HP LaserJet 1320, 1320n, and 1320tn Printers - Product Specifications
Overview
This document provides detailed information about the HP LaserJet 1320, 1320n, and 1320tn printers which may include but is not limited to specifications regarding physical measurements, supported network operating systems, supplies life, electrical power and environmental requirements, sound emissions, FCC compliance, Declaration of Conformity, HP Environmental Product Stewardship information, and safety statements specific to countries or regions.
Physical specifications
Dimensions:
Width: 350 mm (16.8 inches)
Depth: 352 mm (13.9 inches)
Height: 256 mm (10.0 inches)
Weight (2,500-page cartridge installed):
HP LaserJet 1320 series printer: 11.3 kg (24.9 lb)
Values are subject to change. For the most current information, go to http://www.hp.com/support/lj1320/.
Electrical specifications
  warning:
Power requirements are based on the country/region where the printer is sold. Do not convert operating voltages. Doing so might damage the printer and void the product warranty.
HP LaserJet 1320 printer
Power requirements (110):
110-127v (+/-10%), 50/60 Hz (+/-2)
Power requirements (220):
220v-240v (+/-10%), 50/60 Hz (+/-2 Hz)
Power consumption:
During printing (22 ppm): 340 watts (average)
During Ready (Standby) and PowerSave*: 6 Watts
Off: Less than 1 watt(s)
Minimum recommended
circuit capacity for
typical product:
4.5 amps at 115 volts
2.6 amps at 230 volts
* Instant on fuser technology
HP LaserJet 1320n printer
Power consumption
During printing (22 ppm): 345 watts (average)
Minimum recommended
typical product:
HP LaserJet 1320tn printer
Power consumption:
Minimum recommended
typical product:
The power reported is the highest value measured for monochrome printing using all standard voltages.
The default time from Ready mode to PowerSave mode and the recovery time from PowerSave mode to the start of printing is negligible (less than 10 seconds) because of the instant on fusing.
The heat dissipation in Ready mode is 20 BTU/hour.
Environmental specifications
Operating environment:
Printer plugged into an AC outlet:
Temperature: 10 to 32.5 degrees C (50 to 90.5 degrees F)
Humidity: 20 to 80 percent (no condensation)
Storage environment:
Printer unplugged from an AC outlet:
Temperature: 0 to 40 degrees C (32 to 104 degrees F)
Humidity: 10 to 80 percent (no condensation)
Acoustic emissions
Declared per ISO 9296
Sound power level:
Printing (22 ppm):
LWAd = 6.2 Bels A and 62 dB (A)
Ready (PowerSave): essentially inaudible
Sound pressure level - standby position:
Printing (22 ppm):
LpAm = 48 dB (A)
Sound power level:
Printing (22 ppm):
Printing (22 ppm):
LpAm = 48 dB (A)
Configuration tested: HP LaserJet 1320 base unit, standard tray, A4 paper, and simplex continuous print.
Memory specifications
Base memory:
16 MB RAM
Upgrade memory expansion:
100-pin, 66 MHz minimum speed
Regulatory information
FCC compliance
This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to Part 15 of the FCC rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses, and can radiate radio frequency energy. If it is not installed and used in accordance with the instructions, it may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures:
  • Reorient or relocate the receiving antenna.
  • Increase separation between equipment and receiver.
  • Connect equipment to an outlet on a circuit different from that to which the receiver is located.
  • Consult your dealer or an experienced radio/TV technician.
Any changes or modifications to the printer that are not expressly approved by Hewlett-Packard could void the user's authority to operate this equipment.
Use of a shielded interface cable is required to comply with the Class B limits of Part 15 of FCC rules.
Environmental Product Stewardship program
Hewlett-Packard Company is committed to providing quality products in an environmentally sound manner. This product has been designed with several attributes to minimize the impact on our environment.
Ozone production
This product generates no appreciable ozone gas (O3).
Energy consumption
Energy Star
This product is designed to reduce power consumption and save natural resources without compromising product performance. It has been designed to reduce total energy consumption both during operation and when the device is not active.
This product qualifies for ENERGY STAR®, a voluntary program established by the U.S. Environmental Protection Agency (EPA) to encourage the development of energy-efficient office products.
Figure : ENERGY STAR® logo
ENERGY STAR® is a U.S. registered service mark of the U.S. EPA. As an ENERGY STAR® partner, HP has determined that this product meets ENERGY STAR® guidelines for energy efficiency.
