HP Compaq Business Notebook nx7000 - Installing the System Board
Overview
  1. Prepare the notebook for disassembly and remove the following components:
    • Optical drive
    • Keyboard
    • Switch cover
    • Speaker cover
    • Display assembly
    • Top cover
  2. Disconnect the SD Card slot board cable (1) from the system board.
  3. Remove the PM2.5x5.0 screw (2) that secures the SD Card slot board cable ground loop to the base enclosure and the PM2.5x5.0 screw (3) that secures the system board to the base enclosure.
  4. Lift the right side of the system board approximately 1 inch (1). If necessary, flex the back edge of the base enclosure out so the parallel (2) and serial connectors (3) can clear the base enclosure.
  5. Slide the old system board to the right an angle (4).
  6. Remove the old system board.
  7. Reverse the above procedure to install a system board.
