HP Designjet 30 and 30n Printers - Product Specifications
Product model numbers
  • HP Designjet 30 - C7790D
  • HP Designjet 30n - C7790E
Figure : 30 Series
Printer features
  • New, dye-based HP inks that resist fading for approximately 70 years1 and provide rich color depth, minimal dot visibility, and uniform gloss
  • Automatic printhead alignment and color calibration for maximum color consistency
  • Fast color stability, ideal for pre-press printing
  • Superb color image quality with 2400 dpi and a modular dye-based ink system
  • Use a wide range of HP media weights and types
  • With HP Professional Color technologies, including Automatic Closed Loop Color calibration, get fast color stability for pre-press printing with accurate color
  • Handles stock in weights up to 80 lb (300 g/m2) and up to 0.02 inches (0.4 mm) in thickness
  • Choose from a variety of media finishes, including HP Premium Plus Photo and Proofing Gloss and HP Photo Matte
  • Print high-quality images quickly at up to 4 min/page for B/A3 sizes in Normal mode on glossy media
  • Optimized drivers with RGB ICC profiles support Mac and Windows applications
  • Apple ColorSync compatibility ensures color matching during workflow
  • Use optional HP software RIP for expanded printing options and color accuracy
1 Preliminary results from tests conducted by Wilhelm Imaging Research, Inc. indicate that prints made with HP No. 85 ink cartridges and HP Premium Plus Photo and Proofing Gloss paper may be displayed indoors under glass for approximately 70 years before noticeable fading and staining will occur.
Technical specifications
Print technology
HP Thermal Inkjet
Print technology resolution
HP Color Layering Technology, PhotoREt IV
Automatic Color Calibration, Automatic Pantone Calibration, Offset simulation and CMYKplus
Print resolution color
Up to 2400 x 1200 dpi
Lightfastness
Approximately 70 years1
Ink cartridge colors
Black, cyan, magenta, yellow, light cyan, light magenta
Ink types
DYE-based
Print speed (using N5 file)
  • B/A3-size: Up to 4 min/page (Normal, Glossy)
  • B/A3-size: Up to 6 min/page (Best, Glossy)
Print margins
  • Top (A3) 0.2 inch (5 mm)
  • Bottom (A3) 0.47 inch (12 mm)
  • Left (A3) 0.2 inch (5 mm)
  • Right (A3) 0.2 inch (5 mm)
Media sizes
Postcard, letter, legal, B, B+ (Postcard, A4, A3, A3+, A, B, B+)
Media thickness (by paper path)
  • Tray 1 - up to 0.008 inch (0.2 mm); envelopes up to 0.015 inch (0.4 mm)
  • Rear tray - up to 0.015 inch (0.4 mm)
  • Manual sheet feed - up to 0.008 inch (0.2 mm)
Media weights (by paper path)
  • Tray 1 - 17 to 40 lb (65 to 150 g/m2)
  • Manual single-sheet feed - 17 to 40 lb (65 to 150 g/m2)
  • Rear path - Up to 80 lb (300 g/m2)
Minimum system requirements
Windows:
  • Microsoft Windows (95, 98) - Pentium I, 133 MHz,128 MB RAM, 300 MB available hard disk space
  • Microsoft Windows NT - Pentium II, 300 MHz, 128 MB RAM, 400 MB available hard disk space
  • Microsoft Windows (2000, 2003) - Pentium II, 300 MHz, 128 MB RAM, 400 MB available hard disk space
  • Microsoft Windows XP - Pentium III, 733 MHz, 256 MB RAM, 400 MB available hard disk
Macintosh:
  • iMac G3, G4, G5 dual processor, iBook, PowerBook, eMac
  • Mac (OS 9.1, OS X v 10.1.5), 128 MB RAM, 100 MB available hard disk space
Recommended system requirements
Windows:
  • Microsoft Windows (95, Me) - Pentium II, 300 MHz, 128 MB RAM, 1 GB available hard disk space
  • Microsoft Windows NT - Pentium III, 733 MHz, 128 MB RAM, 2 GB available hard disk space
  • Microsoft Windows 2000 - Pentium III, 733 MHz, 256 MB RAM, 2 GB available hard disk space
  • Microsoft Windows XP - Pentium IV, 1 GHz, 256 MB RAM, 2 GB available hard disk space
Macintosh:
  • Dual 1 GHz PowerPC G4, 512 MB RAM
Memory
32 MB
Connectivity
  • 30 Standard - USB 1.1 (USB 2.0 compliant), Centronics parallel IEEE-1284 (ECP compliant), one EIO slot
  • 30 Optional - HP Jetdirect 615n print server for Fast Ethernet
  • 30n Standard - USB 1.1 (USB 2.0 compliant), Centronics parallel IEEE-1284 (ECP compliant), 1 EIO slot HP Jetdirect 615n print server for fast Ethernet
    The HP Jetdirect 615n LAN card has recently been discontinued and is no longer available. The replacement card for the HP Jetdirect 615n is the HP Jetdirect 620n card.
