HP Compaq Business Notebook nx9500 Series - Design Overview and Notebook Features
Design overview
This document presents a design overview of key parts and features of the notebook.
The system board provides the following device connections:
  • Memory module
  • Mini PCI communications devices
  • Hard drive
  • Display
  • Keyboard and TouchPad
  • Audio
  • Intel Pentium 4 processors
  • Fan
  • PC Card
The notebook uses an electrical fan for ventilation. The fan is controlled by a temperature sensor and is designed to turn on automatically when high temperature conditions exist. These conditions are affected by high external temperatures, system power consumption, power management/battery conservation configurations, battery fast charging, and software applications. Exhaust air is displaced through the ventilation grill located on the left side of the notebook.
To properly ventilate the notebook, allow at least a 7.6-centimeter (3-inch) clearance on the left and right sides of the notebook. Failure to properly ventilate the notebook may result in damage to the notebook's components.
Notebook features
  • The following processors, all with 512-KB L2 cache, are available, varying by notebook model:
    • Intel Pentium 4 3.4-, 3.2-, 3.0-, and 2.8-GHz processors with 800-MHz FSB and Hyper-Threading
    • Intel Pentium 4 3.06-, 2.8-, and 2.66-GHz processors with 533-MHz FSB
  • 17.0- inch wide XGA (1440 × 900), 15.4-inch wide XGA (1280 × 800) TFT display with over 16.7 million colors, or 17.0-inch wide WSXGA (1680 x 1050) TFT display, varying by notebook model
  • NVIDIA GeForce FX Go5200 Ultra with 128-MB video memory, NVIDIA GeForce FX Go5200 Ultra with 64-MB video memory, NVIDIA GeForce FX Go5600 Ultra with 128-MB video memory, NVIDIA GeForce FX Go5600 Ultra with 64-MB video memory, NVIDIA GeForce FX Go5700 with 128-MB video memory, or NVIDIA GeForce FX Go5700 with 64-MB video memory, varying by notebook model
  • 100-, 80-, 60-, or 40-GB high-capacity 4200-rpm hard drive, or 80-, 60-, or 40-GB high-capacity 5400-rpm hard drive, varying by notebook model
    Total storage capacity is 40, 60, 80, or 100 billion bytes (for hard drives, 1-GB = 1 billion bytes); actual accessible capacity is less.
  • 1024-, 512-, or 256-MB DDR Synchronous DRAM (SDRAM) at 333 MHz, expandable to 2.0 GB
  • Microsoft Windows XP Home, Microsoft Windows XP Professional, or Microsoft Windows XP Media Center, varying by notebook model
  • Full-size Windows 98 keyboard with integrated numeric keypad
  • TouchPad pointing device with on/off button and dedicated vertical scroll up/down pad
  • Integrated Secure Digital (SD) Memory Card slot
  • Integrated 10/100BASE-T Ethernet local area network (LAN) network interface card (NIC) with RJ-45 (network) connector
  • Integrated wireless support for Mini PCI 802.11b/g and Bluethumb LAN devices
  • One Type II PC Card slot with support for both 32-bit (CardBus) and 16-bit PC Cards
  • External 135- or 120-watt AC adapter with power cord
  • 12-cell Li-Ion battery pack
  • Harman/Kardon stereo speakers
  • Support for the following optical drives:
    • 24X Max DVD/CD-RW Combo Drive
    • 8X Max DVD-ROM Drive
    • 4X Max DVD+RW/R and CD-RW Combo Drive
    • 2X Max DVD+RW/R and CD-RW Combo Drive
  • Connectors:
    • SD Card slot
    • Infrared port
    • RJ-11 (modem) jack
    • RJ-45 (network) jack
    • 4 Universal Serial Bus (USB) v. 2.0 ports
    • S-Video jack
    • Parallel port
    • External monitor port
    • Power connector
    • Docking connector
    • IEEE 1394 digital port
    • Audio-in (microphone) jack
    • Audio-out (headphone) jack
