HP Compaq Business Desktop d530, d330, and d325 PCs - Solving Audio Problems
The following tables provides solutions to common audio problems:
Sound does not come out of the speaker or headphones
Cause
Solution
Volume is muted
  1. From the Control Panel program, click Sound, Speech and Audio Devices, then click Sounds and Audio Devices.
  2. Click the Mute check box to remove the check mark from the box.
Software volume control is turned down
Double-click the Speaker icon on the taskbar, then make sure that Mute is not selected and use the volume slider to adjust the volume.
External speakers are not turned on
Turn on the external speakers.
External speakers plugged into the wrong audio jack
See the sound card documentation for proper speaker connection.
Audio cable not connected
Connect audio cable between CD or DVD-ROM drive and the system board.
Digital CD audio is not enabled
Enable digital CD audio:
  1. From the Control Panel, double-click the System icon.
  2. On the Hardware tab, click the Device Manager button.
  3. Right-click the CD/DVD device and select Properties.
  4. On the Properties tab, make sure Enable digital CD audio for this CD-ROM device is checked.
Headphones or devices connected to the line-out connector mute the internal speaker
Turn on and use headphones or external speakers, if connected, or disconnect headphones or external speakers.
Computer is in standby mode
Press the power button to resume from standby mode.
When attempting to resume from standby mode, do not hold down the power button for more than four seconds. Otherwise, the computer will shut down and you will lose your data.
Software problems
The audio driver might not be installed. For more information, see No Sound from the Speakers in Windows 7.
Noise or no sound comes out of the speakers or headphones
Cause
Solution
Computer may not be detecting the correct speaker/headphone type or output or analog-to-digital auto-sense is not engaged
  1. If you are using digital speakers that have a stereo jack and want the system to auto-switch to digital, use a stereo-to-mono adapter to properly engage the auto-sense feature.
  2. If a stereo-to-mono adapter is not available, use the multimedia device properties to manually switch the audio signal from analog to digital.
  3. If the headphones have a mono jack, use the multimedia device properties to switch the system to analog out. For information, click here to go to Business Desktops d530, d330, and d325 - Setting up Analog/Digital Audio Output.
    If you set digital as the Output Mode, the internal speaker and external analog speakers will no longer output audio until you switch back to an auto-sense or analog mode. If you set analog as the Output Mode, external digital speakers will not function until you change the output mode back to an auto-sense or digital mode. Click here to go to Business Desktops d530, d330, and d325 - Setting up Analog/Digital Audio Output for additional information.
Sound cuts in and out
Cause
Solution
Processor resources are being used by other open applications
Shut down all open processor-intensive applications.
Computer appears to be locked up while recording audio
Cause
Solution
The hard disk may be full
Before recording, make sure there is enough free space on the hard disk. You can also try recording the audio file in a compressed format.
Country: Flag Bulgaria
