HP LaserJet 4250 and 4350 Series Printers - Understanding Printer Error Messages (CPMD)
Printer messages appear on the printer control panel display to relay the normal status of the printer (such as Processing...) or an error condition (such as CLOSE TOP COVER) that needs attention. The document, Interpreting control-panel messages , lists the most common messages that require attention or that might raise questions. Messages are listed in alphabetical order first, with numeric messages at the end of the list.
Using the printer online Help system
This printer features an online Help system on the control panel that provides instructions for resolving most printer errors. Certain control panel messages alternate with instructions about gaining access to the online Help system.
Whenever a message alternates with For help press, press Product illustration (Help button) to view the help and use Product illustration (Up button) and Product illustration (Down button) to scroll through the message.
To exit the online Help system, press Menu.
Resolving persistent messages
Some messages (for example, requests to load a tray or a message that a previous print job is still in the printer memory) allow you to press Product illustration (Select button) to print, or to press Stop to clear the job and eliminate the message.
If a message persists after performing all of the recommended actions, contact an HP-authorized service or support provider. (http://www.hp.com/support/lj4250 or http://www.hp.com/support/lj4350.)
Control panel message
Recommended action
Access denied
MENUS LOCKED
The printer control panel function you are trying to use has been locked to prevent unauthorized access.
See your network administrator.
BAD DUPLEXER
CONNECTION
For help press
The optional duplexer is not properly connected to the printer.
Make sure that you are using the right-angle power cord that came with the printer.
Try removing and reinstalling the optional duplexer. Then turn the printer power off and back on.
BAD ENV FEEDER
CONNECTION
The optional envelope feeder is not connected properly to the printer.
Try removing and reinstalling the optional envelope feeder. Then, turn the printer power off and back on.
<BINNAME> FULL
Remove all paper
from bin
The indicated output bin [BINNAME] is full, and printing cannot continue.
Empty the bin so that the current print job can finish.
<BINNAME> FULL
Remove all paper
from bin
alternates with
<current status
message>
The indicated output bin [BINNAME] is full, but it is not needed for the current print job.
Empty the bin before sending a job to that bin.
Canceling...
The printer is canceling a job. The message continues while the job is stopped, the paper path is cleared, and any remaining incoming data on the active data channel is received and discarded.
No action necessary.
CARD SLOT X DEVICE
FAILURE
To clear pressProduct illustration
alternates with
<current status
message>
The CompactFlash card in slot X had a critical failure and can no longer be used.
Remove the card and replace it with a new one. (See Printer memory.)
CARD SLOT X FILE
OPERATION FAILED
To clear press Product illustration
alternates with
<current status
message>
The requested operation could not be performed. You might have attempted an illegal operation, such as trying to download a file to a non-existent folder.
Try printing again to an existing folder.
CARD SLOT X FILE
SYSTEM IS FULL
alternates with
<current status
message>
The CompactFlash card in slot X is full.
Delete files from the CompactFlash card and then try again. Use the Device Storage Manager in HP Web Jetadmin to download or delete files and fonts. (See the HP Web Jetadmin software Help for more information.)
CARD SLOT X IS
WRITE PROTECTED
alternates with
<current status
message>
The CompactFlash card in slot X is protected, and no new files can be written to it.
Use the Device Storage Manager in HP Web Jetadmin to disable the write protection.
CARD SLOT <X>
NOT FUNCTIONAL
For help press
alternates with
<current status
message>
The CompactFlash card in slot X is not working correctly.
Turn the printer power off.
Make sure the card is inserted correctly.
If the printer control panel message continues to appear, the card needs to be replaced.
CARD SLOT X NOT
INITIALIZED
alternates with
<current status
message>
The file system has not been initialized.
Use HP Web Jetadmin to initialize the file system.
Checking paper path
The printer is checking for possible jams or paper that was not cleared from the printer.
Checking printer
CHOSEN PERSONALITY
NOT AVAILABLE
To continue press Product illustration
alternates with
CHOSEN PERSONALITY
NOT AVAILABLE
For help press Product illustration
The printer received a request for a personality (printer language) that does not exist in the printer. The print job is canceled.
Print the job using a printer driver for a different printer language, or add the requested language to the printer (if available).
To see a list of available personalities, print a configuration page.
CLEANING DISK
<X>% COMPLETE
Do not power off
alternates with
CLEANING DISK
<X>% COMPLETE
Storage device being sanitized or cleaned. Do not turn off. Product functions are unavailable. The printer will automatically restart when finished.
