HP Designjet 110plus nr, 120nr and 130nr Printers - Rollfeed LED Error Information
Icons on the automatic roll feed
There are two LEDs (light emitting diodes) on the left roll feed support, one green and one orange:
Both LEDs off:
The roll feed is not connected to the power supply.
An Indication of NO LEDs lit can be caused by no power. However, it can also be caused by the Cleanout Assembly not being properly inserted into the printer.
Steady Green LED on:
Normal mode - The roll feed is able to communicate with the printer and it is online
Steady Orange LED on:
The roll feed is connected to the power supply but the printer is off.
Steady Green and Flashing Orange LEDs:
The roll feed is on but an error has been detected in the roll feed unit.
Flashing Green LED:
There is a mechanical problem.
Use the printers front panel to help determine detected error.
