HP Designjet 4000 Printer Series - How to Print Internal Test Prints
The internal prints give various kinds of information about your printer. They can be requested from the front panel without using a computer.
Before requesting any internal print, make sure that paper is loaded (roll or sheet), and that the front panel displays the Ready message.
To print any internal print, follow the instructions below:
  1. Using the Arrow keys, Highlight the (printer) icon, and press the Select key .
  2. Scroll to Information, and press the Select key.
  3. Scroll to Internal prints, and press the Select key.
  4. Scroll to the desired Internal print, and press the Select key to start the print.
The following internal prints are available:
  • Demo - shows some of the capabilities of the printer.
  • Menu map - shows details of all the front panel menus.
  • Configuration - shows all the current front panel settings.
  • Usage report - shows estimates of the total number of prints, number of prints by paper type, number of prints by print quality option, and total amount of ink used per color.
  • HP-GL/2 palette - shows the color or grayscale definitions in the currently-selected color palette.
  • PostScript font list - lists the PostScript fonts installed in the printer (PostScript printers only).
  • Image diagnostics - helps you to solve print quality problems.
    Click here for information on how to print and interperet the Diagnositcs print at http://www.hp.com/cposupport/printers/support_doc/c00263430.html
  • Service information - provides information needed by service engineers.