CLEANING PAGE ERROR
Open rear bin
You have attempted to create or process a cleaning page when a duplexer is present and the rear door is closed.
Open the rear output bin to begin creating or processing the cleaning page.
Clearing paper path
The printer jammed or the printer was turned on and media was detected in a wrong location. The printer is automatically attempting to eject the pages.
Wait for the printer to finish trying to clear the pages. If it cannot, a jam message will appear on the control panel display.
CORRUPT FIRMWARE IN EXTERNAL ACCESSORY
For help press
The printer detected corrupt firmware in an input or output accessory.
Printing can continue, but jams might occur. To view instructions for upgrading the firmware and to download the firmware upgrade, go to http://www.hp.com/support/lj4250 or http://www.hp.com/support/lj4350.
DATA RECEIVED
To print last page
press
alternates with
<current status
message>
The printer is waiting for the command to print (such as waiting for a form feed, or when the print job is paused).
Press Product illustration (Select button) to continue.
DIFFERENT PAPER
SIZES IN JOB
The stapler cannot align the paper for stapling if different paper sizes are in the job. Printing continues but the job is not stapled.
If stapling is required, modify the job.
DUPLEXER ERROR
REMOVE DUPLEXER
Install duplexer
with power off
The optional duplexer has an error.
Turn off the printer power and reattach the optional duplexer. (Any print jobs at the printer might be lost.)
EIO X DISK DEVICE
FAILURE
alternates with
<current status
message>
The EIO disk had a critical failure and can no longer be used.
Remove the EIO disk and replace it with a new one.
EIO X DISK FILE
OPERATION FAILED
alternates with
<current status
message>
EIO X DISK FILE
SYSTEM IS FULL
alternates with
<current status
message>
The EIO disk is full.
Delete files from the EIO disk and then try again. Use the Device Storage Manager in HP Web Jetadmin to download or delete files and fonts.
EIO X DISK IS
WRITE PROTECTED
alternates with
<current status
message>
The EIO disk is protected, and no new files can be written to it.
EIO X DISK
NOT FUNCTIONAL
The EIO disk in slot X is not working correctly.
Make sure the EIO disk is inserted correctly and securely fastened.
If the printer control panel message continues to appear, the optional hard disk needs to be replaced.
EIO X DISK NOT
INITIALIZED
alternates with
<current status
message>
EIO X disk
spinning up
The disk accessory in EIO slot [X] is initializing.
ENVELOPE FEEDER
EMPTY
alternates with
<current status
message>
The envelope feeder is empty.
Load envelopes in the envelope feeder.
Event log empty
You are attempting to view an empty event log by selecting SHOW EVENT LOG from the control panel.
INSERT OR CLOSE
TRAY XX
The specified tray is open or missing.
Insert or close the tray for printing to continue.
INSTALL CARTRIDGE
The print cartridge is missing and must be reinstalled for printing to continue.
Replace or correctly reinstall the print cartridge.
INSUFFICIENT MEMORY
TO LOAD FONTS/DATA .
alternates with
<DEVICE>
The printer received more data than can fit in its available memory. You might have tried to transfer too many macros, soft fonts, or complex graphics.
Press Product illustration (Select button) to print the transferred data (some data might be lost).
To solve this problem, simplify the print job or install additional memory.
INTERNAL DISK
DEVICE FAILURE
alternates with
<current status
message>
The disk had a critical failure and can no longer be used.
Contact an HP-authorized service or support provider.
INTERNAL DISK FILE
OPERATION FAILED
alternates with
<current status
message>
INTERNAL DISK FILE
SYSTEM IS FULL
alternates with
<current status
message>
The Internal disk is full.
Delete files from the disk and then try again. Use the Device Storage Manager in HP Web Jetadmin to download or delete files and fonts.
INTERNAL DISK IS
WRITE PROTECTED
alternates with
<current status
message>
The disk is protected, and no new files can be written to it.
INTERNAL DISK NOT
INITIALIZED
alternates with
<current status
message>
LOAD TRAY XX
[TYPE][SIZE]
For help press
The tray that is indicated is configured for a specific type and size of media needed by a print job, but the tray is empty. All other trays are also empty.
Load the requested media in the tray that is indicated.
LOAD TRAY XX
[TYPE][SIZE]
alternates with
LOAD TRAY XX
[TYPE][SIZE]
A job is sent that requires a specific type and size that is not available in the tray that is indicated.
Load the requested media into the indicated tray and press Product illustration (Select button).
