HP Deskjet 9600 Series Printer - Product Specifications
Figure : HP Deskjet 9600 series printer
This document provides the product specifications for the HP Deskjet 9600 printer. Below information is available regarding printer identification, system requirements, features, media and more.
Model numbers
Printer name
Model number
HP Deskjet 9650 printer
C8137A
HP Deskjet 9670 printer
C8138A
HP Deskjet 9680 printer
C8139A
Serial number location
The serial number is located at the back of the printer.
Printer description
This printer can print on paper up to 297 x 420 mm (11.69 x 16.5 inches). It connects directly to computers that have parallel or Universal Serial Bus (USB) ports. The printer can also be shared on a network.
Printer features
Other features of this printer include the following:
  • 4800 dpi and PhotoREt IV
  • High print quality and performance
  • Versatile media support: 101.6 x 152.4 mm (4 x 6 inches) to 330.2 x 482.6 mm (13 x 19 inches); 65 to 280 gsm
  • Fast print speeds
  • Flexibility of 4-ink and 6-ink printing
  • Borderless edge-to-edge printing
  • HP Photo & Imaging Software and Smart Software features
  • EXIF print
  • Auto-duplex option
System requirements
Minimum
Recommended
Windows 98
Pentium 90 MHz, 16 MB RAM, 100 MB hard disk space
Pentium 266 MHz, 32 MB RAM, 200 MB hard disk space
Windows NT 4.0
Pentium 100 MHz, 32 MB RAM, 100 MB hard disk space
Pentium 266 MHz, 64 MB RAM, 200 MB hard disk space
Windows Me
Pentium 150 MHz, 32 MB RAM, 100 MB hard disk space
Windows 2000
Pentium 300 MHz, 64 MB RAM, 100 MB hard disk space
Pentium 300 MHz, 64 MB RAM, 200 MB hard disk space
Windows XP
Pentium 300 MHz, 128 MB RAM, 200 MB hard disk space
Mac OS 9.x
iMac 333 MHz or G3 350 MHz, 32 MB RAM
iMac 333 MHz or G3 350 MHz, 64 MB RAM
Mac OS X
G3 (except original PowerBook G3), 128 MB RAM
G4 800 MHz, 256 MB RAM
I/O interface
IEEE-Centronics parallel compatible; Universal Serial Bus (Windows 98 and USB-connect Macintosh)
Recommended cables
Accessories
Part number
HP IEEE-1284 A-B parallel cable (2 m)
C2950A
HP IEEE-1284 A-B parallel cable (3 m)
C2951A
HP USB A-B (2 m)
C6518A
Fonts
8 built-in fonts, 4 each in portrait and landscape orientations:
  • CG Times
  • CG Times Italic
  • Courier
  • Courier Italic
  • Letter Gothic
  • Letter Gothic Italic
  • Univers
  • Univers Italic (Euro Symbol supported)
Media specifications
Media types supported:
  • Paper (plain, inkjet, photo, and banner)
  • Envelopes
  • Transparencies
  • Labels
Media sizes supported are listed in the following table:
Media
Dimensions
Standard US
Letter (8.5 x 11 inches), Legal (8.5 x 14 inches), Tabloid (11 x 17 inches), Super B (13 x 19 inches), Executive (7.25 x 10.5 inches), Statement (5.5 x 8.5 inches)
Standard international
A6 (105 x 148.5 mm), A5 (148.5 x 210 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A3+ (330 x 482 mm), JIS-B4 (257 x 364 mm), JIS-B5 (182 x 257 mm)
Transparencies
US Letter (8.5 x 11 inches), A4 (210 x 297 mm)
Envelopes
US No. 10 (4.12 x 9.5 inches), US A2 Invitation (4.37 x 5.57 inches), US Monarch (3.87 to 7.75 x 7.5 inches), European DL (220 x 110 mm), C5 (162 x 229 mm), C6 (114 x 162 mm), Japanese Kaku No. 2 (240 x 333 mm), No. 3 (120 x 235 mm), No. 4 (90 x 205 mm) Index Cards: US Index card (4 x 6 inches), US Index card (5 x 8 inches),
Index cards
US Index card (4 x 6 inches), US Index card (5 x 8 inches), A6 card (105 x 148.5 mm)
Labels
US Labels (8.5 x 11 inches), A4 Labels (210 x 297 mm)
Custom
89.9 x 146.05 mm (3.54 x 5.75 inches) to 330.2 x 1,270 mm (13 x 50 inches)
Media handling
Recommended media
Type
Tray
Recommended Weight
Paper
input tray or front manual feed slot
65 to 135 g/m2 (17 to 36 pound bond)
Paper
rear manual feed slot
up to 280 g/m2 (74 pound bond)
Envelopes
75 to 90 g/m2 (20 to 24 pound bond)
Cards
110 to 200 g/m2 (110 pound index)
Tray capacities
Tray
Capacity
Input tray
up to 19 mm (0.75 inches) or up to 150 sheets plain paper; up to 15 envelopes; up to 60 cards
Front manual feed slot
up to 10 sheets plain paper; up to 5 envelopes; transparency; photo media
Rear manual feed slot
single sheet; thick media (up to 0.3 mm); envelopes; cards
Auto-duplex unit
13 x 19 inches, 11 x 17 inches, Legal, Letter, Executive, A3+, A3, A4, and B5 (JIS). Does not support banners, index cards, envelopes, or custom sizes smaller than B5 (JIS) or larger than 13 x 19 inches/A3+
Output tray
up to 75 sheets
Ink information
Cartridge
Ink capacity
Part number
Page yield
Black (HP 56)
19 ml
C6656A
450 pages
Tri-color (HP 57)
17ml
C6657A
400 pages
Photo (HP 58)
17 ml
C6658A
270 pages
The printer uses two print cartridges at one time.
