HP and Compaq Desktop PCs - Motherboard Specifications, MS-6575 v3.1 (Kungur)
Motherboard specifications table
PART/FEATURE
SPECIFICATION/SUPPORT
Motherboard Description
  • Manufacturer's Name - MS-6575 v 3.1
  • HP/Compaq Name - KUNGUR
Motherboard Supplier
MSI
System BIOS Supplier
Phoenix
Form Factor
µatx
Processor Brand
Pentium4
Processor Socket Type
478
Processor Family
Intel Celeron, Pentium 4 HT processor
Maximum approved processor
3.06 GHz Pentium 4 HT processor
Proc. Front Side Bus Freq.
400/533 MHz
Chipset Name
SiS 651/962
Chipset "North Bridge"
SiS 651
Chipset "South Bridge"
SiS 962
Memory Type
DDR
Memory Speed
PC 2700
Memory Sockets
2 DDR-DIMM
Maximum Memory
1 GB DDR 333/DDR 266
Graphics Supplier
Integrated
Graphics Configuration
Down
Onboard Graphics Memory
Up to 64 MB adjustable in BIOS
Graphics Connector (AGP)
YES
TV-Out Device
YES
TV-Out Configuration
Audio
Integrated AC97 Audio
AC'97 CODEC Device
AC'97 2.1 Crystal CS4299
Audio Jacks (Legend Below)
2M (1F+1B), LI, LO, Headphone connector
Ethernet 10/100 LAN Supplier
ICS 1893
Ethernet Configuration
integrated, Down
IE 1394 Front/Back Options
1F + 1B
IDE UDMA Modes
2 x UDMA 100/66/33
Expansion Slots (AGP/PCI/Exten)
1 AGP, 3 PCI
USB Ports
6
USB Front/Back Options
2F + 4B
Serial, Parallel, Floppy, PS2 Kbd & Mouse
1S,1P,1F,PS2 K+M
Serial Port Front Chassis Option
No
Available Mfg Options (Legend Below)
G,L,E,6
LEGENDS
A
Audio down on motherboard
C
External L2 cache on motherboard
E
1394 on motherboard
G
Graphics down (on motherboard or in chipset)
L
LAN on motherboard (Ethernet)P - PCMCIA slot
LI
Line In
LO
Line out
M
Microphone
M/G
Midi/Game
S
S3 power management support
S/O
Speaker
T
TV-out on motherboard
U
Graphics card (up, not on motherboard)
W
Microsoft Windows XP hardware compliant
6
6 speaker mode
Motherboard layout and photos
Figure : Layout
Figure : Photo
    Figure : View of back panel connectors
  1. PS/2 mouse
  2. Parallel port
  3. IEEE 1394 connector
  4. RJ-45 connector
  5. Line in jack
  6. Line out jack
  7. Microphone jack
  8. USB 2.0 connectors
  9. USB 2.0 connectors
  10. VGA connector
  11. Serial connector
  12. PS/2 Keyboard
Clearing the CMOS settings
The Clear RTC RAM (3-pin JBAT1) jumper allows you to clear the Real Time Clock (RTC) RAM in CMOS. It also allows clearing of date, time, and system setup parameter memories in CMOS, by erasing the RTC RAM data. The onboard button cell battery powers the RAM data in CMOS, including system setup information.
Do not change any jumper setting while the computer is on. Damage to the motherboard can result.
  1. Turn off the PC and unplug the power cord.
  2. Move the JBAT1 jumper cap from 1-2 (normal) to 2-3 (clear CMOS).
  3. Keep the JBAT1 jumper cap on pins 2-3 for 5 to 10 seconds, then move back to pins 1-2.
  4. Plug in the power cord and turn on the PC.
  5. Press F1 to enter the BIOS setup and change BIOS settings.
Clearing the BIOS password
The BIOS password protects the BIOS from undesired changes. If password checking is enabled, and you need to disable it, use the following steps:
  2. Remove the JPWD1 jumper cap.
  3. To enter BIOS setup, start the PC and press the F1 key as the PC starts.
  4. Clear or reset the BIOS password.
  5. Save the BIOS settings and shutdown the PC.
  6. Replace the JPWD1 jumper cap.