LOAD TRAY XX
[TYPE][SIZE]
alternates with
To use another
tray pressProduct illustration
Press Product illustration (Select button) to use a type and size that are available in another tray.
LOAD TRAY XX
[TYPE][SIZE]
alternates with
Move tray switch to
CUSTOM
Move the tray switch to the CUSTOM position if another tray is available.
LOAD TRAY XX
[TYPE][SIZE]
alternates with
Recommend move tray
switch to STANDARD
If the size is detectable and another tray is available, move the switch to the STANDARD position.
MANUALLY FEED
OUTPUT STACK
Then press Product illustration to
print second sides
The first side of a manual duplex job has been printed and the device is waiting for you to insert the output stack to complete the second side.
Load the output stack into tray 1, maintaining the same orientation with printed side down.
To continue printing, press Product illustration (Select button) to exit the printer message and then press Product illustration (Select button) to print.
MANUALLY FEED
[TYPE][SIZE]
To use another
tray press Product illustration
The printer is waiting for media to be loaded in tray 1 for manual feed.
MANUALLY FEED
[TYPE][SIZE]
alternates with
MANUALLY FEED
[TYPE][SIZE]
Load the requested media into tray 1 and press Product illustration (Select button).
No job to cancel
The Stop button was pressed, but there is no active job or buffered data to cancel.
The message is displayed for approximately 2 seconds before the printer returns to the ready state.
NON HP SUPPLY
INSTALLED
Economode disabled
The printer has detected that the print cartridge is not a genuine HP supply.
This message is displayed until you install an HP cartridge or press the override button Product illustration (Select button).
If you believe you purchased a genuine HP supply, go to http://www.hp.com/go/anticounterfeit.
Any printer repair required as a result of using non-HP supplies or unauthorized supplies is not covered under the printer warranty.
NON HP SUPPLY
INSTALLED
ORDER CARTRIDGE
LESS THAN XXXX PAGES
alternates with
<current status
message>
For the HP LaserJet 4250 series, the message first appears when about 15% (10,000-page cartridge) or about 8% (20,000-page cartridge) of the life remains in the print cartridge. For the HP LaserJet 4350 series, the message first appears when about 25% (10,000-page cartridge) or about 15% (20,000-page cartridge) of the life remains in the print cartridge.
Make sure that you have a new cartridge ready.
OUTPUT PAPER PATH
OPEN
The paper path between the printer and the output device is open and must be closed before printing can continue.
Make sure the jam-access door on the optional stacker or stapler/stacker is closed.
If the accessory is a stapler/stacker, make sure that the stapler unit is snapped into the closed position.
Paused
To return to ready
press STOP
The printer is paused but continues to receive data until the memory is full. The printer is not experiencing an error.
Press Stop.
RAM DISK DEVICE
FAILURE
alternates with
<current status
message>
The RAM disk had a critical failure and can no longer be used.
RAM DISK FILE
OPERATION FAILED
alternates with
<current status
message>
The requested operation could not be performed. You might have attempted an illegal operation, such as trying to download a file to a non existent folder.
RAM DISK FILE
SYSTEM IS FULL
alternates with
<current status
message>
The RAM disk is full.
Delete files and then try again, or turn the printer power off, and then turn the printer power on to delete all files on the device. (Use Device Storage Manager in HP Web Jetadmin or another software utility to delete the files.
If the message persists, increase the size of the RAM disk. Change the RAM disk size on the System Setup submenu (on the Configure Device menu) at the printer control panel. See the description of the RAM disk menu items in System Setup submenu.
RAM DISK IS
WRITE PROTECTED
alternates with
<current status
message>
The RAM disk is protected, and no new files can be written to it.
RAM DISK NOT
INITIALIZED
alternates with
<current status
message>
REINSERT DUPLEXER
The duplexer has been removed.
Reinsert the duplexer.
REPLACE CARTRIDGE
Pages remaining for this supply has reached the low threshold. The printer was set to continue printing when a supply needs to be ordered.
Press Product illustration (Select button) to continue printing the current job.
Follow the next steps to replace the supply.
Open the top cover.
Remove print cartridge.
Install new print cartridge.
Close the top cover.
REPLACE CARTRIDGE
alternates with
<current status
message>
Pages remaining for this supply has reached the low threshold. The printer was set to stop printing when a supply needs to be ordered.
To continue printing, press Product illustration (Select button) to exit the printer message then press Product illustration (Select button). The message becomes ORDER CARTRIDGE LESS THAN XXXX PAGES (warning).
Open the top cover.
