    Windows 11 Upgrade Guide
HP Designjet EFI Designer Edition RIP - Cannot Create Print File
Issue:
The EFI Designer Edition RIP is displaying the message cannot create print file.
The error messages displayed in the program window are preceded by the word "input," "color," "print," or "port" to indicate at which stage of processing the problem occurred.
Solution
  1. Delete the job from the program window.
  2. Make sure that you have selected a paper name in the Color pane. If no paper names are available, you may first need to search for paper profiles for the selected printer.
  3. Make sure that the bpl file for the selected paper name is available. The bpl files for default papers provided by EFI are saved in the "profiles" folder. If you are using paper profiles saved to a different location, you must check these folders also.
  4. Check the printer settings in the Printer pane.
  5. Reload the job and try again.
If the problem persists:
  • There may be insufficient space on the Hard Disk
  • The system maybe overloaded. Try restarting the computer and EFI Designer Edition.
Cause
EFI Designer Edition cannot find the required linearization (bpl) file.
