HP Officejet 9100 All-in-One Series - Paper Handling
The all-in-one is designed to work well with most types of office paper and with 25-percent cotton bond paper. It is best to test a variety of print media types before buying large quantities.
The following table lists the different media types:
Media name
Tray 1
Tray 2
Auto-duplex unit
ADF (single-sided operation)
ADF (double-sided operation)
Standard paper sizes
U.S. Letter (216 x 279 mm; 8.5 x 11 inches)
Y
Y
Y
Y
Y
U.S. Legal (216 x 356 mm; 8.5 x 14 inches)
Y
Y
Y
Y
A4 (210 x 297 mm; 8.3 x 11.7 inches)
Y
Y
Y
Y
Y
U.S. Executive (184 x 267 mm; 7.25 x 10.5 inches)
Y
Y
Y
Y
Y
U.S. Statement (140 x 216 mm; 5.5 x 8.5 inches)
Y
Y
A5 (148 x 210 mm; 5.8 x 8.3 inches)
Y
Y
Y
ISO B5 (176 x 250 mm; 6.9 x 9.8 inches)
Y
Y
Y
JIS B5 (182 x 257 mm; 7.2 x 10.1 inches)
Y
Y
Y
Y
Envelopes
U.S. #10 Envelope (105 x 241 mm; 4.1 x 9.5 inches)
Y
A2 Envelope (111 x 146 mm; 4.375 x 5.75 inches)
Monarch Envelope (98 x 191 mm; 3.9 x 7.5 inches)
HP Greeting Card Envelope (111 x 152 mm; 4.375 x 6 inches)
DL Envelope (110 x 220 mm; 4.3 x 8.6 inches)
C5 Envelope (162 x 229 mm; 6.4 x 9 inches)
C6 Envelope (114 x 162 mm; 4.5 x 6.4 inches)
Japanese Chou #3 (120 x 235 mm; 4.7 x 9.3 inches)
Japanese Chou #3 (90 x 205 mm; 3.5 x 8.1 inches)
Cards
Index card (76 x 127 mm; 3 x 5 inches)
Y
Y
Index card (102 x 152 mm; 4 x 6 inches)
Index card (127 x 203 mm; 5 x 8 inches)
Hagaki (100 x 148 mm; 3.9 x 5.8 inches)
Ofuku Hagaki (148 x 200 mm; 5.8 x 7.9 inches)
A6 card (105 x 148 mm; 4.1 x 5.8 inches)
Custom-size media
Between 76.2 to 216 mm wide and 127 to 356 mm long (3 to 8.5 inches wide and 5 to 14 inches long)
Y
Custom-size media (tray 2) Between 182 to 216 mm wide and 257 to 356 mm long (7.2 to 8.5 inches wide and 10.1 to 14 inches long)
Y
Between 76.2 to 216 mm wide and 127 to 297 mm long (3 to 8.5 inches wide and 5 to 11.7 inches long)
Y
Custom-size media (ADF) Between 127 to 216 mm wide and 127 to 356 mm long (5 to 8.5 inches wide and 5 to 14 inches long)
Y
Custom-size media (ADF) Between 178 to 305 mm (5 to 8.5 inches wide and 7 to 12 inches long)
Y
Paper capacity and weight matrix
The following table lists the minimum weight and capacity of papers in various trays:
Tray
Media type
Paper capacity
Tray 1
Paper
60 to 90 g/m2 (16 to 24 lb bond)
Up to 150 sheets of plain paper (15 mm or 0.6 inch stacked)
Transparencies
Up to 30 sheets (8 mm or 0.3 inch stacked)
Envelopes
75 to 90 g/m2 (20 to 24 lb bond envelope)
Up to 22 sheets (15 mm or 0.6 inch stacked)
Cards
Up to 200 g/m2 (110 lb index)
Up to 60 sheets (15 mm or 0.6 inch stacked)
Tray 2
Paper
60 to 90 g/m2 (16 to 24 lb Bond)
Up to 250 sheets (25 mm or 1 inch stacked)
Auto-duplex unit
Paper
16 to 24 lb. (60 to 90 g/m^2)
One at a time
Cards
90 lb. Index (Up to 160 g/m^2)
One at a time
ADF
Paper
Up to 50 sheets of plain paper (5 mm or 6 inches stacked)
Special HP paper (for example, HP Premium Inkjet paper, HP Bright White Inkjet paper)
one at a time
Advisable to use the flatbed scanner
Transparencies
one at a time
Photos (special photo paper, such as HP Premium Photo Paper)
one at a time
Real estate forms
one at a time
Output tray
All supported media
Up to 100 sheets plain paper (text printing)
Loading an original in the Automatic Document Feeder (ADF)
The all-in-one has an ADF with a maximum capacity of 50 originals. To load an original in the ADF, follow these steps:
  1. Ensure that no originals are placed on the flatbed scanner glass.
  2. Place all originals in the ADF input tray with the print-side up and with the first page to be scanned/copied/faxed on top of the stack.
