    Looking for Site Help?
HP Digital Sender 9100c - How to Configure the HP 9100c Digital Sender for Use with eFax
Ensure the Digital Sender is powered on and properly configured for sending e-mail. It is imperative that the outbound e-mail server is set correctly before proceeding. Click here for instructions to configure e-mail settings on the Digital Sender.
  1. Using a Web browser, connect to the HP 9100c built-in Web page. Type the IP address displayed on the front panel of the Digital Sender into a Web browser as you would a URL.
  2. Login to the Web page using the Administrator username and password.
  3. In the navigation box (upper left side of browser window), select: Settings, Send To, Fax
  4. Click the Enable Internet Fax radio button.
  5. Click Configure Internet Fax.
  6. In the Fax Settings window, input the following parameters:
    • Domain Name: efaxsend.com
    • Address Format: Standard
    • Default Billing Account: Enter your eFax registered eMail address
    • Fax File Format: PDF
  7. Click Apply button.
How to use the HP 9100c Digital Sender to send a fax with eFax
  1. Place document face-up in the automatic document feeder or face-down on the manual flatbed glass.
  2. Press the action button labeled Fax on the control panel display.
  3. Enter a fax phone number. US numbers should include 1, the area code and number. For example, 14155551212.
  4. Press the Enter key.
  5. Add additional fax recipients if desired.
  6. Press the green Go key.
    The document will be scanned and sent to eFax.
Country: Flag Bulgaria
