HP LaserJet 3380 All-in-One Series Product - Ordering HP Supplies and Accessories
HP parts and accessories charts
The printer capabilities increase with optional accessories and supplies. Use accessories and supplies designed specifically for the HP LaserJet 3380 all-in-one series product to ensure optimum performance.
All HP parts and accessories can be purchased directly online from the HP Website Online Shopping Portal.
Accessories
Part number
Dual inline memory modules (DIMMs)
  • 8 MB
  • 16 MB
  • 32 MB
  • 64 MB
  • C7842A
  • C7843A
  • C7845A
  • C7846A
Cables and interface accessories
  • 2-meter IEEE-1284 parallel cable
  • 3-meter IEEE-1284 parallel cable
  • 2-meter USB Device Cable (A/B)
  • C2950A
  • C2951A
  • 8121-0539
Automatic document feeder (ADF)
If the printer did not come with an ADF, use this part number to order one.
C9143A
Printing supplies
Part number
HP multipurpose paper
HP brand paper for a variety of uses (One box of 10 reams, 500 sheets each).
HPM1120
HP LaserJet paper
Premium HP brand paper for use with HP LaserJet printers (One box of 10 reams, 500 sheets each).
HPJ1124
HPM1120
HP LaserJet paper
HPJ1124
HP LaserJet transparency film
  • HP brand transparency film for use with HP LaserJet monochrome printers.
  • 92296U (A4)
  • 92296T (letter)
Print cartridges
Replacement print cartridges for the HP LaserJet 3380 all-in-one.
2,500 page cartridge
C7115A
Print cartridges
3,500 page cartridge
C7115X
HP Toner Cleaning Cloth
5090-3379
Supplementary documentation
Part number
Guidelines for Paper and Other Print Media
A guide to using paper and other print media with HP LaserJet printers.
5963-7863
Replacement parts
Part number
Paper pickup roller
Used to pick the paper from the paper input tray and advance it through the device.
RL1-0303-000CN
Media input tray
Used to hold media for the device.
RG0-1121-000CN
Priority input tray
Used to feed special media or for printing a first page.
RG0-1122-000CN
Automatic document feeder (ADF) input tray
Used to feed documents into the scanner.
C9143-60102
Separation pad for the device
Used to keep multiple sheets from feeding through the device path.
RF0-1014-000CN
ADF pickup roller assembly
Used to pick the media from the ADF input tray and advance it through the ADF.
C7309-60068
ADF
If ADF breaks, use this part number to order one (includes flatbed scanner lid).
C9143-60108
HP Jetdirect print server accessories
The following HP Jetdirect external print servers are supported.
  • HP Jetdirect 170X (J3258B). Use this model if you have a 10-Base-T network, and only need to connect the HP LaserJet all-in-one product to this print server. This print server does not support Web Scan. This print server is not compatible with Mac systems.
  • HP Jetdirect 175X (J6035C). Use this model if you have a 10-Base-T or a 100-Base-T network, and only need to connect your HP LaserJet all-in-one product to this print server.
  • HP Jetdirect 300X (J3263A) with firmware revision H.08.00 or higher. Use this model if you have a 10-Base-T or 100-Base-TX network, and only need to connect your HP LaserJet all-in- one product to this print server. This print server does not support Web Scan.
  • HP Jetdirect en3700 (J7942A) with firmware revision A.25.00 or higher. Use this model if you have a 10-Base-T or a 100-Base-TX network and only need to connect your HP LaserJet all-in-one product to this print server.
  • HP Jetdirect 380X (J6061A) external wireless, compatible with all firmware versions. It connects one product to any 802.11b wireless Ethernet.
  • HP Jetdirect 500X (J3265A) with firmware revision J.08.00 or higher. Use this model if you have a BNC (10Base2), 10-Base-T, or 100-Base-TX network, and would like to connect your HP LaserJet all-in-one product and up to two other devices to this print server. This print server does not support Web Scan. This print server must be set up on Port 1.
  • The HP Jetdirect Print Server must be set for “ECP/1284.4” mode in order to work correctly with the HP Toolbox.
  • Only print functionality is available when using the IPX/SPX protocol.
  • When using a multi-port HP JetDirect Print Server, the HP LaserJet all-in-one device must be connected using Port 1.
  • It is recommended that a static IP address be assigned to an HP Jetdirect Print Server before installing the software. If the IP address changes after you install the software, you will lose scanning and faxing functionality from the computer.
Check the firmware revision number by printing a configuration page for the HP Jetdirect print server. If the firmware version is not H.08.00 or J.08.00 or higher, upgrade the firmware before using the HP Jetdirect external print server with the HP LaserJet all-in-one product. See the documentation that came with the HP Jetdirect print server for more information about upgrading the firmware. The HP Jetdirect 170X and 175X print server firmware is not upgradeable.
See this document for instructions on upgrading the firmware on multiple HP Jetdirect Print Servers at the same time: HP Jetdirect Print Servers - Update Firmware for multiple HP Jetdirect Print Servers at the same time using HP Download Manager or HP Web Jetadmin.
See this document for instructions on upgrading the firmware on a single HP Jetdirect Print Server: HP Jetdirect Print Servers - Update firmware for a single JetDirect Print Server using Jetdirect EWS or FTP.
Country: Flag Bulgaria
