HP Scanjet 7650 Document Flatbed Scanner Series - Product Specifications and Minimum System Requirements
This document contains the regulatory and product specifications for the HP Scanjet 7650 Document Flatbed scanner, the Automatic Document Feeder (ADF), and the Transparent Materials Adapter (TMA).
Scanner specifications
The following specifications refer to the scanner only and not the TMA or ADF.
Name
Scanner type
Flatbed with ADF and TMA
Weight (with ADF)
5.7 kg (12.6 pounds)
Size with ADF
488 x 340 x 162 mm (19.21 x 13.39 x 6.38 inches)
Scanning element
Charged-coupled device
Interface
USB 2.0 Hi-Speed
Optical resolution
2400 x 2400 dpi hardware
Selectable resolution
12 dpi to 999,999 enhanced dpi at 100 percent scaling
AC line voltage
  • 100-120 V 60 Hz - North America
  • 200-240 V 50 Hz - Continental Europe, United Kingdom, Australia
  • 100-240 V 50 Hz/60 Hz - Rest of the world
Power consumption
For power consumption data, see the regulatory_supplement.htm file on the HP Image Zone software CD.
Energy Star
The HP Scanjet 7600 series scanner is Energy Star compliant. As an Energy Star partner, Hewlett-Packard Company has determined that this product meets the Energy Star guidelines for energy efficiency.
Transparent Materials Adapter (TMA) specifications
The following specifications refer to the Transparent Materials Adapter (TMA) and not the scanner or ADF.
Name
Media types
Three 35 mm slides or one 35 mm negative strip
Media capacity
Slides: 1.05 mm to 1.9 mm thick and 49.8 mm to 50.8 mm on any side
Size
287 x 84 x 50 mm (11.3 x 3.3 x 1.97 inches)
346 g (0.763 pounds)
Power requirements
1.0 Amps, 24 Volts, 24 watts < (supplied by scanner)
925 mA, 22 watts (peak) 700 mA, 17 watts (nominal)
Automatic Document Feeder (ADF) specifications
The following specifications refer to the Automatic Document Feeder (ADF) and not the scanner or TMA.
Name
Size
475 x 320 x 92 mm (18.7 x 12.6 x 3.6 inches)
2.46 kg (5.4 pounds)
Paper tray capacity
50 pieces of 75 g/m2 (20-pound bond)
Maximum paper size
One sided scanning: 210 x 355.6 mm (8.5 x 14 inches)
Two sided scanning: 210 x 304.8 mm (8.5 x 12 inches)
Minimum paper size
One sided scanning: 89 x 127 mm (3.5 x 5 inches)
Two sided scanning: 127 x 127 mm (5 x 5 inches)
Maximum paper weight
90 g/m2 (24 pounds)
Power requirements
1.0 A, 24 V, 32 watts (supplied by scanner)
800 mA, 19 watts (peak) 625 mA, 15 watts (nominal)
Environmental specifications
Name
Temperature
Operating the scanner and TMA: 10 to 35 degrees C (50 to 95 degrees F)
Operating the ADF: 10 to 30 degrees C (50 to 85 degrees F)
Storage: -40 to 60 degrees C (-40 to 140 degrees F)
Relative humidity
Operating: 15 percent to 80 percent non-condensing 10 to 35 degrees C (50 to 95 degrees F)
Storage: up to 90 percent at 0 to 65 degrees C (32 to 149 degrees F)
Minimum system requirements
Windows minimum system requirements
Macintosh minimum system requirements
Computer with Pentium II or Celeron 266 MHz processor (Pentium III or higher recommended)
64 MB RAM (128 MB RAM recommended)
Windows 98, 98SE, Me, 2000 Pro (Requires SP2 or higher), and Windows XP
175 MB free disk space, plus 50 MB for full-color scanning
4x CD-ROM drive (Sound Card, Internet Access, IE 5.0 or higher recommended)
800 x 600 SVGA (24-bit color recommended)
USB Port (USB 2.0 Compatible)
HP Memories Disc Creator software requires CD writer and 700 MB additional disk space
USB-compatible Macintosh G3 with 350 MHz or higher processor
128 MB RAM OS X
OS X 10.2.x, 10.3.x, 10.4.x, or higher
240 MB free disk space
HP Photo and Imaging software requires 240 MB hard disk space
CD-ROM drive
800 x 600 SVGA Monitor (16-bit color)
USB port
