Blinking Lights on the HP Deskjet 5740 Printer Series
The printer lights indicate the printer status. These lights can be on, off, or flashing, depending on the status of the printer. This document describes the most common combinations of flashing lights, what they mean, and how to fix the issue.
Power light
Resume light
Print Cartridge light
Blinking
Off
Off
    Figure : Power light is blinking
  1. Power light
  2. Print Cartridge light
  3. Resume light
Issue
Power light is blinking.
Solution
If the Power light is blinking, the printer is preparing to print. The light stops blinking when the printer has received all data.
Power light
Resume light
On
Blinking
Off
    Figure : Resume light is blinking
  1. Power light
  3. Resume light
Issue
Resume light is blinking.
Solution
If the Resume light is blinking, check the following conditions:
  • The printer might be out of paper.
    1. Place paper in the In tray.
    2. Press the Resume button.
Power light
Resume light
On
Off
On
    Figure : Print Cartridge light is on
  1. Power light
  3. Resume light
Issue
Print Cartridge light is on.
Solution
  • If the light is on and not blinking, check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge.
  • If neither print cartridge is low on ink, press the Resume button. If the Print Cartridge Status light remains on, turn the printer off, and then turn the printer on again.
Power light
Resume light
On
Off
Blinking
    Figure : Print Cartridge light is blinking
  1. Power light
  3. Resume light
Issue
Print Cartridge light is blinking.
Solution
If printing a borderless document when the light started blinking, follow the borderless printing guidelines. Otherwise, follow these steps:
  1. Open the printer cover, remove the print cartridge on the right, and then close the cover.
  2. Follow one of these steps:
    • If the light is blinking: Open the printer cover, replace the print cartridge, and then remove the other print cartridge. The light should quit blinking. Go to Step 3.
    • If the light is off: There is a problem with the print cartridge that you removed. Go to Step 3.
  3. Verify that the print cartridge is the correct type for the printer. If it is, proceed to step four. If not, replace the print cartridge with the correct type for the printer.
    If the wrong print cartridge type is installed in the printer, the cartridge may become stuck in the print cartridge carriage. Using a moderate amount of force, push down on the front edge of the print cartridge to remove it from the print cartridge carriage.
  4. Manually, clean the print cartridge. If the printer is used in a dusty environment, a small amount of debris can accumulate on the print cartridge contacts. To manually clean the print cartridge, perform the following procedure:
    1. Open the printer cover and wait until the print cartridge cradle moves to the right side of the printer and is idle and quiet.
    2. Remove the print cartridges and place them on a piece of paper with the copper strips facing up.
        Figure : Print cartridge nozzles and contacts
      1. Ink nozzles
      2. Copper contacts
      Do not touch the print cartridge ink nozzles. Touching the ink nozzles will result in clogs, ink failure, and bad electrical connections.
      Do not leave the print cartridges outside the printer for more than 30 minutes, as this may dry the print cartridges out.
    3. Moisten a cotton swab with distilled water and squeeze any excess water from the swab.
    4. Wipe the copper contacts on the print cartridge with the cotton swab. Repeat this process until no ink residue or dust appears on the swab.
  5. After cleaning the print cartridge, reinsert it into the printer.
If the Print Cartridge Status light continues to blink, replace the print cartridge.
Power light
Resume light
Blinking
Blinking
On
    Figure : Power and Resume lights are blinking
  1. Power light
  3. Resume light
Issue
Power and Resume lights are blinking in unison.
Solution
If the Power and Resume lights on the printer begin blinking in unison, a carriage stall has occurred. Open the top cover. If the print cartridge cradle moves to the right side, it is not stuck. If it does not move, follow the steps below.
  1. Disconnect the power from the printer by unplugging the power cord from the back of the printer.
  2. Open the access door and observe the print cartridge and carriage. If the carriage is on the right-hand side, check for lint or paper pieces. Remove any obstructions. Move the carriage to the left and check for lint or paper pieces. Remove any obstructions.
  3. If the print carriage is on the left side, check for lint or paper pieces. Remove any obstructions. Move the carriage to the right and check for lint or paper pieces. Remove any obstructions. Then move the carriage back to the left side to make sure the print cartridges are stored properly in the capping station.
  4. Look inside the printer for obstructions along the cartridge cradle's path, such as lint or paper pieces. Remove any obstructions.
  5. Remove the rear access door on the back of the printer and check for paper pieces. Remove any obstructions.
  6. Reattach the power cord and turn the printer back on. The carriage should return to the left side and reseat itself on the capping station.
If you have completed all of the steps listed above and are still experiencing a problem, service your product.
Power light
Resume light
Blinking
Blinking
Blinking
    Figure : Power, Resume, and Print Cartridge Status lights are blinking
  1. Power light
  3. Resume light
Issue
Power, Resume, and Print Cartridge Status lights are blinking in unison.
Solution
The printer might need to be restarted.
  1. Press the Power button to turn off the printer, and then press the Power button to restart the printer. Proceed to Step 2 if the lights continue to blink.
  2. Press the Power button to turn off the printer.
  3. Disconnect the printer power cord from the electrical outlet.
  4. Reconnect the printer power cord to the electrical outlet.
  5. Press the Power button to turn on the printer.
Country: Flag Bulgaria
