    We are upgrading our website
Compaq Evo Notebook N600c - Features and Specifications
This document covers the fetures and specifications of the Evo N600c Notebook.
Figure : Image of the Evo Notebook N600c
Feature
Specification
Intel 830M
BIOS
Compaq BIOS
Processor (depending on model)
  • Mobile Intel Pentium III 1.2 GHz-M
  • Mobile Intel Pentium III 1.06 GHz-M, 1.8 GHz-M
  • Mobile Intel Pentium III 866 MHz-M
Cache
512 KB L2 cache
Memory
  • Standard 256-MB or 128-MB (133 MHz) SDRAM
  • Maximum 1024-MB (133 MHz) SDRAM
Storage (depends on model)
  • Hard Drives
    • 30-GB SMART Hard Drive
    • 20-GB SMART Hard Drive
    • 10-GB SMART Hard Drive
  • Optical Drives
    • DVD/CD-RW Combo Drive
    • CD-RW Drive
    • DVD-ROM Drive
    • CD-ROM Drive
  • Diskette Drives
    • Floppy Drive (optional)
    • USB Floppy Drive (optional)
    • SuperDisk 2X LS –120 Drive (optional)
Video
  • ATI Mobility Radeon 64-bit video graphics
  • 16MB or 32MB DDR SDRAM depending on model
  • AGP 4x
  • Controller Clock Speed: 166 MHz
  • Max Vertical Refresh Rate: 100 Hz
  • 14.1-inch color TFT SXGA+ with 1400 x 1050 resolution (up to 16.7M colors internal)
  • 14.1-inch color TFT XGA with 1024 x 768 resolution (up to 16.7M colors internal)
Audio
  • ESS Allegro Audio
  • Compaq Premier Sound for enhanced stereo audio
  • Integrated 16-bit Sound Blaster Pro-compatible stereo audio
  • Integrated stereo speakers and microphone
  • External Hardware volume controls
  • Headphone-out
  • Microphone-in
  • Software MPEG1 support, MPEG2 and DVD
  • Integrated microphone in and headphone/line out audio jacks
  • High-performance single-chip PCI audio acceleration
  • Integrated high-fidelity AC‘97 codec
  • Multistream DirectSound and DirectSound 3D acceleration
  • Sensauraâ CRL positional 3D
  • High-quality sample rate conversion and digital mixing
  • Direct music support
  • Realtime effects processing
  • S/PDIF output for PCM or AC-3 content
  • Full legacy DOS game support as SoundBlaster and SoundBlaster Pro compatible, using TDMA, PC/PCI, or DDMA hardware implementation methods
  • Supports one additional PCI bus master device
Communications
  • 10/100 NIC integrated on system board
  • Type III Mini PCI 56K (V.90) modem (Upgradable to v.92 through drivers)
Power
  • Rated Input Voltage: 90 to 264 VAC (auto-switching)
  • Rated Input Current: < 60W
  • Rated Frequency: 47 to 63 Hz
External AC adapter, 6-foot/1.82 meter power cord included. Total length including External AC adapter is 12-feet/3.66 meter
Battery
  • Primary: 8-cell Lithium-Ion, average life 4 hours average charge time 1.5 hours system off / 3-5 hours system on
  • Multibay: 6-cell prismatic, average life 2.5 hours average charge time 1 hour system off / 2-3 hours system on
The system supports an internal fuel gauge for each battery pack. The fuel gauge is displayed on the LCD or CRT by pressing the FN & F8 keys
Pointing Device
Dual pointing devices (both Pointstick and Touchpad)
Ports \ Slots
  • PC Card Slot Two Type II/One Type III
  • Enhanced Parallel EPP/ECP
  • Serial Port
  • TV-out connector NTSC/PAL
  • External Monitor
  • PPS/2 External Keyboard/Pointing Device
  • Expansion Base
  • Headphone/Line-out
  • Microphone in
  • 4Mbps Fast Infrared Port
  • USB Port
  • LED status indicators
Security
  • Configuration Control Hardware
  • Memory Change Alert
  • Ownership Tag
  • Set-up Password
  • Power-On Password
  • DriveLock
  • Enabled for PC SmartCard options
  • Kensington Lock
Operating System
  • Microsoft Windows 2000 preinstalled (on CD)
  • Microsoft Windows 2000 preinstalled/Windows NT 4.0
  • Microsoft Windows XP Professional
  • Microsoft Windows XP Home Edition
Dimensions (HxWxD)
1.2in x 12.1in x 9.8in (3.07cm x 30.7cm x 25.0 cm)
4.8 to 5.7 lbs (2.1 to 2.5 Kg)
Stand-Alone Power Requirements
  • Nominal Operating Voltage (Li-Ion): 10.8V
  • Average Operating Power: 15W avg
  • Peak Operating Power: 30W peak
Temperatures
  • Operating: 50°F to 95°F 10° to 40°C
  • Non-operating: –4° to 140°F –20° to 60°C
Relative Humidity (non-condensing)
  • Operating: 10% to 90% relative humidity, non-condensing
  • Non-operating: 5% to 95% relative humidity, 101.6°F /38.7°C Maximum wetbulb temperature
Shock
  • Operating 10 G, 11 ms, half-sine
  • Non-operating 240 G, 2 ms, half-sine
Vibration
  • Operating: 0.5 G zero-to-peak, 10 to 500 Hz, 0.25 oct/min
  • Non-operating: 1.5 G, zero-to-peak, 10 to 500 Hz, 0.5 oct/min
Maximum Altitude (unpressurized)
  • Operating: 0 to 10,000 ft / 0 to 3048 m
  • Non-operating: 0 to 30,000 ft / 0 to 9144 m
