Compaq iPaq Products - Expansion Pack System
Your iPAQ features the iPAQ Expansion Pack System, which allows you to personalize the appearance of your iPAQ H3000 or add extra functionality. iPAQ Style Packs offer a range of styles to customize your iPAQ, while Expansion Packs, such as the CF Card, or PC Card Expansion Pack, let you add extra features. Compaq iPAQ Expansion and Style Packs are designed to be easily slid on and off your Pocket PC without having to power off your Pocket PC first.
For information on ordering Compaq iPAQ Expansion Packs, see the Accessories Information flier included in the shipping box, or visit the HP iPAQ support page at www.hp.com/.
To add a Compaq iPAQ Expansion Pack
  1. Remove the protective plug that covers the iPAQ Expansion connector on the Pocket PC.
  2. Slide the iPAQ H3000 into the Expansion Pack until it clicks into place. The Pocket PC will alert you when the Expansion Pack is ready to be used.
Figure : Inserting an Expansion Pack
To view the Expansion Pack properties
Press the QMenu button, then tap Expansion Pack. If the Expansion Pack is installed properly, the name of the Expansion Pack will appear in the Expansion Pack Properties screen.
To remove a Compaq iPAQ Expansion Pack
  1. Press the Expansion Pack lock on the base of the Expansion Pack.
  2. Slide the Expansion Pack down and off your iPAQ H3000.
Figure : Removing an expansion pack
