    Looking for Site Help?
HP and Compaq Desktop PCs - Motherboard Specifications, A7N8X-LA (Focus)
Motherboard specifications table
PART / FEATURE
SPECIFICATION / SUPPORT
Motherboard Description
  • Manufacturer's name - ASUS A7N8X-LA
  • HP/Compaq name - Focus
CPU
  • Socket A
  • AMD Athlon/Athlon XP
  • Supports up to Athlon XP 3200+ (2.2 GHz, 333 MHz)
  • nVidia nForce2 400 SPP
  • nVidia MCP-T
Front Side Bus (FSB)
  • 400/333/266 MHz
Memory
  • Two 184-pin DDR DIMM
  • Maximum memory size is up to 2GB, 1GB per slot (the PC manufacturer's recommended maximum memory may differ)
  • Supports PC2700/PC2100
Expansion Slots
  • Three PCI slots
  • One AGP 8X slot
IDE
  • Two UltraDMA 100/66/33 connectors
  • PIP Mode 3/4
  • Supports ATAPI IDE, CD-ROM, CD-R, CD-RW, and LS-120
Onboard Audio
  • AC'97 l2.2 compliant
  • RealTek ALC650 6-channel audio CODEC subsystem
Onboard IEEE 1394
  • AgereFW802C PHY
  • Supports two 1394 ports
  • 400/200/100Mbps data transfer rate
Onboard LAN
  • Realtek 8201BL LAN PHY (Physical Layer Protocol)
  • Supports 10/100 Mbps
Hardware Monitoring
Super I/O integrated monitoring:
  • CPU and chassis fan rotations
  • CPU/chassis temperature
Special Features
  • Wakeup on Ring, LAN, keyboard, PS/2 mouse, RTC Timer
  • Supports ACPI STR (S#) function
  • Restart/Off Setup of AC recovery from power failure
Rear panel I/O
  • One parallel port
  • One serial port
  • One video port
  • One PS/2 keyboard
  • One PS/2 mouse port
  • One RJ-45 port
  • Up to four USB 2.0 / USB 1.1 ports
  • One IEEE 1394 port
  • Audio line-in, line-out, and microphone ports
Internal I/O
  • One USB 2.0 connector for two additional USB ports
  • One IEEE 1394 connector
  • CPU/chassis fan connectors
  • 20-pin ATX 12V power connectors
  • S/PDIF out connector
  • Speaker out connector
  • CD/AUX audio connector
  • Front headphone connector
  • Front MIC-in connector
BIOS Features
  • 4Mb Flash ROM
  • AMI BIOS with Enhanced ACPI, PnP, DMI2.0, Green features
Form Factor
  • Micro-ATX form factor
  • 9.6 inches X 9.6 inches (24.5 cm x 24.5 cm)
Industry Standard
  • USB 2.0/1.1
  • PCI 2.2
Mainboard specifications are subject to change without notice.
Motherboard layout and photos
Figure : layout
Figure : photo
    Figure : Photo of the back connector plate
  1. Mouse
  2. Parallel
  3. IEEE 1394 FireWire
  4. Local Area Network
  5. Line-In
  6. Line-Out
  7. Microphone
  8. USB 2.0
  9. VGA
  10. Serial
  11. Keyboard
Clearing the CMOS settings
The Clear RTC RAM (3-pin CLRTC) jumper allows you to clear the Real Time Clock (RTC) RAM in CMOS. It also allows clearing of date, time, and system setup parameter memories in CMOS, by erasing the RTC RAM data. The onboard button cell battery powers the RAM data in CMOS, including system setup information.
  1. Turn off the PC and unplug the power cord.
  2. Move the CLRTC jumper cap from pins 1-2 (normal) to pins 2-3 (clear CMOS).
  3. Keep the jumper cap on pins 2-3 for 5 to 10 seconds, then move back to pins 1-2.
  4. Plug in the power cord and turn on the PC.
  5. Enter the BIOS setup to change the BIOS settings.
Clearing the BIOS password
The BIOS password protects the BIOS from undesired changes (Focus password checking is disabled by default). If password checking is enabled, and you need to disable it, use the following steps:
  1. Move the J11 jumper cap from pins 2-3 to pins 1-2 to enter BIOS setup without a password.
  2. To enter BIOS setup, start the PC and press the F1 key as the PC boots.
  3. Clear or reset the BIOS password.
  4. Save the BIOS settings and shutdown the PC.
  5. If desired, re-enable BIOS password checking by returning the J11 jumper cap to pins 1-2.
Country: Flag Bulgaria