  • For four-ink printing, use HP 56 Black and HP 57 Tri-color print cartridges.
  • For six-ink printing, use HP 57 Tri-color and HP 58 Photo print cartridges.
The Tri-color print cartridge ships with a "print cartridge protector." This protector keeps the cartridge sealed and in proper alignment while not in use.
Memory information
16 MB of built-in RAM
Performance information: Print speed
Specification
Fast draft
Fast normal
Normal
Best
black text, letter, plain paper
20 ppm
8 ppm
7 ppm
2 ppm
mixed text color, letter, plain paper
15 ppm
6.5 ppm
4 ppm
1.5 ppm
full-page color, letter, plain paper
4 ppm
2 ppm
1 ppm
0.2 ppm
color photo, 10 x 15 centimeter (cm), photo paper
1 ppm
0.7 ppm
0.6 ppm
0.5 ppm
Performance information: Resolution
Maximum black and color resolution is 4800 x 1200 dpi.
The printer supports up to 4800 x 1200 optimized dpi for color printing and 1200 input dpi. This setting will temporarily use a large amount of hard disk space (400 MB or more) and will print slower. The photo cartridge, if present, further enhances the print quality.
Reliability
Up to 5,000 pages/month
Physical specifications: Dimensions
The following list provides the dimensions for the HP Deskjet 9650 and 9680:
  • 591.5 mm (23.3 inches) (width) x 176.72 mm (6.96 inches) (height) x 378.85 mm (14.92 inches) (depth)
  • With input tray fully extended: 591.85 mm (23.3 inches) (depth)
The following information provides the dimensions for the HP Deskjet 9670:
  • With auto-duplex unit: 469.35 mm (18.48 inches) (depth)
  • With auto-duplex unit and input tray fully extended: 601.36 mm (23.68 inches) (depth)
Physical specifications: Weight
The HP Deskjet 9650 and 9680 weighs 11 kg (24.25 pounds).
The HP Deskjet 9670 weighs 13.8 kg (30.42 pounds) with the auto-duplex unit.
Electrical specifications
Power supply: Built-in Universal Power Supply
Power modules: Input 100-240V AC, 1300 mA 50 and 60 Hz; Output 32V DC, 1500mA
Power consumption: 60 watts maximum
Environmental specifications
Specification
Limits
Operating temperature
5 to 40 degrees C (41 to 104 degrees F)
Recommended operating conditions
15 to 35 degrees C (59 to 95 degrees F)
Storage temperature
–40 to 60 degrees C (–40 to 140 degrees F)
Relative humidity
20% to 80% RH non-condensing
Noise levels per ISO 9296
Sound power LwAD: 6.1 B(A)
Safety certifications
Certification
Printer
CCC S&E (China), CSA (Canada), PSB (Singapore), UL (USA), NOM-NYCE (Mexico), TUV-GS (Germany), K Mark (Korea), CE (European Union), B Mark (Poland), IRAM S Mark (Argentina)
EMC certifications
Certification
Printer
FCC Title 47 CFR Part 15 Class B (USA), CTICK (Australia and New Zealand), MIC Mark (Korea), CE (European Union), BSMI (Taiwan), GOST (Russia), ICES (Canada), VCCI (Japan)
