HP Docking Station Specifications
Product description
The HP Docking Station provides desktop convenience with full port replication capability in a space-saving design.
Product features
Feature
Compatibility
The HP Docking Station is compatible with HP Compaq 4200, 6100, 6200 and 8200 series Notebook PCs.
Connectors
  • Monitor stand port
  • External monitor port
  • Serial port
  • Parallel port
  • Keyboard connector
  • Mouse connector
  • Audio-out (headphone) connector
  • Audio-in (microphone) connector
  • Digital video (DVI) port
  • Composite video jack
  • RJ-11 port (modem)
  • RJ-45/Ethernet port (network)
  • 3 Universal Serial Bus (USB) 2.0 connectors
  • Powered Universal Serial Bus (USB) connector
  • S-Video-Out
  • Power Connector
Security
Supports the HP/Kensington Cable Lock, which secures the docking station, connected computer and the MultiBay II
Service and Support
One-year limited warranty.
Electrical Specifications
Feature
Power Supply (input)
Rated Voltage
100 to 240 V
Rated Current
2.5A rms
Line Frequency
50 - 60 Hz
Physical Specifications
Feature
Dimensions (H x W x D)
11.02 x 2.4 x 6.02 in (28.0 x 6.1 cm x 15.3 cm)
2.24 lbs (1.02 kg)
Environmental specifications
Feature
Temperature
Operating
50° to 95° F (10° to 35° C)
Non-operating
14° to 140° F (-10° to 60° C)
Relative Humidity
Operating/Non-condensing
10% to 90% relative humidity
Non-operating
5% to 90% relative humidity, 101.6° F (38.7° C) maximum wet bulb temperature
Maximum Altitude
Operating
0 to 10,000 ft (0 to 3,048 m)
Non-operating
0 to 30,000 ft (0 to 9,144 m)
Shock
Operating
10 G, 11 ms, half-sine
Non-operating
60 G, 11 ms, half-sine
Vibration
Operating
0.5 G zero-to-peak, 10 to 500 Hz, 0.25 oct/min sweep rate
Non-operating
1 G, zero-to-peak, 10 to 500 Hz, 0.5 oct/min sweep rate
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
