HP Workstation b2600 - Physical Specifications
Workstation characteristics
Characteristic
Weight Rack System (excl. Keyboard and display)
Weight Desk-side System (excl. keyboard and display)
41.1 kg (31.0 pounds)
15.9 kg (35.0 pounds)
Dimensions, Rack System
Depth: 45.77 cm (18.02 inches)1
Width: 42.50 cm (16.73 inches)
Height: 12.70 cm (5.00 inches)
Dimensions, Desk-side System
Depth: 47.02 cm (18.51 inches)
Width: 43.26 cm (17.03 inches)
Height: 13.67 cm (5.38 inches)
Storage temperature
-40 degrees C to +35 degrees C (+41 degrees F to +95 degrees F)
Operating humidity
15 percent to 80 percent (relative)
Input Current
3.6 - 3.0 amps (AC at 100 to 120 Vac)
1.8 - 1.5 amps (AC at 200 to 240 Vac)
Input Frequency
50 Hz/60 Hz
Sound Power Rack System
5.5 Bels LwA max. at 30 degrees C (88 degrees F)
Sound Power Desk-side System
5.0 Bels LwA max. at 30 degrees C (88 degrees F)
1The depth given above did not include the rear handle on the system. The depth of the system with a rear handle is 49.50 cm or 19.49 inches.
