HP s7502 CRT Monitor - Overview
Product Description
The HP s7502 17-inch CRT monitor is a ideal companion to your HP desktop. This monitor has been engineered to meet the demands of day to day computing, suitable for common business applications such as spreadsheets, word processing and email. The monitor has been designed to provide renowned HP quality to those on a tight budget. This 17-inch CRT provides the most cost effective way to satisfy those users who want to move up from their current 15 inch monitor.
Product Features
Feature
Specification
Picture tube size
43.18 cm (17 in)
40.64 cm (16 in)
Trio dot pitch
0.28 mm
Horizontal dot pitch
0.24 mm
Tube type
Color, Conventional FST, Multi-frequency
Maximum pixel clock speed
110 MHz
Frequency
  • Horizontal: 30 to 70 kHz
  • Vertical: 50 to 160 Hz
Resolution supported
  • Maximum pre-set resolution
    1280 x 1024 @ 60 Hz
  • Preferred flicker free resolution
    1024 x 768 @ 85 Hz
  • Preset graphics mode
    1280 x 1024 @ 60 Hz
    1024 x 768 @ 85 Hz
    800 x 600 @ 85 Hz
    720 x 400 @ 70 Hz
    640 x 480 @ 85 Hz and 60 Hz
All modes are non-interlaced unless specified otherwise.
Signal cable
15-pin miniature D-sub, attached, 1.5 m (4.9 ft)
User-modes
Yes, 6 modes
Anti-glare/anti-static
Yes
Plug and play
Yes
Asset control
Yes, supported
Icon based on-screen
Yes
User controls (on-screen display)
Brightness, contrast, size and positioning, pincushion (barrel), trapezoid, tilt, selectable color temperature, parallelogram, pincushion balance, moiré, degauss, factory reset/recall, current display mode
Power supply
Universal; 100 to 240 V, 50 + and -3 Hz and 60 + and -3 Hz
Power consumption
  • Maximum power rating
    75 watts
  • Low power sleep mode
    < 5 watts
Dimensions (h × w × d)
  • Unpacked
    41 x 40.2 x 42 cm ( 16.1x 15.8 x 16.5 in)
  • Packed
    52.3 x 49.3 x 45.5cm (20.6 x 19.4 x 17.9 in)
  • Unpacked
    15.5 kg (34.1 lb)
  • Packed
    19 kg (41.8 lb)
Temperature
Operating: 10o to 35o C (50o to 95o F)
Humidity
Operating: 20 to 80% non-condensing
Certification and compliance
UL/CSA/CUL approval, MPR-II compliant
Compatibility
Recommended for use with HP products.
Software Overview
HP Display LiteSaver
HP Display LiteSaver feature lets you schedule Sleep mode at preset times to help protect the display against phosphor burn, drastically lower power consumption and energy costs, and extend the lifespan of the monitor.
Link to Warranty Information
Click here for additional information regarding worldwide limited warranty and technical support available at: http://h18004.www1.hp.com/products/servers/platforms/warranty/index.html.
