HP iPAQ GPS Nav System - How Can I Make Certain I Have the Latest Map Data?
Issue:
How can I make certain I have the latest map data?
Solution
It is important to make certain you have registered your product so that you can be notified as soon as map updates are available for purchase. You will receive a reminder in the iPAQ Navigation System software when the map content may have become dated. You can also go to http://www.hp.com/go/ipaqnavigation to find out more information about map updates.
Summary
Click here to access support information about the iPAQ Navigation System on the Web. Alternatively, technical support for your iPAQ Navigation System is available by calling 1-866-4HP-NAV1 (1-866-447-6281) between 8 a.m. and 8 p.m. (EST) Monday through Friday.
