HP LaserJet 3020 and 3030 All-in-One Printers - Supplies and Accessories
HP parts and accessories
Use the following topics to find out about ordering parts and accessories for the printer.
Ordering HP parts and accessories
HP parts and accessories charts
Increase the printer's capabilities with optional accessories and supplies. Use accessories and supplies designed specifically for HP LaserJet 3020 / 3030 All-in-One printers to ensure optimum performance.
All HP parts and accessories can be purchased directly online from the HP Website Online Shopping Portal.
Accessories
Part number
Cables and interface accessories
2-meter IEEE-1284 parallel cable
C2950A
3-meter IEEE-1284 parallel cable
C2951A
2-meter USB Device Cable (A/B)
8121-0539
Cleaning and maintenance accessories
Toner collection cloth
5090-3379
Printing supplies
Part number
HP Multipurpose paper
HP brand paper for a variety of uses (one box of 10 reams, 500 sheets each).
HPM1120
HP LaserJet paper
Premium HP brand paper for use with HP LaserJet printers (one box of 10 reams, 500 sheets each).
HPJ1124
HP LaserJet transparency film
HP brand transparency film for use with HP LaserJet monochrome printers.
92296U (A4)
92296T (letter)
Print cartridges
Replacement print cartridges for the HP LaserJet 3020 / 3030 all-in-one devices.
2,000 page cartridge
Q2612A
Supplementary documentation
Part number
Guidelines for Paper and Other Print Media
A guide to using paper and other print media with HP LaserJet printers.
5963-7863
Replacement parts
Part number
Paper pickup roller
Used to pick up the paper from the media input tray and advance it through the printer.
RL1-0266-000
Media input tray
Used to hold media for the printer.
RG0-1121-000CN
Priority input tray
Used to feed special media or for printing a first page.
RG0-1122-000CN
Automatic document feeder (ADF) input tray
Used to feed documents into the scanner.
C9143-60102
Separation pad for the printer
Used to keep multiple sheets from feeding through the printer path.
C7309-60009
ADF pickup roller assembly
Used to pick up the media from the ADF input tray and advance it through the ADF.
C7309-60068
ADF
If the ADF breaks, use this part number to order one (includes flatbed scanner lid).
C9143-60101
HP Jetdirect print server accessories
The following HP Jetdirect external print servers are supported.
  • HP Jetdirect 170X (J3258B). Use this model if you have a 10-Base-T network, and only need to connect the HP LaserJet all-in-one product to this print server. This print server does not support Web Scan through the EWS. This print server is not compatible with Mac systems.
  • HP Jetdirect 175X (J6035C). Use this model if you have a 10-Base-T or a 100-Base-T network, and only need to connect your HP LaserJet all-in-one product to this print server.
  • HP Jetdirect 300X (J3263A) with firmware revision H.08.00 or higher. Use this model if you have a 10-Base-T or 100-Base-TX network, and only need to connect your HP LaserJet allin- one product to this print server. This print server does not support Web Scan through the EWS.
  • HP Jetdirect en3700 (J7942A) with firmware revision A.25.00 or higher. Use this model if you have a 10-Base-T or a 100-Base-TX network and only need to connect your HP LaserJet all-in-one product to this print server.
  • HP Jetdirect 380X (J6061A) external wireless, compatible with all firmware versions. It connects one product to any 802.11b wireless Ethernet.
  • HP Jetdirect 500X (J3265A) with firmware revision J.08.00 or higher. Use this model if you have a BNC (10Base2), 10-Base-T, or 100-Base-TX network, and would like to connect your HP LaserJet all-in-one product and up to two other devices to this print server. This print server does not support Web Scan through the EWS. This print server must be set up on Port 1.
  • The HP Jetdirect Print Server must be set for “ECP/1284.4” mode in order to work correctly with the HP Toolbox.
  • Only print functionality is available when using the IPX/SPX protocol.
  • When using a multiport HP JetDirect Print Server, the HP LaserJet all-in-one device must be connected using Port 1.
  • It is recommended that a static IP address be assigned to an HP Jetdirect Print Server before installing the software. If the IP address changes after you install the software, you will lose scanning and faxing functionality from the computer.
You can check the firmware revision number by printing a configuration page for the HP Jetdirect print server. If the firmware version is not H.08.00 or J.08.00 or higher, upgrade the firmware before using the HP Jetdirect external print server with your HP LaserJet all-in-one product. See the documentation that came with the HP Jetdirect print server for more information about upgrading the firmware. The HP Jetdirect 170X and 175X print server firmware is not upgradeable.
Go to www.hp.com/go/wja_firmware to download a firmware upgrade for your HP Jetdirect Print Server.
Country: Flag Bulgaria
