HP Compaq nc8000 and nw8000 notebooks - Installing the Hard Drives
Overview
You can use any 9.5mm hard disk drive in the hard disk drive bay. No adapter is required. The hard disk drive in the hard disk drive bay is the primary hard disk
drive.
To install a new hard drive, first remove the old drive and then install a new one:
  1. Save your work. Shut down the notebook and close the display.
  2. Turn the notebook upside down.
  3. Remove the hard drive cover retaining screw.
  4. Slide the hard drive latch forward to open the hard drive compartment
  5. Remove the hard drive cover.
  1. To install the new drive, reverse this procedure and befure to reinstall the hard drive cover retaining screw.
