HP Designjet 4000 Printer Series - Product Specifications
Functional Specifications
HP No. 90 ink supplies
Printheads
Yellow, magenta, black, and cyan (two of each)
Printhead cleaners
Ink cartridges
Yellow, magenta, and cyan cartridges containing 225 or 400 ml (cm3) of ink, and a black cartridge containing 400 ml of ink
Paper sizes
Minimum
Maximum
Width
11 in (279 mm)
42 in (1.066 m)
Length
16.5 in (420 mm)
60 in (1.5 m) for sheet and 300 ft (90 m) for roll
Print resolution
Print quality
Max detail
Optimized for lines and text
Optimized for images
Rendering resolution (dpi)
Printing resolution (dpi)
Best
On
1200 x 1200
2400 x 1200 (High- Gloss Photo Paper, Canvas)
1200 x 1200 (other papers)
1200 x 1200
2400 x 1200 (Productivity Photo Gloss, High-Gloss Photo Paper, Canvas)
Off
600 x 600
1200 x 1200 (High Gloss Photo Paper, Canvas)
1200 x 600 (other papers)
600 x 600
Normal
On
600 x 600
1200 x 600 (other paper types)
600 x 600
Off
600 x 600
300 x 300
1200 x 1200 (Productivity Photo Gloss, High Gloss Photo Paper, Canvas)
Fast
On
600 x 600
1200 x 1200 (High Gloss Photo Paper)
600 x 600
600 x 600 (Max Speed, Bright White, Bond Paper)
Off
300 x 300
600 x 600 (Max Speed)
300 x 300
Margins
Side margins
Normal 5 mm (.19 inch)
Extended 15 mm (.59 inch)
Top margin (leading edge)
Normal 11.5 mm (.45 inch)
Extended 55 mm (2.16 inches)
Bottom margin (trailing edge)
Roll 5 mm (.19 inch)
Sheet, Normal 25 mm (.98 inch)
Sheet, Extended55 mm (2.16 inches)
Mechanical accuracy
Plus or minus 0.1% of the specified vector length or plus or minus 0.1 mm (whichever greater) at 23 degressC (73 degress F), 50-60% relative humidity, on A0 printing material in Best or Normal mode with HP Matte Film.
Graphic languages supported
HP Designjet 4000 and 4000ps Printers
HP-GL/2, RTL, TIFF, JPEG, CALS G4
HP Designjet 4000ps Printer only
Adobe PostScript level 3, PDF 1.5
Physical Specifications
Weight (including stand)
115 kg (253.5 lbs)
Width
Less than 1930 mm (76 inches)
Depth
Less than 800 mm (31.5 inches)
Height
1350 mm (53.1 inches)
System Specifications
Windows Minimum system configuration
  • Microsoft Windows 98, Me - Pentium I, 133 MHz, 48 MB RAM, 300 MB available hard disk space
  • Windows NT 4.0 - Pentium II, 300 MHz, 64 MB RAM, 400 MB available hard disk space
  • Windows 2000, 2003 Server - Pentium II, 300 MHz, 128 MB RAM, 400 MB available hard disk space
  • Windows XP - Pentium III, 733 MHz, 128 MB RAM, 400 MB available hard disk space
Windows Recommended system configuration
  • Microsoft Windows 98, Me - Pentium I, 133 MHz, 64 MB RAM, 320 MB available hard disk space
  • Windows NT 4.0 - Pentium III, 733 MHz, 128 MB RAM, 2 GB available hard disk space
  • Windows 2000, 2003 Server - Pentium III, 733 MHz, 256 MB RAM, 2 GB available hard disk space
  • Windows XP - Pentium IV, 1 GHz, 256 MB RAM, 2 GB available hard disk space
Mac Minimum system configuration
  • iMac G3, G4, G5 dual processor, iBook, PowerBook, eMac
  • Mac OS 9.1, OS X v 10.1.5
  • 128 MB RAM, 256 MB available hard disk space
Mac Recommended system configuration
  • 1 GHz PowerPC G4
  • Mac OS 9 v 9.2, Mac OS X v 10.1.5, 10.2.2 and higher 10.3
  • 256 MB, 512 MB available hard disk space
Memory Specifications
Memory (DRAM) supplied - DDR SDRAM (266MHz)
256 MB
Memory (DRAM) maximum - DDR SDRAM (266MHz)
512 MB
Hard disk
40 GB
Electrical Specifications
Source
100-240 V ac, plus or minus 10%, autoranging
Frequency
50-60 Hz
Current
< 6 A
Consumption
< 1 kW
Power consumption
Maximum
500 watts
Standby
105 watts
Power requirements
Input voltage 100 to 127/220 to 240 VAC (+/- 10%) auto range, 6/3 amp maximum, 50/60 Hz (+/- 3 Hz)
Power certification
Safety certification
Compliant with IEC 60950, including EU LVD and EN60950, CSA certified for US and Canada, Mexico NYCE, Argentina IRAM, Singapore PSB, Russia VNIIS, Poland EL TEST
Electromagnetic compatibility
Compliant with Class A requirements including EU (EMC Directive), USA (FCC rules), Canada (DoC), Australia (ACA), New Zealand (MoC0, Japan (VCCI), Korea (MIC), Taiwan (BSMI)
Energy Star compilant
Yes
Environmental Specifications
Operating humidity
20 to 80% RH, depending on paper type
Recommended humidity
25 to 75% RH
Recommended operating temperature
15 to 30 degrees C (59 to 86 degrees F), depending on paper type
Operating temperature
5 to 40 degrees C (41 to 104 degress F)
Storage temperature
-20 to +50 degrees C (-4 to 131 degrees F)
Maximum altitude
3000 m (9843 ft)
Acoustic Specifications
Idle sound power
(less than or equal to) 5.7 B (A)
Operating sound power
(less than or equal to) 7.0 B (A)
Idle sound pressure
(less than or equal to) 39 dB (A)
Operating sound pressure
(less than or equal to) 53 dB (A)
Ecological Specifications
For the up-to-date ecological specifications of your printer, click here go to http://www.hp.com/ and search for “ecological specifications”.
Product Overview Information
Click here for product overview information at http://www.hp.com/cposupport/printers/support_doc/c00261952.html.