To learn more about HP ENERGY STAR® qualified products, go to the Explore HP ENERGY STAR® qualified products Web site (www.hp.com/go/energystar) (in English).
For more information about ENERGY STAR®, go to the EPA's ENERGY STAR® Web site (www.energystar.gov) (in English).
Paper use
This product's automatic/manual two-sided printing (duplexing) and N-up printing (multiple pages printed on one page) features can reduce paper usage and the resulting demands on natural resources.
Plastics
Plastic parts over 25 grams (0.9 oz) are marked according to international standards that enhance the ability to identify plastics for recycling purposes at the end of the product's life.
HP LaserJet printing supplies
In many country/region, this product's printing supplies (such as print cartridge, drum, and fuser) can be returned to Hewlett-Packard through the HP printing supplies returns and recycling program. This easy-to-use, free take-back program is available in over 48 country/region. Multilingual program information and instructions are included in every new HP print cartridge and consumables package.
HP printing supplies returns and recycling program information
Since 1990, the HP printing supplies returns and recycling program has collected millions of used print cartridges that otherwise might have been discarded in the world's landfills. The HP LaserJet print cartridges and consumables are collected and bulk-shipped to our resource and recovery partners who disassemble the print cartridge. After a thorough quality inspection, selected parts are reclaimed for use in new print cartridges. Remaining materials are separated and converted into raw materials for use by other industries to make a variety of useful products.
U.S. recycling returns
For a more environmentally responsible return of used print cartridges and consumables, Hewlett-Packard encourages you to use bulk returns. Simply bundle two or more print cartridges together and use the single, prepaid, pre-addressed label that is supplied in the package. For more information in the U.S., call (800) 340-2445 or visit the HP LaserJet supplies Web site at http://www.hp.com/recycle.
Non-U.S. recycling returns
Non-U.S. customers should call the local HP sales and service office or visit the http://www.hp.com/recycle Web site for more information regarding availability of the HP printing supplies returns and recycle program.
Recycled paper
This printer is suited for the use of recycled papers when the paper meets the guidelines in the HP LaserJet printer family print media guide located on the HP Web site at http://www.hp.com/support/ljpaperguide. This product is suitable for the use of recycled paper according to DIN 19309.
Toner consumption
EconoMode uses significantly less toner, which might extend the life of the print cartridge.
Material restrictions
  • This product does not contain added mercury (except lamps containing less than 10 mg2.2 lb).
  • This product contains lead in solder that may require handling at end-of-life.
  • This product does not contain batteries.
Material Safety Data Sheet (MSDS)
To obtain Material Safety Data Sheets (MSDS), or to learn about supplies containing chemical substances (toner, for example), go to www.hp.com/go/msds.
For more information on the following HP environmental programs, see http://www.hp.com/go/environment/.
  • Product environmental profile sheet for this and many related HP products
  • HP's commitment to the environment
  • HP's environmental management system
  • HP's end-of-life product return and recycling program
  • Material safety data sheets
according to ISO/IEC Guide 22 and EN 45014:
Manufacturer's Name:
Manufacturer's Address:
11311 Chinden Boulevard
Boise, Idaho 83714-1021, USA
declares, that the product:
Product Name 4):
HP LaserJet 1320, HP LaserJet 1320n, HP LaserJet 1320tn/HP LaserJet 1320nw
Regulatory Model 3):
BOISB-0402-00/BOISB-0402-01
Including: Q5931A - Optional 250-Sheet Input Tray
Product Options:
ALL
conforms to the following Product Specifications:
Safety:
IEC 60950:1999 / EN 60950:2000
IEC 60825-1:1993 +A1:1997 +A2:2001 /
EN 60825-1:1994 +A11:1996 +A2:2001
(Class 1 Laser/LED Product)
GB4943-2001
EMC:
CISPR 22:1997 / EN 55022:1998 Class B1)
EN 61000-3-2:2000
EN 61000-3-3:1995 / A1
EN 55024:1998
FCC Title 47 CFR, Part 15 Class B2) / ICES-003, Issue 3
GB9254-1998, GB17625.1-1998 / CNS13438
Supplementary Information:
The product herewith complies with the requirements of the EMC Directive 89/336/EEC and the Low Voltage Directive 73/23/EEC, and carries the CE-marking accordingly.
