HP PSC 2350 Series All-in-One - Streaks or Lines in the Printed Image
Problem
The printer is working, but printed output shows streaks or lines. The lines are perpendicular to the direction the paper moved through the printer (and parallel to the movement of the cartridges during printing).
Figure : Defect, with the direction the paper moved through the printer indicated
If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  1. Open the Printer Toolbox. There are two ways to do this:
    • Open HP Director, select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox.
    • Open Printers and Faxes in the Windows Control Panel, then right-click your printer icon and choose Properties. Click Printing Preferences. Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
    Figure : Estimated ink levels
  1. In the program being used for printing, click File, and then click Print.
    The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties.
    The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab.
    Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality: If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type: If one of the options matches the paper type exactly, select it instead of Automatic.
    • Paper size: Make sure that this option matches the paper loaded in the product.
    To see additional options, click the Advanced tab, and then click Advanced Features.
    The Advanced Features window opens. Consider changing the following option:
    Ink volume: Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
  1. Press the Setup button.
  2. Use the arrow keys to select Tools and then press the OK button.
  3. Select Clean Print Cartridge and then press OK. The device prints a test page.
  4. Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.
  5. Open the Printer Toolbox. There are two ways to do this:
    • If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel, then right-click your printer icon and choose Properties. Click on Printing Preferences. Click the Services tab, then the Service This Device icon.
  6. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges, then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
Step 4 - Print a diagnostic page
If the steps above have not helped, you may have to replace a cartridge. Print and evaluate a diagnostic page to determine which cartridge to replace.
  1. Press the left arrow and right arrow simultaneously, then release both buttons.
  2. Press 1, 2, then 3. The Service menu appears.
  3. Press the right arrow twice. The Special Reports menu opens.
  4. Press OK.
  5. Press the right arrow once. The Print Cartridge menu opens.
  6. Press OK. The diagnostic page prints.
Identify which cartridge printed which part of the diagnostic page, so that if you find defects on the page, you know which cartridge is the problem.
However, you can install different combinations of ink cartridges in your printer, and different cartridge combinations print different diagnostic page patterns. The diagnostic page might not look exactly like the example presented here, but the right and left cartridges print in the same areas of the page no matter which cartridges are installed.
    Figure : Diagnostic page layout (the patterns in each area might look slightly different on your page)
  1. Printed by the right cartridge
  2. Printed by the left cartridge
If you are printing in reserve mode (one cartridge is missing), the area of the diagnostic page where that cartridge prints is blank.
In general, if the printer and print cartridges are working properly, the patterns (which look like grids of lines) should contain few or no missing lines. Also, the colors of the patterns and bars should be approximately the same as the color dots on the print cartridge label.
Do not compare the colors on your diagnostic page to the colors on this Web page. Unless your monitor is calibrated, the colors will not be correct. Instead, compare the colors on the page to the colors dots on the print cartridge label. While the color dots might not be perfectly accurate, they are likely to be more accurate than the colors on the monitor.
Missing lines or streaked bars
If a pattern shows more than a few missing lines, or a bar is streaked, that print cartridge is not functioning properly.
Figure : The right cartridge (a photo cartridge) shows missing lines and a streaked bar - the cartridge is not functioning properly
Figure : The left cartridge (a tri-color cartridge) shows missing lines and a streaked bar - the cartridge is not functioning properly
If your diagnostic page shows missing lines or streaked bars, click here to continue troubleshooting.
Color mix
If the color of the patterns or bars differs from the color dots on the cartridge label, the cartridge is not functioning properly.
Figure : Color dots on the left (tri-color) cartridge label
Figure : The color of one of the left cartridge bars is different from the color on the cartridge label - the cartridge is not functioning properly
If your diagnostic page shows colors that differ from the colors on the cartridge label, click here to continue troubleshooting.
Missing colors
If any of the color blocks or patterns is entirely missing, the cartridge is not functioning properly.
Figure : The yellow pattern and bar for the left (tri-color) cartridge is missing
If any of the patterns or color blocks is entirely missing, click here to continue troubleshooting.
Ink smears
If the diagnostic page shows smeared ink, you might need to clean your cartridges.
Figure : Left (black) cartridge shows smeared ink
If your diagnostic page shows smeared ink, click here to continue troubleshooting.
If no defects appear on the diagnostic page, the cartridges and product are probably working correctly. Click here to continue troubleshooting (c00211601) (in English).
