HP Compaq Business Notebook nx9600 - Overview
Product description
The HP Compaq nx9600 Notebook PC brings you all the advantages of a high-end desktop in a notebook design.
Product Features
Feature
Processor
  • Intel Pentium 4 570 processor with HT Technology (3.8 GHz, 1MB L2 cache, 800 MHz FSB)
  • Intel Pentium 4 560 processor with HT Technology (3.6 GHz, 1MB L2 cache, 800 MHz FSB)
  • Intel Pentium 4 550 processor with HT Technology (3.4 GHz, 1MB L2 cache, 800 MHz FSB)
  • Intel Pentium 4 540 processor with HT Technology (3.2 GHz, 1MB L2 cache, 800 MHz FSB)
Memory
512MB or 1024MB standard, 400-MHz DDR2 SDRAM standard; two SODIMM slots Upgradeable to 2048 MB maximum (1024MB in slots 1 and 2)
Graphics
  • ATI MOBILITY RADEON® X300 with 64 MB
  • ATI MOBILITY RADEON X600 with 128 MB
  • 17.0-inch WXGA+ display with 1440 x 900 resolution and 16M colors, 140-degree viewing angle, 16:10 aspect ratio
  • 17.0-inch WSXGA+ BrightView display with 1680 x 1050 resolution and 16 M colors, 140-degree viewing angle, 16:10 aspect ratio
Hard Drive(s)
  • 40, 60, 100 GB 4200 rpm Hard Drives
  • 80 GB 5400 rpm Hard Drive
  • 60 GB 7200 rpm Hard Drive
Optical Drive(s)
Fixed 12.7mm Optical Drives: 24X DVD/CD-RW Combo, DVD+/-RW
Audio
AC’97 Codec with internal digital equalization; JBL Pro speakers
Input/Output/Peripheral support
  • PC card slots - (1) One Type I/II/III PC Card slot which supports both 32-bit CardBus and 16-bit PC Cards; (1) One ExpressCard/54 slot
  • Six-in-one media slot - Support for SD, MMC, Memory Stick, Memory Stick Pro, xD, and Smart Media
Security
Kensington lock, Smart Card as an accessory
Networking
  • Integrated high speed 56K modem,
  • Integrated 10/100/1000 NIC
  • Integrated Broadcom® 802.11a/g or Broadcom 802.11g wireless LAN connection
  • Optional integrated Bluetooth™ module
I/O ports and connectors
VGA, RJ-11, RJ-45, IEEE 1394, (4) USB 2.0, S-video, external microphone in, headphones/line out, docking connector, DC power
Keyboard
Full size keyboard with numeric pad
Pointing Device
Touchpad with four-way scrolling device
Power
12-cell Lithium-Ion battery, 2.2 Ah; AC adapter: 180 W
Dimensions (L x W x H)
11.14 x 15.67 x 1.99 inches (283 x 398 x 50.5 mm)
Less than 9.3 pound (4.2 kg)
One-year standard parts and labor warranty
Software Overview
Feature
Operating System(s)
Pre-installed Microsoft Windows XP Professional Edition
Installed Applications
  • Microsoft Windows Media Player 10
  • Microsoft .NET Framework 1.1
  • Microsoft DirectX 9Internet applications
  • Sun Java™ VM
  • Norton® Anti Virus 2004
  • Intervideo WinDVD 5 – select models
  • Sonic RecordNow 7 – select models
  • Sonic DLA 4 – select models
  • Intervideo WinDVD Creator 2 – select models
  • HP Mobile Printintg Driver for Windows
  • HP Wireless Assistant – select models
  • Adobe Acrobat Reader
Links to Product Specification and Warranty Information
