HP Scanjet 3770 Series Digital Flatbed Scanner - Scanning with an HP Scanjet 3770 Series Digital Flatbed Scanner
Using the scanner
Scanning is started in one of three ways:
Scanning method
Scan from the buttons on the scanner lid.
The buttons on the scanner lid provide shortcuts to frequently used scanning functions.
Scan from the HP Director.
Scan from the HP Director software for more controls to customize the scan.
  • To start the HP Director software, double-click the HP Director icon on the first screen. The HP Director window appears.
  • If the HP Director icon is not on the first screen, click the the Start button, point to Programs or All Programs, then point to HP, and then click HP Director.
Scan from other applications
Bring an image directly into an open file in an application if the application is TWAIN- or WIA-compliant. Generally, the application is compliant if it has a command such as Acquire, Scan, or Import New Object. If unsure whether the application is compliant, or what the option is, see the documentation for that application.
Scan pictures and documents
Press the Scan button on the scanner lid to scan pictures and documents.
The Scan button will also scan slides or negatives from the Transparent Materials Adapter (TMA). For more information, see Scan slides and negatives.
Figure : Scanning pictures and documents
  1. Place the original face down in the upper-right corner on the glass as shown by the corner reference mark on the scanner.
  2. Close the scanner lid.
  3. Press the Scan button on the scanner lid.
  4. In the dialog box that appears, select one of the following options:
    • Picture - if scanning a photograph, a graphic, slides, or negatives. The default setting for scanned pictures is to appear in the HP Image Zone.
    • Document - if scanning text, both text and graphics, or any text that will be edited later. Scanned documents appear in the specified destination.
  5. Follow the instructions on the screen to finish scanning.
To simplify scanning, the software does not prompt to preview the picture when using the Scan button on the scanner lid. If you want to preview the scanned picture, select the Show Preview checkbox on the screen, or begin the scan from the HP Director.
The HP Scanning software can automatically correct images or restore faded colors in old pictures. The preview setting must be on to use this feature. To turn picture correction on or off, select Automatically Correct Photos in the Basic menu of the HP Scanning software, and then select the Restore Faded Color checkbox.
Scanning multiple pictures with one scan
To scan multiple pictures at the same time from the scanner glass, perform the following procedure:
Figure : Scanning multiple images
  1. Place the original pictures in each corner of the scanner glass with at least 1/4 inch (6.35 mm) space between the pictures, and then close the scanner lid.
    After scanning, you can rotate the scanned pictures in the HP Image Zone software.
  2. Press the Scan button on the scanner lid.
  3. Follow the instructions on the screen to finish scanning.
Each scanned picture appears in the HP Image Zone software as a separate picture.
To use the Scan button on the scanner lid to scan multiple pictures with one scan, the Preview setting must be set to off. To change the preview settings for the Scan button or HP Director, see Change settings. For scans from the HP Director, the Preview setting is on by default.
Tips for scanning slides and negatives
  • To scan a transparency for an overhead projector, place the transparency on the scanner glass, place a white sheet of paper on top of the transparency, and then scan.
  • When scanning a 35 mm slide or negative, the scanner software automatically enlarges the image to approximately 4 x 6 inches (10 x 15 cm). If the final image needs to be larger or smaller, use the Resize tool in the scanner software to set the scaling to the desired size. The scanner will scan the item at the proper resolution for the chosen size.
  • When cropping images, completely remove the borders to reduce excess light interference.
Scanning slides
Figure : Scanning slides
Use the TMA to scan as many as two 35 mm slides or two 35 mm negatives at one time. To scan 35 mm slides, use the slide holder that is part of the built-in TMA.
  1. Open the scanner lid.
  2. Remove the negative strip holder, if present, from the slide holder.
  3. Place as many as two slides into the slide holder. Insert the slides with the top up and with the front of the slides facing away from the lid.
  4. Close the scanner lid.
    Make sure that the slides are flat and do not overlap. Do not press the Scan button until the slides are loaded and the lid is closed.
  5. Press the Scan button on the scanner lid. A dialog box appears asking what is being scanned.
  6. Select Picture, and then click Scan.
  7. Select Slides from a Transparent Materials Adapter (TMA), and then click Scan.
  8. The scan is sent to the HP Image Zone. If you want to preview the scanned picture, select the Show Preview checkbox on the screen, or begin the scan from the HP Director software.
