HP Scanjet Scanners - HP Scanjet 5400c, 5470c and 5490c Scanners User Replaceable Parts and Accessories (EMEA)
This document provides information on obtaining user replaceable parts and accessories for the HP Scanjet 5400c, 5470c and 5490c Scanners in Europe, Middle East and Africa.
Parts
Interface cable
Part Number
Part Description
C7697-47300
Pass through parallel cable - 25 pin (M) to 25 pin (F) - 1.8 m (5.9 ft) long
C8507-47300
Universal serial bus (USB) interface cable with ferrite - Type 'A' connector to type 'B' connector - 1.7 m (5.7 ft) long
C9930-80003
Universal serial bus (USB) interface cable (Black) - Type 'A' connector to type 'B' connector - 1.83m (6.0ft) long
Power cord
Part Number
Part Description
8120-6260
Power cord (Black) - 18 AWG, 1.0m (3.3ft) long - Has straight (F) receptacle (For Saudi Arabia)
Only used with the worldwide power module
8120-6262
Power cord (Black) - 18 AWG 3-wire, 1.0 m (3.3 ft) - Has straight (F) receptacle - 240V Europe (except Denmark, Ireland and Switzerland)
8120-8881
Power cord (Black) - 17 AWG 3-wire, 1.0 m (3.3 ft) long - Has straight (F) receptacle (For 220V in Denmark)
8120-8882
Power cord (Black) - 17 AWG 3-wire, 1.0m (3.3 ft) long - Has straight (F) receptacle (For 240V in the UK and Ireland)
8120-8883
Power cord (Black) - 17 AWG, 1.0m (3.3ft) long - Has straight (F) receptacle (For 220V in Israel)
8120-8885
Power cord (Black) - 17 AWG 3-wire, 1.0m (3.3 ft) long - Has straight (F) receptacle (For 220V in Switzerland)
8120-8886
Power cord (Black) - 17 AWG 3-wire, 1.0m (3.3ft) long - Has straight (F) receptacle (For 240V in South Africa and Israel)
Power module
Part Number
Part Description
C8517-84201
Low power AC power module (Wall Mount Type) - 200-240VAC - Detachable power cord not needed (Europe)
Use a High Power AC Power Module if an Automatic Document Feeder (ADF) is attached
C8517-84202
Low power AC power module (Wall Mount Type) - 200-240VAC - Detachable power cord not needed (UK and Ireland)
C8517-84204
Low power AC power module (Brick Type) - 100-240V, requires a 3-wire detachable power cord - Worldwide operation
C9867-84204
High power AC power module (Brick Type) - 100-240V, 50/60Hz, requires a 3-wire detachable power cord - Worldwide operation
Required if an Automatic Document Feeder (ADF) is attached, however it can be used if the ADF is not attached
Cover
Part Number
Part Description
C9850-67902
Document cover - Plastic lid that covers scanner glass
This part is only available for HP Scanjet 5470c and 5490c Scanners
Accessories
TMA (Transparent Materials Adapter)
Part Number
Part Description
C9861-60140
Active transparency adapter assembly kit - Includes active transparency adapter with attached power cord, and template which holds up to four 35mm slides
TMA (Transparent Materials Adapter) Template
Part Number
Part Description
C9861-67703
Template kit - Includes template to hold the active transparency adapter in place and a template for holding 35mm negatives in place
ADF (Automatic Document Feeder)
Part Number
Part Description
C9866-60140
Automatic Document Feeder assembly - Does not include power module or power cord
The TMA (Transparent Materials Adapter) and the TMA template are optional accessories for the HP Scanjet 5400c Scanner but they are included with the HP Scanjet 5470c and 5490c Scanners. The ADF (Automatic Document Feeder) is an optional accessory for the HP Scanjet 5400c and 5470c Scanners but it is included with the HP Scanjet 5490c Scanner.
To buy any of these user replaceable parts and accessories, click on the how to buy link at the top of the page.