  3. Adjust the paper-width guides to fit the size of the originals.
Loading an original on the scanner glass
An original can also be copied/scanned by placing it on the scanner glass. To load an original on the scanner glass, follow these steps:
  2. Lift the flatbed scanner lid.
  3. Place the original facedown on the scanner glass in the bottom-right corner, with the sides of the original touching the right and bottom edges.
  4. It is important to place the original in the lower-right corner. Otherwise, part of the original might be clipped in the resulting scan.
Loading media into Tray 1 and 2
To load Tray 1 or Tray 2, follow these steps:
  1. Pull the tray out of the all-in-one.
  2. To load the paper in Tray 1, raise and remove the output tray.
  3. To load paper between 11 inches (279 mm) and 14 inches (356 mm) long, move the latch on the tray to the right and lower the front of the tray. (There is no need to lower the front of the tray for letter-size or A4-size paper.)
  4. Place the media with the print side down in the tray and slide the media width and length guides to the edges of the media.
  5. When loading Tray 1, reattach and close the output tray.
  6. Slide the tray into the all-in-one.
  7. Pull out the extension on the output tray.
  8. Select the appropriate media type option in the application or printer driver.
The all-in-one speed specification is based on Tray 1. When Tray 2 is installed, it becomes the default tray (unless otherwise specified by the user). As a result, any job sent to the all-in-one with Tray 2 selected or as autoselect, the job will print slower as compared to the quoted speed specifications. This is because Tray 2 has a longer paper path and the printing is, therefore, slower than Tray 1.
Manual duplexing
Users can also perform manual duplexing with the all-in-one. From the software program, print one side of the document. Turn the paper over in the tray and then repeat the print job, this time printing the second side.
Printing on special media
The four types of special media on which the HP Officejet 9100 series all-in-one can print are as follows:
  • Cards and envelopes
  • Transparencies
  • Photo paper
  • Custom size
Cards or envelopes
To use cards or envelopes, follow these steps:
  1. Remove Tray 1 from the printer.
  2. Remove the output tray and then remove all media from Tray 1.
  3. Insert the cards or envelopes into the tray (envelopes should be loaded with the flaps facing up and to the right).
  4. Slide the media width and length guides to the edges of the cards or envelopes.
  5. Replace the output tray and insert Tray 1 into the printer.
  6. Start the job from the computer, after selecting the correct media size and type.
Transparencies
To use transparencies, follow these steps:
  3. Insert the transparencies into the tray, with the rough side down and the adhesive strip pointing forward.
  4. Slide the media width and length guides to the edges of the transparencies.
  7. Remove each transparency as it prints and set it aside to dry. Allowing wet media to stack up might cause smearing.
Photo paper
Photographs taken using a digital camera can be printed using the all-in-one. The printing can be done either directly from the memory card or from a software program, such as the HP Photo & Imaging software. Use Best print quality to print photographs. However, this takes longer to print and requires more memory. The all-in-one can produce 4,800 x 1,200 optimized dpi resolution when using the PCL 6 driver for Windows 98/XP/Me/2000 operating systems. In addition, all-in-one supports the PS driver for Windows 2000/XP, Mac 9.2.x, and Mac (10.1 and later) operating systems.
To print digital photographs from a program, do the following:
  1. Load the appropriate paper in Tray 1.
  2. Start the job from the computer after selecting appropriate print-quality setting, media size, and media type.
  3. Remove each sheet of media as it prints and set it aside to dry. Allowing wet media to stack up might cause smearing.
Custom-size media
When printing on custom-size media, adjust the length and width guides in the tray, and, if necessary, extend the tray size to accommodate larger media. Use Tray 1 when printing on paper that is 3 to 8.5 inches wide and 5 to 14 inches long (76.2 to 216 mm wide and 127 to 356 mm long). Customize the media size before printing the document if the application supports custom-size media. If the application does not support custom-size media, set the size in the printer driver, create the document and print it. Reformatting might be needed on existing documents to print them correctly on custom paper sizes.
To use custom-size media, do the following:
  3. Insert the custom-size media into the tray.
  4. Slide the media width and length guides to the edges of the media.
  6. Start the job from the computer after selecting appropriate media size and type.
Supported media and part numbers
Media type
Part number
HP Bright White Inkjet Paper
HPB1124
HP Office Paper
HPC8511
HP Office Recycled Paper
HPE1120
HP Multipurpose Paper
HPM1120
HP Printing Paper
HPP1122
HP Everyday Paper
Q2509A
HP Everyday Copy & Print Paper
Q2509A
HP Premium Paper, coated
51634Y
HP Premium Inkjet Transparency Film
C3834A
HP Premium Plus Inkjet Transparency Film
C7028A
HP Everyday Photo Paper, semi-gloss
Q2509A
HP Premium Plus Photo Paper
C6831A
C6979A
HP Photo Paper
C7896A
HP Brochure and Flyer Paper, glossy
C6817A
HP Brochure and Flyer Paper, matte
C6955A