  9. Follow the instructions on the screen to finish scanning.
  10. When finished, remove the slides and place the negative strip holder back into the scanner lid for convenient storage.
Scan negatives
To scan 35 mm negatives, use the negative strip holder that is part of the built-in TMA.
Figure : Scanning negatives
  1. Open the scanner lid, and remove the negative strip holder, if present, from the slide holder.
  2. Slide a negative strip into the negative strip holder so that the shiny side faces away from the scanner lid.
    Negatives are easily damaged. Touch them only on their edges.
  3. Insert the negative strip holder back into the slide holder, and then close the scanner lid. Do not press the Scan button until the negatives are loaded and the lid is closed.
  4. Press the Scan button. A dialog box appears asking what is being scanned.
  5. Select Picture, and then click Scan.
  6. Select Negatives from a Transparent Materials Adapter (TMA), and then click Scan.
  7. The scan is sent to the HP Image Zone. If you want to preview the scanned picture, select the Show Preview checkbox on the screen, or begin the scan from the HP Director software.
  8. Follow the instructions on the screen to finish scanning.
  9. When finished, remove the negative strip and place the negative strip holder back into the scanner lid for convenient storage.
Print copies
To use the Copy button to scan an original and send it directly to a printer to make copies, perform the following steps:
Figure : Printing copies
  1. Place the original face down on the scanner glass as indicated by the reference marks on the scanner, and close the lid.
  2. Press the Copy button on the scanner lid. A screen opens that shows the copy progress.
  3. To increase the number of copies, lighten or darken the copies, reduce or enlarge them, or change printer settings, click Cancel in the Copy in Progress dialog box, then make the desired changes to the settings in the HP Copying software.
E-mail a scanned picture with HP Instant Share
Use HP Instant Share software to send someone an e-mail with thumbnails and links to pictures stored on a secure HP Web site, to upload pictures to the HP Photo Web site to create online picture albums, and to order professional-quality prints from an HP partner Web site. (Not all services are available in all regions or for all operating systems.) To e-mail scanned pictures using HP Instant Share, perform the following steps:
  1. Place the slides or negatives in the TMA, or place the photo face down on the scanner glass, and then close the scanner lid.
  2. Press the Scan button on the scanner lid. The scan is displayed in the HP Image Zone software. If multiple selection areas were detected, the selections are displayed as separate scanned images.
  3. Select one or more pictures in HP Image Zone.
  4. Click To E-mail, and then follow the onscreen directions.
E-mail scanned pictures as attachments
To e-mail scanned pictures as attachments, perform the following steps:
  1. Place the slides or negatives in the TMA, or place the photo on the scanner glass, and then close the scanner lid.
  3. Select one or more pictures in the HP Image Zone.
  4. Click the Selections Menu below the images. A screen opens that displays a list of destinations for the images.
  5. Select the appropriate e-mail application from the list of destinations, and then click OK. The selected e-mail software starts, and a new e-mail message opens. The selected pictures are attached to the e-mail message.
  6. Enter the e-mail destination and subject, and write a note.
  7. Send the message.
E-mail scanned documents
To e-mail scanned documents, perform the following steps:
  1. Place the original face down in the upper-right corner on the scanner glass, as shown by the corner reference mark on the scanner.
  4. Select E-mail from the scroll-down menu.
Changing settings
The HP Scanjet 3770 digital flatbed scanner allows customization of some features, including the scanner-lid button settings and other preferences.
  • Change settings from the HP Director
    When using the scanner buttons or the HP Director software, the scanner uses settings optimized for the scanned original type, such as a picture. Scan settings are changed from the Settings menu in the HP Director software. To change settings, start the HP Director software, and then click Settings.
  • To turn the preview image setting on or off, perform the following steps:
    1. Double-click the HP Director icon on the first screen. Or, click the Start button, point to Programs or All Programs, point to HP, and then click HP Director.
    2. When the HP Director opens, verify that the HP Scanjet 3770 scanner is selected in the Select Device list.
    3. On the Settings menu, point to Scan Settings & Preferences, and then click Button Settings. The Button Settings dialog box, which has a tab for each configurable button, opens.
    4. To turn the preview image setting on or off for each button, click the corresponding tab.
    5. Select or clear the preview button setting for that button.
    6. When you are satisfied with the settings, click OK.