ROM DISK DEVICE
FAILURE
alternates with
<current status
message>
The ROM disk had a critical failure and can no longer be used.
Contact an HP authorized service or support provider.
ROM DISK FILE
OPERATION FAILED
alternates with
<current status
message>
ROM DISK FILE
SYSTEM IS FULL
alternates with
<current status
message>
The ROM disk is full.
ROM DISK IS
WRITE PROTECTED
alternates with
<current status
message>
ROM DISK NOT
INITIALIZED
alternates with
<current status
message>
SANITIZING DISK
<X>% COMPLETE
Do not power off
alternates with
CLEANING DISK
<X>% COMPLETE
A hard disk or a CompactFlash card is being sanitized.
SIZE MISMATCH IN
TRAY XX
alternates with
<current status
message>
The tray indicated is loaded with a different size of paper than the size configured for the tray.
Load the tray with the size configured for the tray.
Make sure that the guides are positioned correctly in the tray, and then make sure that the knob is set correctly to Standard or Custom.
STAPLER LOW
ON STAPLES
Fewer than 70 staples remain in the optional stapler/stacker cartridge. Printing continues until the cartridge runs out of staples, and the STAPLER OUT OF STAPLES message appears on the printer control panel display.
Replace the staple cartridge.
STAPLER OUT OF
STAPLES
The stapler in the optional stapler/stacker is out of staples. The printer behavior depends on how STAPLES OUT is configured in the Output Setup submenu.
If STAPLES OUT=STOP, the printer stops printing until you refill the stapler or press Select. This is the default setting.
If STAPLES OUT=CONTINUE, printing continues, but the job is not stapled.
Replace the staple cartridge..
TRAY XX EMPTY
[TYPE][SIZE]
alternates with
<current status
message>
The specified paper tray is empty.
Load paper in the empty tray [XX] to clear the message.
If you do not load the specified tray, the printer will continue printing from the next tray with the same paper size and type, and the message will continue to appear.
TRAY XX OPEN
For help pressProduct illustration
alternates with
<current status
message>
The tray cannot feed paper to the printer because tray [X] is open and must be closed for printing to continue.
Check the trays and close any that are open.
TRAY XX
[TYPE][SIZE]
To change size or
type press Product illustration
alternates with
TRAY XX
[TYPE][SIZE]
To accept settings
press
This message states the current type and size configuration of the paper tray, and allows you to change the configuration.
To change the paper size or type pressProduct illustration (Select button) while the message is present. To clear the message, press the Product illustration (Back button) while the message is present.
Set size and type to ANY if the tray is used frequently for different sizes or types.
Set size and type to a specific setting if printing with only one type of paper.
TOO MANY PAGES
IN JOB TO
STAPLE
The maximum number of sheets the stapler can staple is 15. The print job finishes printing but is not stapled.
For print jobs that have more than 15 pages, staple them manually.
Unable to mopy job
<JOBNAME>
alternates with
<current status
message>
Memory or file system failures would not allow a mopy job to occur. Only one copy will be produced.
Correct the error and then try again to store the job.
Unable to store job
<JOBNAME>
alternates with
<current status
message>
The print job named cannot be stored due to a memory, disk, or configuration problem.
UNSUPPORTED DATA ON
[FS] DIMM IN SLOT X
The data on the DIMM is not supported. [FS] stands for either ROM or FLASH.
The DIMM may need to be replaced. Turn the printer power off before removing it.
USE TRAY XX
[TYPE][SIZE]
To change press Product illustration /Product illustration
To use press Product illustration
The printer did not detect the type and size of media requested. The message shows the most likely type and size available and the tray in which they are available.
Press Product illustration (Select button) to accept the values in the message, or use Product illustration (Up button) and Product illustration (Down button) to scroll through the available choices.
WAITING FOR
TRAY XX TO LIFT
alternates with
<current status
message>
The specified tray is in the process of lifting the paper to the top of the tray for proper feeding.
WARMING UP
alternates with
<current status
message>
The printer is coming out of powersave mode. Printing will continue as soon as it is done.
10.XX.YY SUPPLY
MEMORY ERROR
An error has occurred in one or more of the printer's supplies. Values of XX and YY are listed below:
XX00 = memory is defective
XX01 = memory is missing
YY00 = black print cartridge
Turn the printer power off, and then turn the printer power on to clear the message.
This is typically an e-label issue. The printer will continue to print after pressing the green SELECT button. The consumable management features will be lost (such as the gas gauge, cartridge page count, estimated pages remaining, etcetera) and the control panel may report that the printer has a non-HP print cartridge installed; however, the product will continue to print without problem until the toner runs out and the pages begin to fade, then the print cartridge may be replaced as usual.