Drivers (included)
Raster driver for Mac OS (9.x, X.1, X.2, X.3), PCL 3-GUI Windows driver, Microsoft Windows drivers (95, 98, Me, NT 4.0, 2000, XP) including support for AutoCAD 2000, USB, ECP drivers
Print languages
  • Standard - PCL 3-GUI RGB 24-bit Contone
  • Optional - Adobe PostScript 3 via software RIP
Product weight
27.5 lb (12.5 kg)
Dimensions (h x d x w)
8.8 x 21.3 x 28.5 inches (223.7 x 441.9 x 723.9 mm)
Power consumption
65 watts (max), 18 watts (standby)
Power supply
Input voltage 100 to 240 VAC (+/- 10%) auto ranging, 50/60 Hz (+/- 3Hz), 2 amps maximum
Electromagnetic compatibility
Compliance for Class B products, Class A when connected to LANs, EU (EMC Directive), USA (FCC rules), Canada (DoC), Australia (ACA), New Zealand (MoC), China (CCC), Japan (VCCI), Class A for Korea (MIC), Taiwan (BSMI)
Safety
IEC 950-compliant, EU LVD and EN60950 compliant, CSA certified for US and Canada, Mexico NOM-1-NYCE, Argentina IRAM, China CCC, Singapore PSB, Russia VNIIS, Poland ELTEST, Korea KTL
Supplies and accessories
Ink supplies
HP part number
HP 85 cyan printhead
C9420A
HP 85 magenta printhead
C9421A
HP 85 yellow printhead
C9422A
HP 85 light cyan printhead
C9423A
HP 85 light magenta printhead
C9424A
HP 84 black printhead
C5019A
HP 85 cyan ink cartridge
C9425A
HP 85 magenta ink cartridge
C9426A
HP 85 yellow ink cartridge
C9427A
HP 85 light cyan ink cartridge
C9428A
HP 85 light magenta ink cartridge
C9429A
HP 84 black ink cartridge
C5016A
Accessories
HP part number
HP Jetdirect 615n print server for Fast Ethernet (included in HP Designjet 30n)
J6057A
HP Software RIP for HP Designjet 30
Q5671A
EFI Designer Edition 4.0 for HP M
Q6641A, (Japan - Q6642A)
HP Care pack information
Care pack description
HP part number
HP Care Pack Next Day Exchange, three years (EMEA1, NA2, LAR3, JP4, Australia, New Zealand)
H7708A
HP Care Pack Next Day Exchange, three years (EMEA, NA, LAR, JP, Australia, New Zealand)
H7708E
HP Care Pack Return to HP, three years (AP except JP, Australia, New Zealand)
H7598A
H7598E
1Europe, 2North America, 3Latin America, 4Japan
Contact HP
Click here for information on contacting HP support at http://h20000.www2.hp.com/bizsupport/TechSupport/CallHP.jsp?locale=en_US&docIndexId=179680&taskId=101&prodTypeId=18972&prodSeriesId=25301.
Additional Web support sources
Click here to access additional media supplies information on HP Designjet online at http://www.designjet.hp.com/supplies/home.html?newlang=en&uid=2274065.
Click here to access HP Designjet online at http://www.designjet.hp.com/home.html?pageseq=52699280.
Click here to access HP business support center at http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?locale=en_US.
Country: Flag Bulgaria
