HP Business Inkjet 2800 Series Printer - Resolving Printer Management Problems
Embedded Web server (EWS) cannot be opened
Check your network setup
  • Make sure you are not using a phone cord to connect the printer to the network.
  • Make sure the network cable is securely connected to the printer.
  • Make sure the network hub, switch, or router is on and working properly.
Check the computer
Make sure the computer that you are using is connected to the network.
Check your Web browser
Make sure the Web browser meets the minimum system requirements.
Check the printer IP address
  • Print a configuration page, and then locate the printer’s IP address on the second page.
  • Ping the printer using the IP address from an MS-DOS prompt. For example, if the IP address is 123.123.123.123, type the following at the MS-DOS prompt: C:\Ping 123.123.123.123. If a reply appears, the IP address is correct.
Country: Flag Bulgaria