If this workaround is not acceptable or the error message persists after performing all of the recommended actions, contact an authorized HP Service or Support Provider: http://www.hp.com/go/support
10.32.00
UNAUTHORIZED SUPPLY
The printer has detected that a printer supply is not a genuine HP supply.
This message is displayed until you install an HP supply or press the override button Product illustration (Select button), (which may void the printer warranty).
If you believe you purchased an HP supply, go to http://www.hp.com/go/anticounterfeit.
13.XX.YY JAM IN
<Location>
A jam has occurred in the specified location.
Remove jammed media from the specified location. .
If the message persists after all jams have been cleared, a sensor might be stuck or broken. Contact an HP-authorized service or support provider.
20 INSUFFICIENT
MEMORY
alternates with
20 INSUFFICIENT
MEMORY
Press Product illustration (Select button) to print the transferred data (some data might be lost), and then simplify the print job or install additional memory.
21 PAGE TOO COMPLEX
alternates with
21 PAGE TOO COMPLEX
The data (dense text, rules, raster or vector graphics) sent to the printer was too complex.
If this message appears often, simplify the print job or install additional memory.
22 EIO X
BUFFER OVERFLOW
Too much data was sent to the EIO card in the specified slot [X]. An improper communications protocol might be in use.
Note: EIO 0 is reserved for the HP Jetdirect embedded print server.
Press Product illustration (Select button) to clear the message. (The job will not be printed.)
Check the host configuration. If the message persists, contact an HP-authorized service or support provider.
22 PARALLEL I/O
BUFFER OVERFLOW
alternates with
22 PARALLEL I/O
BUFFER OVERFLOW
Too much data was sent to the parallel port.
Check for a loose cable connection and be sure to use a high-quality cable. Some non-HP parallel cables might be missing pin connections or might otherwise not conform to the IEEE-1284 specification.
This error can occur if the driver you are using is not IEEE-1284 compliant. For best results, use an HP driver that came with the printer.
Press Product illustration (Select button) to clear the error message. (The job will not be printed.)
22 USB I/O
BUFFER OVERFLOW
Too much data was sent to the USB port.
40 EIO X BAD
TRANSMISSION
The connection has been broken between the printer and the EIO card in the specified slot [X].
Press Product illustration (Select button) to clear the error message and continue printing.
41.X ERROR
alternates with
41.X ERROR
A temporary printing error occurred.
Press Product illustration (Select button). The page containing the error automatically reprints if jam recovery is enabled.
Turn the printer power off, and then turn the printer power on.
41.3 UNEXPECTED
SIZE IN TRAY X
alternates with
LOAD TRAY XX
[TYPE][SIZE]
To use another
or
This is typically caused if two or more sheets stick together in the printer or if the tray is not properly adjusted.
Reload the tray with the correct paper size.
Press Product illustration (Select button) to scroll to TRAY XX SIZE=. Reconfigure the size in a tray so that the printer will use a tray that contains the size required for the print job.
If the error does not clear, turn the printer power off, then turn the printer power on.
49.XXXXX ERROR
To continue
turn off then on
A critical firmware error has occurred.
Turn the printer power off, leave it off for 20 minutes, and then turn the printer power on.
50.X FUSER ERROR
A fuser error has occurred.
Turn the printer power off and then on.
51.XY ERROR
alternates with
51.XY ERROR
To continue
turn off then on
52.XY ERROR
alternates with
52.XY ERROR
To continue
turn off then on
53.XY.ZZ CHECK RAM
DIMM SLOT <X>
To continue
press
There is a problem with the printer memory. The DIMM that caused the error will not be used.
You will be prompted to press Product illustration (Select button) to continue in the following cases:
1 or 2 DIMMs where the only error is ZZ=04
2 DIMMs where one is good and the other has an error with ZZ=01, 02, 03, or 05
2 DIMMs where one has an error with ZZ=04 and the other has an error with ZZ=01, 02, 03, or 05
Values of X and Y are as follows:
X = DIMM type, 0 = ROM, 1 = RAM
Y = Device location, 0 = Internal memory (ROM or RAM), 1 or 2 = DIMM slot 1 or 2
If the message continues, you might need to replace the specified DIMM. Turn the printer power off, and then replace the DIMM that caused the error.
54.XX ERROR
To continue
turn off then on
This message is typically related to a sensor issue.
