HP LaserJet 3015, 3020, 3030, and 3380 AiO Products - Using the Firmware Update Utility
This document provides information for running the HP LaserJet Firmware Update utility.
To ensure an easy and successful upgrade, it is essential to read and follow the instructions below.
Disconnect all devices except the target HP LaserJet AiO product that are directly connected to the computer before performing the Firmware upgrade.
Performing the update
Perform the update as follows:
  1. Print a Configuration page to confirm the existing firmware date code.
    1. Press the Menu/Enter button
    2. Press the < or > button until Reports appears in the control panel display, then press the Menu/Enter button.
    3. Press the < or > button until Configuration Report appears in the control panel display and press Menu/Enter. The product will exit the menu settings and print the report.
  2. Disconnect the phone line from the device to prevent interruption from an incoming fax.
  3. Verify that the computer has 50 MB of free disk space in order to successfully run the Firmware Update Utility.
  4. The utility can run using either a parallel or a USB connection (USB is not supported in Windows 95 or NT): If using a USB cable, it is important to first install the HP LaserJet AiO software before running the utility (the USB ports and connection are established during the software install). If using a parallel cable, simply attach the cable and the utility will find the connection automatically.
  5. Restart (reboot) the HP LaserJet AiO device.
  6. Close all open programs before running the firmware update.
    In Windows 95/98/Me
    1. Simultaneously press the Ctrl, Alt, and Delete keys. This will bring up the Close Program window.
    2. Highlight one item and click End Task.
    3. Repeat this procedure until all programs are closed, except for Explorer and Systray.
    In Windows 2000/XP
    1. Simultaneously press the Ctrl, Alt, and Delete keys. This will bring up the Windows 2000 Security window.
    2. Click the Task Manager button.
    3. Click to open the Applications tab.
    4. Highlight one item and click End Task until all items are closed.
  7. Download the product firmware update utility from: Click hp LaserJet 3030 Flash Firmware. Use either of the options: Save the file to your PC or Run the update from its current location.
  8. When the file opens, click the Start button and allow the utility to run uninterrupted. The product display will initially read Printing Document. After about a minute, the product display will read Updating. Several minutes later the display will change to Completed. The display will then change to Scanner Bulb Warming Up as the new firmware initializes. Finally, the display will show Ready in the top-left corner. Depending upon the operating system on the PC, the software might prompt Please reboot your Computer. Close the screens by clicking OK.
  9. Reboot the PC, if necessary.
  10. Print a new Configuration page to confirm the new firmware date code.
Country: Flag Bulgaria
