatures are encountered. Will automatically shutdown the computer without warning before hardware component damage occurs.
Cover removal alert (requires Insight Management Agent)
  • Assists with asset security and control by notifying the Network Administrator and end user when the cover has been removed without authorization.
  • Is an electronic switch residing inside the computer which can be set to any one-of-three modes depending on the amount of control desired:
    • DISABLED - the network administrator does not want to be made aware of the computer hood removal.
    • NOTIFY USER - notifies network administrator that the hood has been removed, but no administrator action required before re-booting the computer.
    • UP PASSWORD – notifies network administrator that the hood has been removed and administrator password is required before re-booting the computer.
Master boot record security
Allows for detection of changes to MBR and optional restoration, useful in protecting from viruses.
Remote ROM flash
Provides secure, fail-safe ROM image management from a central network console.
Remote wakeup
  • Allow a system administrator to power on, restart, and power off a client computer from a remote location.
  • This enables cost-effective power consumption when the administrator needs to distribute software, perform security management, or update the ROM.
ACPI power management
  • Advanced Configuration and Power Management Interface (ACPI).
  • It allows the system to wake from a low power mode.
  • It controls system power consumption, making it possible to place individual cards and peripherals in a low-power or powered-off state without affecting other elements of the system.
SMBIOS
System Management BIOS, previously known as DMI BIOS, for system management information.
Software overview
Feature
Operating System
  • Windows XP Professional SP1
  • Red Hat 8.0 Certified
  • SuSE 8.1 Certified
  • TurboLinux 7.0 (limited configurations – China only)
Physical specifications
Feature
Chassis dimensions (H x W x D)
7 x 32 x 33 cm (2.72 x 12.4 x 12.83 in)
Chassis weight
  • System weight: 5.04 kg (11.2 lb)
  • Weight supported: 45.5 kg (100 lb)
Environmental specifications
Feature
Acoustics (with advanced power management - on)
Idle (HDD spinning but not seeking) = 19 dB
Shock
  • Operating: 5 G (with no damage being incurred)
  • Non-operating: 20 G (with no damage being incurred)
Vibration
  • Operating: Random vibration at 0.000215 G²/Hz, 10 Hz to 300 Hz, (0.25 G nominal)
  • Non-operating: Random vibration at 0.0005 G²/Hz, 10 Hz to 500 Hz, (0.5 G nominal)
Relative humidity
  • Operating (maximum wet bulb temperature, non-condensing): 10% to 90% relative humidity (Rh), 28°C
  • Non-operating (maximum wet bulb temperature, non-condensing): 5% to 95% relative humidity (Rh), 38.7°C
Altitude (un-pressurized)
  • Operating: 0 to 3,048 m (10,000 ft) - This value may be limited by the type and number of options installed
  • Non-operating: 0 to 9,144 m (30,000 ft)
Maximum allowable altitude change rate is 1500 ft/min.