If error reappears, record message and contact an HP-authorized service or support provider (see HP customer care .
55.XX.YY DC
CONTROLLER ERROR
alternates with
55.XX.YY DC
CONTROLLER ERROR
To continue
turn off then on
56.XX ERROR
alternates with
56.XX ERROR
To continue
turn off then on
A temporary printing error occurred as a result of an incorrect input or output request.
57.XX ERROR
alternates with
57.XX ERROR
To continue
turn off then on
A temporary printing error occurred in one of the printer fans.
58.XX ERROR
alternates with
58.XX ERROR
To continue
turn off then on
A printer error has occurred where a memory tag CPU error was detected, or there is a problem with the air sensor or power supply.
To resolve problems with the power supply:
Remove the printer from any UPS supplies, additional power supplies, or power strips. Plug the printer into a wall outlet and see if this resolves the problem.
If the printer is already plugged into a wall outlet, try another power source in the building that is independent of the one currently being used.
The line voltage and current source at the printer location might need to be inspected to ensure that they meet the electrical specifications for the printer.
59.XY ERROR
alternates with
59.XY ERROR
To continue
turn off then on
62 NO SYSTEM
To continue
turn off then on
This message indicates that no system was found. The printer software system is corrupt.
64 ERROR
alternates with
64 ERROR
To continue
turn off then on
A temporary printing error occurred in the scan buffer.
If the message persists, contact an HP-authorized service or support provider .
66.XY.ZZ EXTERNAL
DEVICE FAILURE
An error occurred between the printer and an external paper-handling accessory.
Check that the accessory is properly seated on and connected to the printer, without any gaps between the printer and the accessory. If the accessory uses cables, disconnect and reconnect them.
Turn the printer power on.
If the error reappears, record the message, and contact HP Customer Support.
66.XY.ZZ INPUT
DEVICE FAILURE
An error occurred in an external paper-handling accessory.
66.XY.ZZ OUTPUT
DEVICE FAILURE
68.X STORAGE ERROR
SETTINGS CHANGED
alternates with
68.X STORAGE ERROR
SETTINGS CHANGED
An error occurred in the printer permanent storage and one or more printer settings has been reset to its factory default.
Press Product illustration (Select button) to clear the message, and press Product illustration (Select button) to resume printing.
Print a configuration page and check the printer settings to determine which values have changed.
If the error does not clear, turn printer off then on. If the error reappears, record the message and contact an HP-authorized service or support provider .
68.X PERMANENT
STORAGE FULL
alternates with
68.X PERMANENT
STORAGE FULL
The printer permanent storage is full. Some settings might have been reset to the factory defaults.
Turn the printer power off, then press and hold Menu while turning the printer on to clean up permanent storage.
68.X PERMANENT
STORAGE WRITE FAIL
The storage device is failing to write. Printing can continue, but there might be some unexpected behaviors because an error occurred in permanent storage.
If the error does not clear, turn the printer off then on. If error reappears, record the message and contact an HP-authorized service or support provider.
69.X ERROR
For help press
alternates with
69.X ERROR
To continue
turn off then on
A printing error occurred.
79.XXXX ERROR
To continue
turn off then on
The printer detected a critical hardware error.
Press Stop to clear the print job from the printer memory. Turn the printer power off and then on.
Try printing a job from a different program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain program or print job, contact the software vendor for assistance.
If the message persists with different programs and print jobs, try these steps.
Disconnect all cables to the printer that connect it to the network or computer.
Remove all the memory DIMMs or third-party DIMMs from the printer. Then reinstall at least one memory DIMM .
Remove all EIO devices and CompactFlash cards from the printer.
If the error no longer exists, follow these steps.
Install each DIMM and EIO device one at a time, making sure to turn the printer power off and back on as you install each device.
Replace a DIMM or EIO device if you determine that it causes the error.
Reconnect all cables that connect the printer to the network or computer.
8X.YYYY
EIO ERROR
The EIO accessory card in slot [X] has encountered a critical error.
Turn the printer power off, reseat the EIO accessory in slot [X], and then turn the printer power on.
Turn the printer power off, remove the EIO accessory from slot [X], install it in a different EIO slot, and then turn the printer power on.
Replace the EIO accessory in slot [X].
8X.YYYY EMBEDDED
JETDIRECT ERROR
The embedded HP Jetdirect print server has encountered a critical error.
11.01 = Dead clock battery
11.02 = Dead real-time clock
This message is displayed when there is a problem with the real-time clock on the formatter board.
Contact HP Support.