  1. The product was tested in a typical configuration with Hewlett-Packard Personal Computer Systems.
  2. This Device complies with Part 15 of the FCC Rules. Operation is subject to the following two Conditions:
    1. This device may not cause harmful interference, and
    2. This device must accept any interference received, including interference that may cause undesired operation.
  3. For regulatory purposes, this product is assigned a Regulatory model number. This number should not be confused with the product name or the product number(s).
  4. Regulatory information regarding radio module approvals for the HP LaserJet 1320nw (Regulatory Model Number: BOISB-0402-01) can be found in the wireless user guide for that product.
Boise, Idaho 83714, USA; April 30, 2004
For Regulatory Topics ONLY, contact:
Australia:
Product Regulations Manager
Hewlett-Packard Australia Ltd.
31-41 Joseph Street
Blackburn, Victoria 3130, Australia
Europe:
Your Local Hewlett-Packard Sales and Service Office
- OR -
Hewlett-Packard GmbH
Department HQ-TRE / Standards Europe
Herrenberger Straße 140, Böblingen D-71034, Germany
(FAX: +49-7031-14-3143)
USA:
PO Box 15, Mail Stop 160
Boise, Idaho 83707-0015, USA
(Phone: 208-396-6000)
Country/Region-specific safety statements
Laser safety statement (USA)
The Center for Devices and Radiological Health (CDRH) of the U.S. Food and Drug Administration has implemented regulations for laser products manufactured since August 1, 1976. Compliance is mandatory for products marketed in the United States. The printer is certified as a "Class 1" laser product under the U.S. Department of Health and Human Services (DHHS) Radiation Performance Standard according to the Radiation Control for Health and Safety Act of 1968.
Since radiation emitted inside the printer is completely confined within protective housings and external covers, the laser beam cannot escape during any phase of normal user operation.
  warning:
Using controls, making adjustments, or performing procedures other than those specified in this user guide could result in exposure to hazardous radiation.
DOC regulations (Canada)
Complies with Canadian EMC Class B requirements.
«Conforme á la classe B des normes canadiennes de compatibilité électromagnétiques. «CEM».»
Laser statement (Finland)
LASERTURVALLISUUS
LUOKAN 1 LASERLAITE
KLASS 1 LASER APPARAT
HP LaserJet 1160, HP LaserJet 1320, HP LaserJet 1320n, HP LaserJet 1320tn, HP LaserJet 1320nw -laserkirjoitin on käyttäjän kannalta turvallinen luokan 1 laserlaite. Normaalissa käytössä kirjoittimen suojakotelointi estää lasersäteen pääsyn laitteen ulkopuolelle.
Laitteen turvallisuusluokka on määritetty standardin EN 60825-1 (1994) mukaisesti.
VAROITUS!
Laitteen käyttäminen muulla kuin käyttöohjeessa mainitulla tavalla saattaa altistaa käyttäjän turvallisuusluokan 1 ylittävälle näkymättömälle lasersäteilylle.
VARNING!
Om apparaten används på annat sätt än i bruksanvisning specificerats, kan användaren utsättas för osynlig laserstrålning, som överskrider gränsen för laserklass 1.
HUOLTO
HP LaserJet 1160, HP LaserJet 1320, HP LaserJet 1320n, HP LaserJet 1320tn, HP LaserJet 1320nw -kirjoittimen sisällä ei ole käyttäjän huollettavissa olevia kohteita. Laitteen saa avata ja huoltaa ainoastaan sen huoltamiseen koulutettu henkilö. Tällaiseksi huoltotoimenpiteeksi ei katsota väriainekasetin vaihtamista, paperiradan puhdistusta tai muita käyttäjän käsikirjassa lueteltuja, käyttäjän tehtäväksi tarkoitettuja ylläpitotoimia, jotka voidaan suorittaa ilman erikoistyökaluja.
VARO!
Mikäli kirjoittimen suojakotelo avataan, olet alttiina näkymättömälle lasersäteilylle laitteen ollessa toiminnassa. Älä katso säteeseen.
VARNING!
Om laserprinterns skyddshölje öppnas då apparaten är i funktion, utsättas användaren för osynlig laserstrålning. Betrakta ej strålen.
Tiedot laitteessa käytettävän laserdiodin säteilyominaisuuksista:
Aallonpituus 785-800 nm
Teho 5 mW
Luokan 3B laser
Country: Flag Bulgaria
