HP Compaq nc/nw/nx8200 Notebook PCs Product Specifications
Product description
The HP Compaq nc/nw/nx8200 series Notebook PCs combine the processing and graphics power of a desktop with the mobility and convenience of a notebook.
Product features
Feature
Processor
  • minimum: Intel® Pentium® M Processor 730 (1.6 GHz, 2-MB L2 cache, 533-MHz front side bus)
  • maximum: Intel® Pentium® M Processor 770 (2.13 GHz, 2-MB L2 cache, 533-MHz front side bus)
Memory
  • minimum: 256 MB
  • maximum: 2048 MB
Mobile Intel 915PM Express Chipset
Storage - Hard Drive
  • minimum: 40 GB (5400 rpm) or 60 GB (7200 rpm)
  • maximum: 80 GB (5400 rpm) or 60 GB (7200 rpm)
Storage - MultiBay II (optional)
  • DVD-ROM MultiBay II Drive
  • DVD/CD-RW Combo MultiBay II Drive
  • DVD+/-RW MultiBay II Drive
  • 80-GB 5400 rpm MultiBay II Hard Drive
  • 15.4-inch TFT WXGA
  • 15.4-inch TFT WSXGA+ Wide Viewing Angle
  • 15.4-inch TFT WUXGA Wide-Viewing Angle
Graphics
ATI Mobility Radeon X600 graphics controller (PCI Express) with 64 MB or 128 MB video memory (nx8220 and nc8230)
ATI MOBILITY FireGL V5000 graphics controller (PCI Express) with 128 MB of video memory, OpenGL support (nw8240)
Audio
  • ADI AC '97 CODEC
  • Integrated 16-bit Sound Blaster Pro compatible audio
  • Integrated stereo speakers
  • External volume up, volume down, and mute buttons
  • Stereo headphone/line out
  • Stereo microphone in
Communications
  • NetXtreme Gigabit PCI Express Ethernet Controller (10/100/1000 NIC) with HP power down NIC technology
  • 56K modem with digital line guard
Communications - Wireless (optional)
  • Broadcom 802.11b/g WLAN
  • Broadcom 802.11a/b/g WLAN
  • Intel PRO/Wireless 2200BG 802.11 b/g WLAN
  • Intel PRO/Wireless 2915ABG 802.11 a/b/g WLAN
  • Integrated Bluetooth
Power
External 90W AC adapter, 6-foot power cord included
Battery
8-cell high capacity Lithium-Ion (69Wh)
Pointing Device
Dual Pointing devices – Touchpad with scroll zone and Pointstic (Exception: nx8220 has only the Touchpad)
Ports, Connectors & Slots
  • Type I/II PC Card Slot
  • One integrated Secure Digital slot
  • External Monitor Connector
  • External Microphone
  • Headphone/Line out
  • Power Connector
  • RJ-11 (Modem)
  • RJ-45 (NIC)
  • Ambient Light Sensor
  • Fast Infrared Port
  • Serial Port (nc8230 only)
  • IEEE 1394 Port (4-pin)
  • S-Video TV Out (Support for NTSC/PAL)
  • 3 USB 2.0 ports
  • Docking Connector
  • Travel Battery Connector
Dimensions (H x W x L)
14.00 x 10.40 x 1.10 in.
From 5.8 lb.
Nx - 1/1/0
Nc - 3/3/0
Nw - 3/3/3
Software overview
Feature
Operating System
  • Microsoft® Windows® XP Professional Edition SP2
  • Microsoft® Windows® XP Home Edition SP2 (select countries only)
  • FreeDOS
Preloaded Software
  • Adobe Acrobat Reader
  • HP Local Recovery provided by Altrirs
  • HP One-Touch Button Software
  • HP Mobile Print Driver
  • Synaptics Touchpad Driver
  • HP Help and Support
  • HP ProtectTools Security Manager: BIOS Configuration for HP ProtectTools, Credential Manager for HP ProtectTools
  • HP Wireless Assistant
  • Sonic RecordNow! (for optional DVD+/-RW and DVD/CDRW drives)
  • Symantec Norton Antivirus with complimentary 60-day live update
  • Intervideo WinDVD - DVD Player (for optional DVD+/-RW, DVD/CDRW and DVD drives).
Software available on CD
Intervideo WinDVD Creator – DVD Authoring (for optional DVD+/-RW drives)
Additional software downloadable from the Web
  • HP Client Manager Software
  • HP ProtectTools Security Manager including embedded Security for HP ProtectTools and Smart Card Security for HP ProtectTools
Search key words include:
nc8230, nx8220, nw8240, nc8200, nx8200, and nw8200
